Originally Posted by huck55
After reading all about TPMS, I am convinced I need them.
I own a 2019 25’ FC RBT.
How do I measure the valve stem so that I order the correct one? I plan on bringing them to the local Mavis, manager said no problem at $20 per tire.
I called Dill and they are no help at all.
Any help or insight is very much appreciated.
When the old stem is removed the HOLE in the wheel can be measured. But I’m betting they are .453” stems.
A good tire tech would break it down look at it and grab a replacement stem size by eye.
I would not expect Dill to know what size stem is required for an Airstream but if you called Dill and asked for metal stem choices for a .453” stem hole I bet they could rattle them off.
Good luck.
