Old 09-17-2020, 05:28 PM   #1
2019 25' Flying Cloud
Monmouth County , New Jersey
Noobie help metal valve stems
After reading all about TPMS, I am convinced I need them.
I own a 2019 25 FC RBT.
How do I measure the valve stem so that I order the correct one? I plan on bringing them to the local Mavis, manager said no problem at $20 per tire.
I called Dill and they are no help at all.
Any help or insight is very much appreciated.
huck55 is offline   Reply With Quote
Old 09-17-2020, 06:06 PM   #2
2018 25' International
Slidell , Louisiana
well.... You don't need them but they are a very good idea. Full disclosure I still have the rubber ones. But as long as you are replacing them get some TPMS integral stems. The cheap ones on ebay designed for trailers with a repeater is what I recommend, but me? I don't mind periodic fails. You can go with a top brand off amazon or e-trailer also. Anything designed for aluminum wheels will work if they are rated for 80 psi or more.
Brian
Old 09-20-2020, 11:07 AM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Doesn't the tire store stock them?
Action
Old 09-20-2020, 12:04 PM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
When the old stem is removed the HOLE in the wheel can be measured. But Im betting they are .453 stems.
A good tire tech would break it down look at it and grab a replacement stem size by eye.
I would not expect Dill to know what size stem is required for an Airstream but if you called Dill and asked for metal stem choices for a .453 stem hole I bet they could rattle them off.
Good luck.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Metal Valve Stems required for TPMS? JVfromGrnBay Tires 19 01-21-2016 05:13 PM
Valve Stems....Metal or Rubber? jomondnv Tires 25 06-09-2015 04:01 PM
Source For Metal Valve Stems For GMC ? 2dabeach Tow Vehicles 3 12-23-2009 07:46 AM
Metal valve stems jcanavera Tires 7 10-31-2007 11:12 AM
