Hi all,
looking at my tires I see some small minor cracks starting on the sidewalls. Tread is fine. I don't know how old the tires are.
I'm gonna replace the other 2 anyway(other 2 are cupped and definately need replacement along w/axles), would you go ahead and replace all 4? How can I tell?
thanks
Joe
There is really no hurry, take your time. Anytime tomorrow would be soon enough to replace all four.
Seriously - they rot from the inside out. So however bad they look outside, they are that much worse inside. A check of the archives will turn up tales of two, three, and even four old tires failing while on the road.
Tread wear is not a significant factor. In fact, the hardest thing on tires is to set in one spot for year after year.
