Old 09-17-2021, 05:23 PM   #1
2014 28' Flying Cloud
Phoenix , AZ
New Tires for Tundra
I'm in need of new tires for our Tundra, and not sure whether to get LT or P. My buddy recommends the P series Hankooks. Tire shop recommend the LT series Continental. Price is about the same (around $1,000 installed) for all 4 tires. My concern about the LT is the ride (especially when unhitched and just driving around town) and gas mileage (who am I kidding when towing? so it drops from 11 mpg to 10?). Any advice, opinions, thoughts? Thanks, Vance
P.S. Currently have P series tires on the Tundra and no issues with handling while towing.
vwii is offline   Reply With Quote
Old 09-18-2021, 12:12 AM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
What year Tundra?
What does the tire placard sticker say on the driver's door post?
Will look similar to the attached.
Action
Old 09-18-2021, 07:02 AM   #3
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
I tried a variety of tires over the years on my first Tundra (2007) and didn't like the E rated tires much.
truckasaurus is offline   Reply With Quote
Old 09-18-2021, 07:24 AM   #4
2019 25' Flying Cloud
Hendersonville , North Carolina
If your Tundra is approaching 7 years old or so, considering installing new TPMS valve stems or bands when replacing tires. The sensors have a battery life of about 7 years. Much less expensive to replace when new tires are installed. Should run around $300.00 for all 4 tires.
The E Rated tires will ride stiffer. My 2013 Ford E150 XLT van has requires E Rated tires (8600 GVWR). They do ride a bit stiff but very stable when towing 25' AS. I have added Sulastic Shackles (wonderful product) to make the ride much better and changed to a Monroe Gas Magnum LT shock absorber. Way better ride.
As suggested check the door sticker and go from there. You can get tires rated for XL (Extra Load) and have a Max Cold PSI rating of 50 or so pounds. You might check them out. They are not a P Rated tire but are marketed for larger SUV's and Light Trucks such as yours.
uraljohn is offline   Reply With Quote
Old 09-18-2021, 07:40 AM   #5
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
I put E rated (Cooper Discoverer 20”) on my 2012 Tundra. The ride was not effected very much. I had already added Bilstein shocks, and a Roadmaster Active Suspension. I did find that the heavier tire knocked about 1 mpg off my gas mileage. No difference in mpg when pulling our 25FB. Still at 10 mpg. Nice firm ride with the AS in tow.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 09-18-2021, 08:26 AM   #6
richw46's Avatar
I'm In , Kentucky
Have you used the Toyota Tire Center site to see which ones are recommended by Toyota? I checked it a couple of days ago and there were quite a few for my Corolla (and my 4Runner a couple years ago). I called the dealership and they just had a sale started on Wednesday; buy 3, get a 4th for $1. It's cheaper than other tire stores near me.
https://www.toyotatirecenter.com
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
richw46 is offline   Reply With Quote
Old 09-18-2021, 09:13 AM   #7
2016 19ft flying cloud
Spokane , Washington
Take a look at Michelin Defenders,,,,I really like mine
Spinonedad is offline   Reply With Quote
Old 09-18-2021, 09:20 AM   #8
Mike from Canmore
Mike G's Avatar
2018 27' Flying Cloud
Calgary , Alberta
I have Continental Crosscontact LT tires on my Yukon, and the ride is fine. I feel much better towing with these than P tires . . .
Mike G is offline   Reply With Quote
Old 09-18-2021, 09:20 AM   #9
Mollysdad's Avatar
Mine came with Bridgestones, but I'm not a Firestone fan so I changed to Michelin Defenders. They wear much longer, and all around are a better tire.
But I don't think the Defender is still available so the Agilis is the replacement?
Old 09-18-2021, 09:27 AM   #10
2014 25' Flying Cloud
Temple , Texas
Its probably not going to make much difference in your ride quality - go with the best you can afford. I always used P on my Ram 1500 as recommend by the Manu.
