Old 06-28-2021, 08:18 PM   #1
1967 22' Safari
Elysburg , Pennsylvania
Tire question...
SO... If I currently have 235/75/B15
can I switch to a 225/75/R15 and they will still fit the rims? I am switching out the tires to the rims and will NOT be moving this trailer. Its a 1967 and she is not road worthy, she is just a sweet spot at a campground, but my tires are dry rotted and one is flat so I need to do something.
Ginabeana is offline   Reply With Quote
Old 06-29-2021, 12:30 AM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The R15 in the tire sizes above means the tire is to be mounted on a 15" rim.
The new tire you want will fit the rim. It is smaller in width. And will have a lower load capacity so NOT recommended for towing the trailer at distances and at speed.
For your stated use should be OK.
Action
Old 06-29-2021, 05:11 AM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Is this trailer after new tires a candidate for jack stand supports under the frame as it's grounded?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is online now   Reply With Quote
Old 06-29-2021, 05:14 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
the 225 size will probably be closer to what the trailer came with than the 235 on it now.
Airstream Tire Poll for Travel Trailers with NO Tire Failures Phoenix Tires 5 01-09-2015 08:11 AM
Blown tire-Discount Tire sold me Carlisle?? FLYNCLD Tires 15 08-22-2010 09:45 AM
help with measurments from tire to tire '67 Caravel Trophycare General Repair Forum 0 07-19-2010 11:17 AM
Tire protection, tire cover and airconditioning leong1 Tires 0 06-22-2009 04:02 PM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
