03-11-2022, 08:07 AM
Ebb and Flo
Tulsa
, Oklahoma
NEW TV tires
It appears to be time to replace my 2012 f150 tires. Currently I have 275/65R18 goodyear wranglers that are mud and snow rated. Previous owner lived in Wyoming, and probably a good tire for that area. But, I am wondering what folks are running for towing across the country.
Is a MS tire right or should I go to a light truck rated tire?
Noise abatement and good handling are important, but safety comes first.
What do you recommend?
David Briggs
Ebb - 2015 F-150 3.5L Ecoboost
Flo - 2012 30' International Serenity
03-11-2022, 08:33 AM
2013 31' Classic
billings
, Montana
You have a p rated tire…..E is the heavier tire… ..
03-11-2022, 08:45 AM
1994 25' Excella
Waukesha
, Wisconsin
Mud and snow rating don't affect safety or load capacity on the roads. They only affect traction in mud and snow. Whether or not you should stick with them really depends on how often you find yourself needing the extra gription in areas like that. If you don't frequently have need to run through mud or snow, then perhaps you'd be better served with a tire with more of a road specific tread.
The Goodyear Wrangle product line comes in a variety bearing the LT designation, meaning that you have the extra load capacity and sidewall strength. Depending on your towing setup and your cargo weights, you might be better served by an LT (light truck) tire than a P-rated (passenger car) tire.
Richard
11018
03-11-2022, 09:02 AM
Our Sprinter 4X4 came to us with Toyo Open Country AT’s 275/70/18. Rough riding and noisey. After 35K miles useless in snow. We replaced with a 265/70/18 Michelin Agilus rated with three “snowflakes” Colorado CDot approved. They are much smoother, quieter and the smaller biase eliniated body-roll fender rubbing. They are nice while towing our 29ft Squarestream
JIM n CHRIS
‘62 Overlander 26 ft. ATW Yeager trailer #5289
"62 Airstream 22ft. ATW Hall trailer #83,’90 SQ Sream, ‘06 Bambi Q/S, Prevost Featherlite 45ft, GMC/ Bigfoot camper
03-11-2022, 09:25 AM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
Ditto on the Michelin Agillis tire. Good ride and have worked well in snow and mud. Off road tires with large voids tend to throw rocks, not good with an Airstream. Discount Tire has Michelin tires on sale this weekend...lucky you!
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
03-27-2022, 11:14 AM
Ebb and Flo
Tulsa
, Oklahoma
According to the dealer my TV tires need to be replaced. Always take dealer recommendations with a ton if salt, especially when that item is on sale.
But, the service writer showed me a series of cracks on the tread that radiate out to the sidewall. Very thin (1/16" wide) and short (generally 1.5" to 2") long.
Do they need to be replaced?
If so, what do you think about hankook tires?
David
David Briggs
03-27-2022, 11:51 AM
1977 23' Safari
Niagara on the Lake
, Ontario
David
Cracks are definitely a sign your tires need replacement.
Also look at the date codes.
When I worked in a fleet service garage we used a lot of hankook tires on company cars and vans, they were a good value tire at the time, but that was 20 years ago.
Just about any tire that meets the required specifications and isn’t aged out or worn out will work. I currently own Cooper, BFG, General, Michelin, Goodyear, Motomaster, Hoosier and Mickey Thompson tires. All are a good tire when used for the appropriate application.
03-27-2022, 11:58 AM
2015 20' Flying Cloud
Kingsport
, Tennessee
Kinda funny, when I was buying my Airstream, at an Airstream dealer, it was used, had the original tires on it, so I was going to get them to put new tires one... but they don't do tires. SO, in their case, if they suggested you did or didn't need tires, it wasn't based on making a sale, it was based on, whether or not you needed tires.
-Leslie
WBCCI #1051
03-27-2022, 12:47 PM
2017 30' International
Broomfield
I run BFG KO2 with DT tread. DT is a harder tread compound for certain tire sizes used for 3/4 ton applications - they don’t wear as fast.
I’ve been very happy with the versatility / performance
(snow, rain, off-road, on-road, towing) and tread wear.
03-27-2022, 01:32 PM
2023 27' Globetrotter
Williamsburg
, Virginia
Michelin LTX AT-2 have been a great combination of on/off road for our F-150. Great traction in snow/mud, quiet on the road.
03-27-2022, 02:18 PM
Salem
, Oregon
Hi, my 2014 F-150 came with that same size and brand name tires. But mine are "LT" load range "C" tires. I treasure my teeth and my wife's back, so I would never switch to load range "E" tires. I might just have to buy the same thing when the time comes.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
03-27-2022, 02:37 PM
Escape Pod II
2022 23' Flying Cloud
2018 22' Sport
Orange
I towed a 22' Sport across country with Goodyear Wrangler DuraTracs on my 2010 F150. They look aggressive but are quiet, handle good, and were good in the rain.
JEWare
03-27-2022, 03:12 PM
2019 30' Flying Cloud
Grass Lake
, Michigan
Just replaced factory tires on my TV with a set of these Michelins last Fall. Very happy with them.
03-27-2022, 04:11 PM
2019 27' Globetrotter
McHenry
Check out Michelin Agilis CrossClimate
David, I replaced the factory Firestones with Michelin Agilis CrossClimates and have been very happy with them. Better ride, much better wet/snow traction.
Check out the reviews on them; they’re always at the top.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
