Old 05-03-2022, 04:32 PM   #1
1999 25' Safari
Cincinnati , Ohio
Tire Pressure on Goodyear Endurance
Just got a set of Goodyear Endurance on our 25' Safari. What is a good tire pressure for these. I ran my old tires at max (50psi) and these are 80psi max and that seems excessive. Thanks, Charlie
Chazblank is offline   Reply With Quote
Old 05-03-2022, 04:38 PM   #2
2007 16' International CCD
Somewhere , Colorado
Find your tire size, determine the loaded weight of your trailer, and there’s the manufacturer’s recommendation.
https://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
field & stream is offline   Reply With Quote
Old 05-03-2022, 05:06 PM   #3
2021 30' Globetrotter
Oviedo , Florida
Oh no! Back from the grave!
jondrew55 is offline   Reply With Quote
Old 05-03-2022, 06:03 PM   #4
2019 25' Flying Cloud
Hendersonville , North Carolina
Tire Pressure Minefield
OK, I will take a stab at this and hope I do not get blown up.
2 Airstreams. First 2017 International 23. Goodyear Endurance tires. Trailer weighed right at 5600 LBS ready to travel. Ran 55 PSI. Put 20K miles on it in 2 years. No problems and no popped rivets. Second 2019 Flying Cloud 25 RBT. Goodyear Endurance tires. Trailer weighs right at 6400 LBS ready to travel. Run 60 PSI. So far 25K miles. No problems and no popped rivets. This is how I run our rig and so far so good.
I treat our tow vehicle the same way. 2013 Ford E150 XLT Premium van. 8600 GVWR (yes, it is an E150). From factory with Michelin defenders with E Rating. Door sticker says 55 PSI Front, 80 PSI Rear when fully loaded. The van weighs 6400 LBS ready to travel. I run 50 PSI in front and 65 PSI in the rear. The front axle is rated at 3700 LBS and is only loaded to 3200 LBS ready to travel. The back axle is rated at 5120 LBS and is supporting 4200 LBS after hitching up the AS. This has worked well for us. Currently have 65K miles on the van tires and they still have a whole bunch of tread depth.
So. bottom line is to head to the CAT scale and do a 3 pass weigh in. Set your pressures to support your rig without beating it to death. 80 PSI in the trailer tires just beats up the trailer. IMHO.
uraljohn is offline   Reply With Quote
Old 05-03-2022, 06:34 PM   #5
Rich Jenkins's Avatar
Tavares , Florida
Working through this also.
Currently 75 psi on our 23GT FBT. No popped rivets but did have some cushions on the floor a couple times on our way back from Colonial to Florida last month. Hmmm...not sure if pressure or just Jersey Turnpike lol.
Using the GYE load chart for our rig, I’ll probably go with 65 here shortly. I know there is a wide range opinions on this, to say the least.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Rich Jenkins is offline   Reply With Quote
Old 05-03-2022, 06:46 PM   #6
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
I run 60 psi on our 28'.
StuartsDad is offline   Reply With Quote
Old 05-03-2022, 06:48 PM   #7
1999 25' Safari
Cincinnati , Ohio
Thank you for all the feed back. I think I'll go with 60psi.
Old 05-03-2022, 08:17 PM   #8
2017 25' International
West Lake Hills , Texas
I run 55 psi on our 2017 25FB. I think, but not sure, that the OEM wheels are rated at 65 psi. One popped interior rivet this year.
Fungus is offline   Reply With Quote
Old 05-03-2022, 10:33 PM   #9
Dennis C's Avatar
Evergreen , Colorado
I run my GYE tires at 70 PSI. All good.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
Dennis C is offline   Reply With Quote
Old 05-04-2022, 06:21 AM   #10
"Cloudsplitter"
I run just enough....65-75...
CK the inside of the wheel...max wheel pressure may be stamped.
Old 05-04-2022, 06:30 AM   #11
CapriRacer
CapriRacer's Avatar
I'm in the , US
Just so everyone understands, those charts are MINIMUMS, not recommendations.
CapriRacer
Want to learn about tires? Please visit my website: Barry's Tire Tech New content every month!
CapriRacer is offline   Reply With Quote
Old 05-04-2022, 07:21 AM   #12
This is accurate, and a very significant clarification to my poorly worded comment. Thank you!
The charts are labeled minimums for normal road service, not the manufacturer’s recommendation for any particular application. Similarly, the maximum recommended by the manufacturers (stamped on the sidewall) is not their recommendation for any particular application either. The optimum pressure for any application probably is neither the max nor the min.
OK, I’ll venture an opinion: given the frequency of reports of falling cabinets and dining tables, popped rivets, tossed cushions, etc. I avoid the higher end of the range. Midway seems to work well for us.
Old 05-04-2022, 07:45 AM   #13
Berkel-Enschot , Noord-Brabant
On forest river forum similar question
https://www.forestriverforums.com/fo...si-249914.html
Already more then 100 reactions.
