02-11-2006, 06:26 PM
1963 24' Tradewind
Pittsford
, New York
Spare tire - best way to handle
Just purchased 63 tradewind (first trailer). Where did AIrstreams originally have the spare tire? I have seen some trailers on eBay with the tire mounted on he back - is that a customization or did they come from the factory like that?
Any suggestions / information appreciated!
-Sig
02-11-2006, 06:45 PM
Moderator Emeritus
1972 31' Sovereign
High Springs
I keep mine in the bed of the tow vehicle. Not a good idea to keep spare on the back of the coach, due to rear frame seperation issues.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
02-11-2006, 06:51 PM
Desert Fox
1985 31' Sovereign
Tucson
Spare Tire
Hi Sig,
On my 1985 Sovereigh I gave up trying to mount the spare tire. All I do now is trow it in the back of the pickup which has a camper shell on it. I feel that AS felt that with 4 tires we may not need a spare and could limp in to repair station. Good luck about the repair station when you are heading to Alaska or far west. The repair stations are far and few.
I used my spare 3 times so far for one reason or other. Mostly becouse one my axels was bent. We blamed the brake locking up.
So if you have a pick up tow whecle just trow it in the back.
Regards Russell In Sunny Tucson Az.
02-11-2006, 07:00 PM
Mansfield
Airstream makes a spare tire carrier for its newer trailers that fits under the tongue,behind the propane bottles. I believe it was made for its newer trailers. There might be a way to adapt it to your tradewind
02-11-2006, 07:30 PM
Allentown
, New Jersey
Hi Sig,
I have a 1971 Safari and my spare tire is mounted under the frame of the trailer in the front end of the trailer. I had assumed that this was standard on older AS's. Fortunately I have never had to use it and I hope it stays right where it is. Good luck with your new rig.
Larry
02-11-2006, 07:40 PM
_
isn't the '63 tradewind on smaller wheels or with less ground clearance than the newer trailers?...seems this would be an issue with the front/under tire carrier?
cheers
2air'
02-11-2006, 10:23 PM
spare tire in front
I found that there is room on mine in front between the trailer and gas tanks
here is a picture
Life's short...take your kid camping
02-11-2006, 10:30 PM
by the way those propane bottles were stollen and the new replacements are on and the tire still fits fine. there is not alot of room under my trailer to mount a spare but that sounds like another location to look at maybe yours has more ground clearance than mine... my brother has another brand and his spare is in front...between the frame rails like a spare on a pickup..? what ever you chose good luck and I would try to have a spare with me somewhere
02-11-2006, 10:39 PM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
My spare is right behind the propane tanks just like gotairs'. It is outta the way there and I can lock it and the propane tanks up all at once. Plus I don't have to remember to throw it in when packing for a trip.
Chris
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
02-12-2006, 06:23 AM
Retired.
, At Large
Chris
That is where the spares were located for a long time. There are brackets for this, so the tire won't rub the shell.
02-12-2006, 06:43 AM
Lisle
Here is the factory option under the floor spair carrier. I like this because it is out of the way.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
02-12-2006, 07:12 AM
1963 24' Tradewind
Pittsford
, New York
Originally Posted by Larry71
Hi Sig,
Larry
I like the idea of having it on the trailer. My 63 does sit low however but we are going to have GSM replace the axle and (from my understanding, the trailer will sit consirerably higher with a new one). I will contact CSM and see what they can do. Will follow up with the forum and let you know what we decided to do.
02-23-2006, 07:30 PM
1976 25' Caravanner
Campton
, New Hampshire
I installed mine as per AS instructions in Service Manual , with a few modifications. I didn't want to loose all the floor insulation so I sandwiched a piece if 1" urethane between the plywood floor and the alum shielding(cut from belly pan). I also covered the exposed A frame with alum., then caulked all seams to make water tight . Some angle iron and bolts will make a fine carrier , don't really need AS parts . When wife returns (Florida) I'll try to get some pics , she has the camera. Took about a day , most of it plannig , you know how these one-off's are.
02-23-2006, 07:35 PM
Airstream - Other
Bosque Farms
, New Mexico
What? Carry a spare tire? Where's your spirit of adventure? (Nope, we don't carry a spare.)
Lynn
ACI Big Red Number 21043
02-23-2006, 08:38 PM
Naples
NO spare.......NO Problem!
I have mentioned this product before. It's called Ride-On. It's a water based tire sealant that also keeps your tires in perfect balance as you drive. I have nothing to do with the company, nor do I sell this product, but when I went to change my rear motorcycle tire and found a nail and screw in it with no air loss (I never even knew they were there!) I bought a bunch and added it to every rolling tire that I own: TV, wife's car, the CCD, motorcycle trailer and both motorcycles. www.ride-on.com
lewster
02-24-2006, 04:44 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Lynn
Don't need no stink'n spare you have an Airstream and it will tow on 3 wheels...now what you do if 3 tires go flat is another story I have a spare but only throw it in the truck if we are going more than a couple of hours from home. PO used to put it inside the unit...not my choice.
Aaron
WBCCI #XXXX AIR #2495
02-24-2006, 05:57 AM
Naples
Aaron
Sounds great! But I don't think they will work as well on the single axles with only 1 tire .
lewster
02-24-2006, 07:32 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Here are a few older threads discussing different options for spare tire carriers. One of them has diagrams I drew for the carrier on our '64 GT if you want to build your own.
And yes Lew, it might be difficult to limp to a tire store with a single axle trailer!
Shari
02-24-2006, 09:37 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Maybe it would be like those videos of the front wheel drive car towing a trailer with the rear wheels off to show how well a WDH worked Now all the WDH's come with stickers and directions telling you have to have ALL the wheels on the tow vehicle
Aaron
02-24-2006, 09:58 AM
1977 31' Sovereign
Tampa Bay
Here's a little something I fabricated some time back to accomodate my spare...
Spare Tire Carrier
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
