Old 09-13-2021, 06:50 PM   #81
WHUDS22's Avatar
2018 25' Flying Cloud
Arcadia , Oklahoma
Originally Posted by Tireman9 View Post
Simply selling lots of tires does not make someone an actual tire "Expert". Maybe you need to ask those self proclaimed "Experts" how many tires have they been responsible to take from concept through the development and testing to production?
Have they bee declared in a court to be an "expert"?
You folks here in this forum in that you have two actual tire design engineers that follow this forum. These engineers are from two different tire companies bringing decades or actual tire design, testing and inspection of failed tires to learn the reason for failure. I suggest you listen to the advice given.
Understood,
I was not clear when I read my statement, I do not mean to say underinflate but to run at a lower PSI somwhere between 65 and 75, this allows for air to expand when heated. Also a softer ride
Just from some "other experienced" people
But it feels a little hostile in the thread, I'm not a tire expert
So peace out
WHUDS22 is offline   Reply With Quote
Old 09-13-2021, 07:20 PM   #82
Freedom
KCurtis's Avatar
2020 25' Flying Cloud
Dallas , TX
I own a 25RB Flying Cloud I tried 80Lbs as the dealer instructed for the first couple of months. After replacing several rivets after each trip I decide something was wrong. After I weighed my fully loaded trailer on CAT scales I referee to the Goodyear Endurance Tires table that has been posted in this thread. It said I should use 45 lbs. based on my total weight. That is when I decided that 60 lbs should be safe.
Since then I’ve been all across the USA from Florida to California through the desserts and to Montana across to Mackinaw Michigan and back to West Texas in the summer heat. I’ve now totaled over 30K miles on my tires and the have worn evenly and still look great. I plan on replacing them by the end of this year because I feel I have gotten the best out of them. I travel consistently at 65 MPH on the highways.
Based on MY experience I will stick to this routine. That Goodyear tires weight reference chart reads in Lbs; Airstreams are weighed in Lbs too. Therefore it made sense to me to refer to it and so far it hasn’t proven me wrong.
2020 25RB We named her Freedom
2019 Chevy High Country
WBCCI: 26506
KCurtis is offline   Reply With Quote
Old 09-13-2021, 07:38 PM   #83
2021 25' Globetrotter
Oviedo , Florida
Seems to me we’re settling in on what the purpose of the load charts are. As others have asked, if they are not intended to provide recommended pressure for a specific load environment, why publish them?
jondrew55 is offline   Reply With Quote
Old 09-13-2021, 10:03 PM   #84
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by richard5933 View Post
I've asked this before and have never seen a good answer, so I'll ask again...
If the 'best' way to use Goodyear Endurance tires is to simply fill them to the max cold inflation pressure of 80psi, then why do they even bother publishing a load & inflation table. It would be much simpler for them to just instruct every user to fill them to the 80psi point and let it be. Surely the engineers at Goodyear know something about this...
A ST tire and/or other tire will end up on farm equipment, or a very old vehicle or some other situation that the manufacturer was not required or did not have a tire pressure decal. For that situation the tire manufacturer publishes a tire pressure chart which I understand is created by the Tire Industry.
It shows for a given tire, with a given load the minimum pressure needed to support that load.
And know the tire manufacturer has no clue what tire will be mated to what vehicle. Therefore the vehicle manufacture's tire decal when supplied supersedes the tire pressure charts.
Pretty sure that is correct. Pretty sure if it isn't, there will be a post to clean up my mess.
Action
Action is online now   Reply With Quote
Old 09-14-2021, 04:41 AM   #85
Oviedo , Florida
Well, not sure if this is written by lawyers or engineers, but from what I can tell all tire manufactures recommend you use the cold inflation pressure recommended by the vehicle manufacturer. Goodyear is very specific:
"IMPORTANT: It's a common practice for RV owners to lower tire pressure in their search for a smoother ride. This is not only dangerous, it's relatively ineffective, as the difference in ride quality is not significant. When minimum inflation pressure requirements are not met, tire durability and optimum operating conditions are compromised. Tire inflation pressure should always meet at least the minimum guidelines for vehicle weight." (https://www.goodyearrvtires.com/tire...n-loading.aspx )
I've looked at similar information from Toyo, Firestone, tires.com etc. The load/inflation charts are intended for situations where you are selecting an alternative size or type tire to the ones supplied by the RV manufacturer. Then you should use the recommended pressure based on the maximum load seen on any tire on a particular axel. Then use that pressure for all tires on that axel. Of course if you back that information out from the Goodyear charts, it would come out to 2800 pounds per tire (at 80 PSI) or a total vehicle load of over 11k pounds.
I think what's going on here is the tire manufacturers want to ensure the liability for under-inflation accidents lies strictly with the vehicle manufacturers and if owners use the information they supply for these products based on owner calculations, they do so at their own risk. I'd be surprised if one of our resident tire engineers would contradict that norm and give a thumb's up to calculating your own pressures.
Years ago I had a blowout on a different travel trailer that damaged the sheetmetal. The insurance company adjuster came out and asked if I still had the tire that blew out. All I had were the shredded fragments. They did not check the pressure of the remaining tires. Maybe if the accident had injured or killed someone they would have checked that to see if the tires were to mfg specs.
Old 09-14-2021, 05:26 AM   #86
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by jondrew55 View Post
The charts say "TIRE LOAD LIMITS (LBS) AT VARIOUS COLD INFLATION PRESSURES (PSI) USED IN NORMAL HIGHWAY SERVICE*". .....
A load limit is a maximum. It means that at that pressure that load value is the limit you can load to.