2014 Flying Cloud 25FB
2018 Ram 2500; Cummins
Blue Ox WDH
RamRider is offline   Reply With Quote
Old 09-18-2021, 09:44 AM   #11
Greeneville , Tennessee
Tires
If you are towing you need LT tires. Just remember the weight that is transferred to the steer axle. Passenger tires will not take the load that LT tires will. I bought Michelin LT tires for my Nissan Titan, love them.
jimfa440 is offline   Reply With Quote
Old 09-18-2021, 10:21 AM   #12
1977 31' Sovereign
Bartlett , TN
LT designates light truck, P designates passenger. Ride trade off for LT is negligible. Stability when towing is paramount. It really won't matter until it does.
jsaucier is offline   Reply With Quote
Old 09-18-2021, 04:09 PM   #13
Phoenix , AZ
Thanks. Toyota does have some good deals, around $1,100 for a new set of Michelin LTX M/S2, equivalent though to what our local tire shops are offering.
Old 09-18-2021, 04:27 PM   #14
Phoenix , AZ
Here's the door placard. Based on the PSI and load limits on the tires themselves, I've been running them at about 40 psi.
Old 09-18-2021, 04:44 PM   #15
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Toyota made it with the P Series tire. I would use that.
Action
Old 09-18-2021, 06:25 PM   #16
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Which size tires do you need? Depending on the trim level of your truck, you may have any one of several sizes. I have the 20” wheels on my 2020 as I did on the 2014 it replaced. My size (275/55R20) are not available in some popular manufacturer’s models. I stayed with Bridgestones (dueler h/l alenza plus) on the 2014. Will likely do the same with my current truck when I need to re-tire.
Silver Cliche’
Follow us at...
silvercliche.blogspot.com
GammaDog is offline   Reply With Quote
Old 09-18-2021, 06:34 PM   #17
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I have used E rated LT Michelins on both our 2500 Burbs.
1994-2021 SFSG
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 09-18-2021, 06:58 PM   #18
Ray Eklund's Avatar
2019 27' International
2014 25' International
Fort Saunders , Wyoming
My experience:
Land Cruisers are P.
Tundras are LT.
Michelin tires on all my Toyotas and my F350 have been LT.
Michelin tires on my Airstream 25 foot & 27 foot models have been Michelin 16" wheel LT. I have used 225 widths in the past, but may try 235 width some day if I find a bag of cash along the highway some day.
I like the 'lots of tire rubber tread' on the road, they are heavy duty and can handle all kinds of roads and wear well.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 09-18-2021, 07:30 PM   #19
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Haven experienced a several tire failures on 3 different brands on my trailer, I ony use Michelins on all my vehicles and trailers. If you are a Airstream Club member, there is a Michelin discount program for members.
The ability to follow instructions is highly underrated.
Always be wary of stupid people in large numbers.
hhendrix is offline   Reply With Quote
Old 09-19-2021, 11:11 AM   #20
Revery's Avatar
2014 23' Flying Cloud
2015 28' Flying Cloud
Laguna Niguel , California
Get Michelin Defenders LT. If you have a Costco near you a set is about $900 with free rotation. I put them on my 2007 Dodge Ram 2500 and I pull 9500lb AS. Reasonably good wear as they will hit 50,000 miles shortly and that will be about time to replace. This is the best tire for your needs. Quiet, smooth ride and durable on highways, many of which can be very rough. Be sure to get an alignment and rotate about every 5000 miles, they will wear well.
Revery is offline   Reply With Quote
Tires...Tires...Tires Bob Thompson Tires 279 09-19-2019 03:17 PM
Choosing tires for 2007 Toyota Tundra soonerbill Tires 9 09-13-2016 10:41 AM
Tundra Tow vehicle tires wlanford Tires 25 07-10-2016 11:53 AM
Good tires for towing/08 Tundra bonginator Tow Vehicles 4 09-01-2010 07:27 PM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
