I get more use out of my Milwaukee M12 inflator than I do anything else. Slap a battery in it, and carry it exactly where I need it, no air hoses to fight with, no hardwiring or mounting anything. I'd love to have one of the onboard air solutions, but still doubt if get nearly as much use out of it as I do the little inflator.
Ditto on a 120v compressor and use your inverter (if you have one). This unit should run fine with a 1000 watt inverter. But, I’ve not tested this yet.
https://www.californiaairtools.com/ultra-quiet-series-of-air-compressor-contractor-grade/1-2-hp-air-compressors/cat-2050a/
I agree with the battery powered inflator. I have a DeWalt model. So easy to use. Pretty much replaces need for compressor. Uses same battery as the drill I use for the stabilizer jacks. https://www.amazon.com/DEWALT-DCC020.../dp/B07H39S9JQ
