02-19-2023, 08:14 PM
Undecided
Rear tire lifting when backing
We have a 2023 GB 30RBT with a Ram 2500, the following has happened to us twice now as we are backing into our RV drive.
We have driven about an hour at highway speed, then about 3 miles at 40mph, we stop at point A in the diagram and are parked there about an hour. We then go to park in the driveway, I first so a bit of an S turn to get me to point B in the diagram. The trailer is turned a bit so I cannot see down the driver’s side in the mirror.
My wife is behind near the driveway, looking for traffic and guiding me using the cellphone to talk with me. I start backing up, I have gone maybe 5 feet and my wife screams that the back driver’s side wheel is 6-8 inches off the ground and is making some terrible creaking sounds. I stop, pull forward a little bit, the trailer comes back to the ground with a jarring sound, I get out and we look, scratch our heads, etc and cannot figure anything out. We then back in without any issues.
This being our first big trailer, the first time I thought it might have something to do with the weight distribution bars of the Blue Ox hitch, the second time, we had removed the tension bars so we were just on the ball. We have backed into camp sites without this happening.
02-19-2023, 08:30 PM
2017 25' International
West Lake Hills
Is the ground flat?
Any elevation changes or gutters?
What is your brake gain set to?
02-19-2023, 09:43 PM
Undecided
Originally Posted by Fungus
Is the ground flat?
Ground is flat, no gutters, we are in the middle of the street. Brake gain was the same as the rest of the trip at 5 of 10.
Seattle
If I had to guess, your electric brakes locked up, the front wheel ‘digs’ into the ground, lifting the torsion axle, leaving the rear wheel to raise up. Something gets unstuck.
This is a huge guess with very little information, but it’s the first thing I would look at. Maybe the gain is set too high on the brake controller, or something else.
02-20-2023, 12:30 AM
1994 25' Excella
Waukesha
, Wisconsin
Just a wild guess here as well, but check the mounting bolts for your axles - there should be two on each end of each axle. Perhaps one or two bolts left the factory without proper torque allowing the axle to rotate when backing? You should be able to reach these bolts easily from under the trailer.
Richard
11018
02-20-2023, 03:10 AM
2008 22' Safari
Spicewood (W of Austin)
I think Richard is on the right track. Dual axles place considerable strain onto the tires, especially when backing/turning. I believe you are experiencing an axle which is not properly mounted / bolted… or a structural / mechanical failure at that point.
02-20-2023, 04:44 AM
2018 27' Globetrotter
Mooresville
, North Carolina
Following
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
02-20-2023, 06:19 AM
2002 25' Safari
Dewey
6 to 8 inches is more travel than I would ever expect to see on an Airstream axle. Something is wrong...
Richard
02-20-2023, 06:44 AM
Joliet
My first thought also. Time to jack up the trailer and pull some wheels.
02-20-2023, 07:25 AM
2016 27' International
Sherwood Park
, Alberta
It is a brand-new unit. The first thing I would do is take it back to the dealer rather than trying to sort this out yourself.
02-20-2023, 08:06 AM
Undecided
We will be taking the unit in to the dealer to look at, and will report back what is found. I just wanted to make sure this is not some relatively common thing, or something I was doing and the dealer would try to explain it off in that manner. It sure seems odd to us, and am glad it is odd.
02-20-2023, 09:01 AM
2015 25' FB Flying Cloud
Cedar Rapids
, Iowa
You say you do an “S” and come to the position in the diagram but the trailer must be more turned to the passenger side because you can’t see it. If you have turned the steering wheel hard to right to bring the left side around are you jack-knifing and lifting the tire? Once you pull ahead you have straightened out enough to move into
the drive. A 30 footer is pretty big. I have trouble with my 25 sometimes and campers will bring out lawn chairs to watch. I am not trying to offend in any way.
Kemmy
Oh the places we’ll go!
02-20-2023, 09:10 AM
1994 25' Excella
Waukesha
, Wisconsin
This is a good thought...
Perhaps before going to the dealer you can check for any witness marks indicating that your trailer and truck made contact around the tongue areas, or if the hitch you're using got to the extreme of its possible travel on a too-tight trurn and that caused things to go wonky.
Richard
11018
02-20-2023, 09:22 AM
2019 25' International
Washington
, Washington, D.C.
Is there any list to your Airstream when it's parked on level ground?
02-20-2023, 09:27 AM
2013 28' Flying Cloud
Penn Yan
, New York
Odd
I recommend calling the mother ship and asking a service rep about it. You could also reach out to Dexter.
What you’re describing is not normal.
02-20-2023, 09:34 AM
1964 30' Sovereign
Ione
, CA
If loose, axle mount on that wheel location may be sliding forward when backing (thus creating a 'wrap' on the torsion axle). Is not a problem when going forward if axle doesn't slide back. Locked brake would just cause tire to skid. Have axle mount, axle itself, brakes, and wheel bearings checked. Make sure they do it on all four axle sides.
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
02-20-2023, 09:43 AM
2007 25' Safari FB SE
North/East
, New Jersey
I suggest that you try backing it up again and have someone video what is happening to the wheel as you back up. It should be helpful when you bring it to the dealer or contact Airstream service. Good luck.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
02-20-2023, 10:14 AM
2018 19' Tommy Bahama
Downey
, CA
I would suggest going to an empty parking lot and repeat the event, stopping in place when it happens. Put parking brakes on turn off TV and go inspect trailer to see what is happening and take pictures of the problem. Especially underside of axles and mounting points.
02-20-2023, 11:52 AM
2021 20' Caravel
Plaistow
, New Hampshire
Based off what he's saying I don't think I would want to repeat this action too many times.
Learning and enjoying as we go !
02-20-2023, 05:05 PM
1988 32' Excella
Robbinsville
, New Jersey
While that is true, it is probably better to get video evidence. Hate to take it in and get the dreaded "could not replicate problem" or "found nothing wrong".
