Old 01-04-2018, 05:51 AM   #1
2013 23' FB Flying Cloud
Lakewood , Washington
Spare Carrier mods-14"to 15" upgrade?
Time to stop lurking.
Picked up a '13 FC 23FB last summer, with original 14" Marathons. After cruising the forums here, elected to move to 15" Sendel T03s with 235/75x15 Mich LTXs, and Dill 1506-453 TPMS. Wheels/TPMS on order. Tires to follow.
Mixed perspectives on the spare tire carrier needing to be modified. I recall the fixes range from nothing-just barely fits with a little grunting; bend the front retaining arms out a few inches; to fabbing longer pivot arms in the rear. Experiences?
Also, I recall 44psi has been recommended as cold pressure with these tires, as opposed to max inflation 50psi.
Thanks, all!
vlaming is offline   Reply With Quote
Old 01-04-2018, 06:02 AM   #2
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
Following along. I have the wheels, but haven't bought tires yet. I was actually going to leave the spare at 14". Just use it like a space saver spare on a car. Have it on the ground long enough to get to the next tire store. I only ordered 4 of the Sendel wheels.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
GettinAway is offline   Reply With Quote
Old 01-04-2018, 06:38 AM   #3
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Spare Carrier Mod
Did this mod last summer. Extended the length of the front retaining arm on the curb side by welding in about 2 in. of new metal. Works great, nothing else had to be done to mine. The spare rack is not hard to drop to do this mod.
I changed everything out to 15", including the spare.
Good luck....
'01 16' Bambi --- Swee' Pea
'13 23D International --- Trixy
'18 F150 Lariat maxtow --- Liz
tinbender is offline   Reply With Quote
Old 01-05-2018, 01:17 PM   #4
2015 28' Flying Cloud
Durango , Colorado
Thanks, all!
I upgraded to 235/75x15 Mich LTXs on our 2011 FC23FB four years and about 30K miles ago. Entirely satisfied. Kept the 14" spare until I had to use it for a 60 mile run after a road hazard blowout. Rolled just fine. Later replaced the spare as well, and the 15" fit the spare holder without mods. That said, I hate that miserable spare holder! I run 50 psi cold and use the external TST TPMS on metal valve stems.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 01-23-2018, 07:45 PM   #5
Johnnyooo
Johnnyooo's Avatar
2015 23' International
Colrain , Massachusetts
I changed the 14" sendel wheels and marathon tires, to 15" sendel wheels with Michelin LTX DEFENDER TIRES. New wheel and tire for the spare as well...Had to bend one arm on the spare tire holder to get the new 15" wheel and tire in ...No trouble at all fitting it in ...
Johnnyooo is offline   Reply With Quote
Old 01-24-2018, 05:32 AM   #6
Thanks for the replies. Have the wheels/tires/tpms put together and stacked up in the house. Waiting on a good weather day to make the swap.
Old 01-24-2018, 06:51 AM   #7
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Don't forget to torque the wheels, tow it about 20 miles and retorque.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 01-24-2018, 11:49 AM   #8
Ravenna , Ohio
Thanks, all!
Since you got the "P" version of LTX, don't forget to de-rate the load capacity when using your passenger tires in trailer application/
Actual capacity = tire numbers/1.1
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
Tireman9 is offline   Reply With Quote
Help Converting Spare Carrier to 16" from 15" interstateflyer Tires 12 04-29-2014 08:57 PM
16" spare tire vs OEM spare tire rack Bluto Wheels, Hubs & Bearings 22 04-30-2013 05:13 AM
Spare tire carrier--underneath Sneakinup Wheels, Hubs & Bearings 3 11-27-2004 03:21 PM
Spare Tire Carrier Pahaska Our Community 8 08-27-2003 09:00 AM
