Old 06-22-2025, 05:12 PM   #1
2020 30' International
Needville , Texas
Tire size
I have lifted my 2020 airstream international 3”, can I fit a 235/85/16 without rubbing the frame , please advise
Cedart is offline   Reply With Quote
Old 06-24-2025, 08:03 AM   #2
"Cloudsplitter"
Welcome Aboard...
AI sez the demensions are....
A 235/85R16 tire has a diameter of 31.73 inches, a width of 9.25 inches, a sidewall height of 7.86 inches, and a circumference of 99.68 inches.
Are you planning on using a trailer tire, 'ST' ?
I’m an AS owner, and I'm really good at fixing things that aren't broken.
ROBERT CROSS is online now   Reply With Quote
Old 06-24-2025, 08:10 AM   #3
1986 29' Sovereign
Southern , California
Po of my 86 sovereign 29' put 235/80/16 on it and it's not lifted. Clearance is about 1 inch in the front, 1/2 inch in back and close to 3 inches on top
Im2bent is offline   Reply With Quote
Old 06-24-2025, 08:15 AM   #4
1986 29' Sovereign
Pics
ID:	454466   Click image for larger version
Old 06-25-2025, 06:43 AM   #5
Needville , Texas
Im using a 235/85/16 G614 14 ply Goodyear trailer tires , I have installed them on my hydraulic tilt trailer and they made a world of difference
Old 06-25-2025, 12:01 PM   #6
2019 22' Sport
High River , Alberta
Do you really want to? They're very heavy (60 lbs each) and no doubt very stiff tires that seem to be designed for the heaviest tandem axle trailers, especially big fifth wheels that really should have three axles.
I can appreciate that they are ideal for a dump trailer in heavy use, but I'd be concerned about beating up an Airstream and dealing with sheared interior pop rivets on a constant basis.
They also have a lower speed rating (120 km/h / 75 mph) than other options such as the Endurance which are rated for 140 km/h / 87 mph.
AlbertF is offline   Reply With Quote
Awning size; wheel lug nut size jaygoree 2011 - 2015 International 0 02-19-2015 04:18 PM
What size TT have the same size awnings LI Pets Awnings 11 07-19-2014 01:04 PM
Plug size and ball size for '66 Safari 22'? Jezibels Hitches, Couplers & Balls 3 08-13-2009 06:59 AM
Twin Size Size Over59 Upholstery, Blinds, Walls & Interior Finishes 5 08-20-2004 10:18 AM
