Old 04-17-2023, 10:06 AM   #1
2018 22' Sport
Santa Fe , New Mexico
Seeking opinion on torque wrench
I have an older non click torque wrench, uses the fixed needle and the scale- think it’s ok to use torquing the wheels? The range is enough, but it’s old school. Was good enuff to rebuild a VW engine, but…. What’s the thinking on this old tech. Good enuff??
Dandyburger is offline   Reply With Quote
Old 04-17-2023, 11:20 AM   #2
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte , North Carolina
Even if the wrench has been cradled for its lifespan, odds are it's still off a little. https://bit.ly/3okPV5J should be helpful.
wimpy is offline   Reply With Quote
Old 04-17-2023, 12:09 PM   #3
"Cloudsplitter"
No problem, I've used both styles for years.
The non-clicker was my Dad's, probably at least 65+++yrs old.
Old 04-17-2023, 01:50 PM   #4
dznf0g's Avatar
Oswego , Illinois
That's called a beam torque wrench. Nothing wrong with them, other than you need a view directly down on the scale. That can be tricky sometimes. But it is the only pound feet wrench I own. My inch pound wrench is a clicker.
-Rich-
Old 04-17-2023, 02:07 PM   #5
2022 25' Flying Cloud
Vashon Island , Washington
I watched a youtube video testing the accuracy of that type of torque wrench and it did really well. I have one but got a clicker because I had to contort myself to be able to read the dial straight on. But, if that's all you have I would say you're way better off than people who don't have one at all.
AlIslander is offline   Reply With Quote
Old 04-17-2023, 04:23 PM   #6
Mollysdad's Avatar
I bought one from Harbor Freight. It's the dial/click type, the markings are hard to see, but the price was right. I force myself to unwind it for storage. For lug nuts I don't think you need a digital. (You do need a deep thin wall 13/16" socket, at least on mine)
$23
Old 04-17-2023, 06:20 PM   #7
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
I have been told to always zero out the pound dial on the torque wrench before storage.
Silvr_Bullet is offline   Reply With Quote
Old 04-17-2023, 06:27 PM   #8
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
I had SnapOn torque wrenches when I was turning nuts and bolts for a living, but I lost them in a fire and replaced the 1/2" one with a Sears model as I don't need a 1/4" or 3/8" anymore. Works fine for me and yes you should unwind it before putting it away.
JEWare
John Ware is offline   Reply With Quote
Old 04-17-2023, 08:07 PM   #9
2017 25' International
West Lake Hills , Texas
^My wrench too. Oldish Craftsman clicker. Unwind before stowing in the case…except now it sits under the back seat of the F-250 with no case. Maxes at 150’#
My other torque wrench is a Delco attachment for a breaker bar. 250’# max. Electronic. I compared it to the craftsman. Spot on. Maybe right or maybe wrong but at least there was a consensus.
Fungus is offline   Reply With Quote
Old 04-18-2023, 07:39 AM   #10
1986 25' Sovereign
Allegan , Michigan
Old style is just fine for what you are doing - it is not rocket science by a long shot. If the pointer is on "zero" when you start it is calibrated. I suspect that the "beam style" wrench will stay calibrated and take more abuse than more modern ones. (If you were doing something more critical where you could not see the pointer then I might have a different opinion.)
My advice: Clean the wheel and hub mating surfaces; take the torque up in several stages using a cross pattern to evenly seat the wheel. The only time you have to check the exact torque is on the final tightening. Check a few miles down the road (50 - 100?) to see that things are OK, if not tighten and check again until it stays tight. You will be fine.
If you want to start a real debate ask if you should use lubricant on the threads; a debate that has been going on for a century or so.
Whit Nash
rwnash is offline   Reply With Quote
Old 04-18-2023, 07:59 AM   #11
Escape Pod II
John Ware's Avatar
2018 22' Sport
Orange , Texas
^^^ You got that right. I posted once that I lubed my lugs and started a heated conversation. I didn't mention that I never lubed them on customer's cars because the torque value changes for lubed fasteners.
JEWare
Old 04-18-2023, 09:13 AM   #12
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Not to get too far off this post but I remember that one, what a hoot! Here's a couple questions.... how may years did you wrench before anyone came up with the torque wrench idea for wheels (and why?), for me I want to say 20 years. How many people re-torque their car wheels at 50, 100 miles etc? Should we even mention torque sticks?! For the record I DO lube my lug nuts and many but not all other fasteners. Product of choice is Wurth CU-800 spray copper anti-seize, just a little spritz every few years (and around the wheel and hub, the chloride road stuff in CO is murder on aluminum). Back to torque wrenches, my weapon of choice is my 50 year old Snap On click style. Had it tested several years back and it was right on the money. Beam style is just fine.
Stay tight, Mark D
mrdes8 is offline   Reply With Quote
Old 04-18-2023, 11:37 AM   #13
2015 30' International
FREDERICK , Maryland
If you are just going to check the torque on your Airstream wheels, most find that an inexpensive torque wrench should be fine - Harbor Freight, Kobalt, Craftsman, Tekton (made in USA - which is what I use). Check to see what is the torque settings for the lug nuts on your tow vehicle. Mine needs to be 150 foot pounds, so you might need one that will go up to at least 150. Now if you are setting the torque for your hitch nuts/bolts, some of those need to be torqued to 250 foot pounds or more. For this you might want to go up to a 3/4" drive. Unless you are a mechanic and use a torque wrench frequently, I personally don't see the need to spend money or a Snap-On or Matco, etc.
As others have mentioned set back to 0 after each use. I keep an index card on my truck sun visor with notes for all of my tire pressures, torque settings for truck and Airstream and most importantly the height of my trailer and truck for quick and easy reference
Doc Foster is offline   Reply With Quote
Old 04-18-2023, 11:54 AM   #14
mykytiukr's Avatar
1965 24' Tradewind
almena , Wisconsin
It’s Fine
Back in the eighties Caterpillar mechanics were only allowed to use the “Beam” type torque wrenches like you have because clickers of the day weren’t all that accurate.
mykytiukr is offline   Reply With Quote
Old 04-19-2023, 05:54 AM   #15
Escape Pod II
John Ware's Avatar
2018 22' Sport
Orange , Texas
Stay tight, Mark D
I started as a VW mechanic at a private shop in 1967 and hired on a dealership in 1971. Sometime early in the 70's a memo came out to torque the wheels because overtightening the lug bolts was warping the drums, especially the 5 bolt pattern wheels. I got a 1/2"click type torque wrench from the SnapOn dealer from which I bought 99% of my tools. I also got a 3/8" drive for engine builds and a 1/4" inch pound one for automatic transmission reassembly. The owner of the independent shop in the 60's had a beam type for engine builds and I used one of those at the Ford dealer to set the preload on the pinion bearings in a rear end.
JEWare
Torque wrench..necessary? Kistler Wheels, Hubs & Bearings 20 08-01-2016 06:15 PM
Torque wrench recommendation needed Papa smurf General Repair Forum 101 03-20-2016 09:39 AM
Torque Wrench by Husky Devoman General Repair Forum 3 01-10-2016 06:51 PM
Torque Wrench..Which one to use. jomondnv General Repair Forum 38 03-19-2013 06:49 AM
$28.99 for a torque wrench... did I was my $ Kistler Our Community 3 03-11-2004 06:27 PM