Search for my first post # 62, in wich I stated that if you let me calculate it with my extra safe spreadsheet, both the C- and E- load tires could give pressures below 50 psi, because tandemaxle tralers often have comfortable reserves.
In that topic it appeared to be not true , and The E- load needed 74 psi to give all the reserves without bumping.
But I based that on airstream TT's in the past, so here probably I am right.
So give old and new tiresises and maxload and loadrange and if ST.
And of TT the GVWR, GAWR's and number of axles ( I assume 2 axles) .
Then I will do the calculations .
Better ofcource weighed axle-end loads fully loaded.
jadatis is offline   Reply With Quote
Old 05-04-2022, 07:45 AM   #14
Mollysdad's Avatar
The GoodYear chart is the same chart used for GY Marathons, so that should tell you something.
I always ask those using the chart to explain it. They can't.
So, instead of the recommended 28 psi, I decided on 65 psi.
"If driving on I-95 or I-10, reduce pressure to 60 psi." That's science, man!
Why would I understand that? The word minimum doesn't appear anywhere. Is Goodyear that careless?
Old 05-04-2022, 07:53 AM   #15
About that Goodyear list, I also wrote in the forest river topic. Same post #62
In post #104 my end conclusion, after that only defending the statements I made about higher then reference-pressure ( that 50 and 80 psi) , and needed reserves that ate higher then 5% .
Is expantion of the old marathon list in the sises that are the same, so calculated for 65mph , and with an old formula introduced in 1928 for diagonal tires, that leads to much higher loadcapacity's then the european formula for all kind of radial tires, that since 2006 is also used in US for P-tires, and lately discovered also for trucktires and semi-trucktires like for large RV.
Only LT is now still calculated with formula that leads to higher loadcapacity's, not that bad as the ST lists.
Old 05-04-2022, 08:32 AM   #16
All pressure loadcapacity lists give loadcapacity for the pressure with no reserve also the european lists.
Mayby the maxload of tires is calculated with a little reserve, but I would not bet on it.
So the reserves you have to add yourselves first, before looking back in the list.
Some traveltrailer tirepressure-calculators go from 90% used of the loadcapacity belonging to the pressure, so then you dont need to add that first.
In my made spreadsheet I also go from 90% using, and 10% of total weight on towbar
So total weight minus towbar 10% is 90% left on wheels , then adding 11% to that gives again 100% of total weight, for wich pressure is calculated.
Why that complicated?
Because european traveltrailers, have between 1% and 10% on towbar ( axle placed more to the front)
Then I use 4% as towbar weight, left 96% on wheels / 0,9 gives 106.6% of total weigt to calc pressure for.
Only if you choose American Inglish as language, the towbar weight is set to 10%. Together with tire instead of tyre, lbs instead of kg, and some other things.
Old 05-04-2022, 08:46 AM   #17
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
55psi
Had my new truck in for service and asked that they rotate the tires and reset the pressures. I pick up the truck and had not got but a few blocks when I noticed how harsh the ride seemed. Scrolled to the psi screen and sure enough, my fronts were at 50 and the backs at 35. Went back and had them adjust the fronts and rears down to 35. I'll put 50 back in the rears next tow. What a world of difference. Running at max pressures on the trailer is being very "harsh" to your pride and joy. Recommended minimums for weight plus 5 works for me.
2022 25RBT FC, 50A Dual AC, Awning Package, 270W Solar, Convection Microwave. Ceramic Coat, Grand Lounge, 3" Lift, 16" Michelin RIBs, Multiplus II, Battleborn 400A, MPPT 100/50, Orion-TR 30, EasyStart (2), Easy Touch, AirKrafters jenRack, Onan 2500i, Truma Aquago Confort, Starlink, Pepwave, Parsec
2012FB is offline   Reply With Quote
Old 05-04-2022, 08:47 AM   #18
2019 30' International
Pennsylvania , Pennsylvania
I run 'em at 70-72.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 05-04-2022, 09:08 AM   #19
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Around 65 as that is what is recommended
urnmor is offline   Reply With Quote
Old 05-04-2022, 09:14 AM   #20
2016 25' Flying Cloud
tampa , Florida
Just dropped my FC 25' 2016 off at AS for service and they recommend 80 psf as per trailer sticker. I have been running at 65 psf for 12,000 mi and do rivets. Always stuff on the floor usually due to road conditions.
fclewis is offline   Reply With Quote
Goodyear Endurance Tire / Pressure dlkershaw Tires 108 05-11-2021 03:45 PM
Tire pressure for Goodyear endurance brendakerry Towing, Tow Vehicles & Hitches 52 08-22-2019 08:50 AM
Goodyear Endurance Pressure pontzdav Tires 15 07-13-2019 04:42 AM
Endurance Tire pressure on 27FB Int'l LAWBC Tires 155 04-13-2019 10:16 AM
