Old 02-17-2025, 02:50 PM   #1
1975 31' Excella 500
Traverse City , Michigan
Tire Load range
Hi, I just purchased a 1975 airstream excelle 500 and need new tires. This is going to be parked for the summer at a campground so I will not be traveling around. I wasn’t sure if the load range E is not going to work, or do I need to find a C Or D range? The tire is 225/75r15. Thanks for any help
Heidi
Plaiddogs is offline   Reply With Quote
Old 02-17-2025, 04:19 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 198
RE: Tires for 1975 Airstream Excella 500
Greetings Heidi! Welcome to the Forums and the world of Vintage Airstream Ownership!
Heidi
The original factory recommendations for tires on your trailer would be the equivalent of:
ST 225 75 R 15 Load Range C
My suggestion is to go with Load Range D for the slightly higher weight carrying capacity. I have also found that the Load Range D tires give me much better wear when compared to Load Range C on both of my trailers -- 1964 Overlander Land Yacht International and 1978 Argosy Minuet 6.0 Metre. I have run the Load Range D tires on both of my trailers since 1995 with excellent results.
Good luck with your investigation, and Safe Travels!!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC/Pride Streamers/Wisconsin-UP Unit (Primary)/Missouri Greater Ozark Unit (Affiliate Member) #7864
AIR #827
1964 Overlander International
Old 02-17-2025, 09:01 PM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Goodyear Endurance tires should come in the size you need.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 02-18-2025, 04:40 AM   #4
CapriRacer
CapriRacer's Avatar
I'm in the , US
Heidi
The difference between Load Range E and Load Rangle C is the strength of the sidewalls - which is not enough to change how the tire behaves - EXCEPT for load carrying capacity.
The way to achieve more load carrying capacity in a tire is to increase the inflation pressure. A LR E will be able to carry more load than a LR C because the upper pressure limit is higher.
HOWEVER, the load carrying capacity of a LR E is the same as a LR C at the same pressure.
So buy the Load Range E's with confidence that you can use them in place of the Load Range C.
CapriRacer
Want to learn about tires? Please visit my website: Barry's Tire Tech New content every month!
CapriRacer is offline   Reply With Quote
50 psi in a load range E tire?? Bill M. Tires 83 04-02-2018 12:42 PM
Karrier ST225/75R15 Radial Trailer Tire - Load Range E cole3444 Tires 14 12-30-2016 12:08 PM
New Tires - got Load Range E instead of Load Range D Hyperion 2009-2015 Flying Cloud 49 06-08-2016 06:47 PM
Karrier ST205/75R14 Radial Trailer Tire - Load Range D mountainaxe Tires 16 02-11-2016 06:01 AM
Alternatives for R15 D Load Range Tire Cos Tires 15 07-28-2008 10:36 AM