If you approach it from the other direction, it means if you want to carry the load listed, you need to use AT LEAST that amount of pressure.
CapriRacer
Please visit my website: https://www.barrystiretech.com/index.html
CapriRacer is offline   Reply With Quote
Old 09-14-2021, 10:18 AM   #87
Ann Arbor , Michigan
Tire Engineers weigh in
I would be interested to know what type of airstream the tire engineers have, GVWR and/or what weight they load the trailer and what pressures they use. I’d follow that.
MandN is offline   Reply With Quote
Old 09-14-2021, 10:36 AM   #88
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Not really relevant as a tire is a tire and all inflation is measured in PSI on this side of the pond.
Follow their posts and it should become clear what they "advise."
I'm at 74, but my parameters....Better high than not enough.
Tahawus
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 09-14-2021, 11:31 AM   #89
Ravenna , Ohio
Originally Posted by WHUDS22 View Post
Understood,
So peace out
When developing and testing tires we never let air out of a warm tire and only specify and set pressure when the tire is at ambient temperature. Depending ton the testing done the ambient temperature may be 20°F when doing snow traction testing or it may be 100°F in a tire test chamber.
It could even be argued that tire engineers depend on the increased pressure to allow the tire to run longer.
I apologize if I come across too strong. I will admit to getting frustrated at providing the same answers to the same questions over and over and over, as I have been doing for the last 10 years on various RV forums and in the 500 posts in my Tire Safety Blog.
Retired tire engineer (40 years). Write a blog on RV Tire Safety. Give seminars for FMCA across the US. Gillette, WY July 7-10 2021.
Tireman9 is offline   Reply With Quote
Old 09-14-2021, 11:33 AM   #90
Ravenna , Ohio
Action
You got it right.
Old 09-14-2021, 12:34 PM   #91
Oviedo , Florida
I get it. Every few months (weeks?) new chuckleheads like me start asking the same questions that have been answered ad nauseam.
Old 09-14-2021, 02:29 PM   #92
2021 16' Caravel
Callao , Virginia
My problem was NOT overinflation
Just replaced the tires I mentioned earlier. After inspecting them, it is clear the tread damage was not caused by over inflation. The tread damage was not uniformly on the center tread, it was in diagonal bands across the treads. It was caused by the brakes locking. This occurred quite a lot when we first purchased our Caravel; we set the gain too high. If I can get it to work, I will attach a photo. Anyway, I am no longer convinced running the tires at 80psi causes undue wear or shortens the life of the tires. Setting the brake gain wrong definitely will.
kmrice is offline   Reply With Quote
Old 09-14-2021, 03:13 PM   #93
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Thanks for posting and the thread is getting off topic.
I don't want to shut down a discussion.
There is no issue with starting a new thread with your situation.
And it seems the OP hasn't posted for a long time and the thread has drifted off.
Action
Old 09-14-2021, 03:53 PM   #94
Ravenna , Ohio
What you have in the tire in the picture is called "Diagonal Wear" according to tire industry condition manuals. The guide states "Localized flat spots worn diagonally across the tread at approximately 25° to 35° angles often repeating around the tread circumference."
Probable cause "Improper bearing adjustment, toe-out, mismounting and other application issues"
Proper tire inspection should identify this condition early on so corrective action can be taken. You could try and reverse the direction of rotation before the condition gets severe.
Old 09-14-2021, 03:53 PM   #95
2017 25' International
West Lake Hills , Texas
Now you'll excuse me while I concentrate on a fight in a cooking forum about whether to salt the water before or after it boils when making pasta.
Hilarious…
…Because the timing of the salt doesn’t matter either.
Fungus is offline   Reply With Quote
Old 09-14-2021, 03:58 PM   #96
Looking at the two flat spots,(are there more) it appears a balance concern, bad shock, if it has them, will also contribute.
Tahawus
RLC
Old 09-14-2021, 06:13 PM   #97
Oviedo , Florida
Originally Posted by Fungus View Post
Hilarious…
Not true… a pile of salt at the bottom of your pot while it heats can cause corrosion.
Old 09-14-2021, 06:28 PM   #98
Never noticed that on stainless steel. But pasta is not a part of our regular meal rotation...maybe once a quarter. When we do cook pasta, we sprinkle kosher salt around a large shallow (two-inch deep) pan instead of dumping it in a pile. It dissolves instantly. Come to think of it, the water is probably at least somewhat warm.
It is interesting though, the weird conversations you can get into with true aficionados. I was once a witness to a conversation about freshly ground Kona coffee being pour-over brewed at 210 degrees F instead of 180 or 190. So I tried it. Couldn't tell a difference.
Old 09-14-2021, 06:33 PM   #99
Oviedo , Florida
It’s like wine. Most double blind testing show extremely high bias to label favoritism. I wish that were true for single malt scotch.
Old 09-15-2021, 06:07 AM   #100
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by tireman9 View Post
what you have in the tire in the picture is called "diagonal wear" according to tire industry condition manuals. The guide states "localized flat spots worn diagonally across the tread at approximately 25° to 35° angles often repeating around the tread circumference."
probable cause "improper bearing adjustment, toe-out, mismounting and other application issues"
proper tire inspection should identify this condition early on so corrective action can be taken. You could try and reverse the direction of rotation before the condition gets severe.
x2!!
CapriRacer
Tire pressure — should I bump up the pressure on my truck's tires? WhereStream Towing, Tow Vehicles & Hitches 27 08-22-2021 07:44 AM
TV Tire Pressure & RV Tire Pressure Q's starpicker Towing, Tow Vehicles & Hitches 37 05-26-2021 09:02 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 19 07-03-2019 09:19 AM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
