Old 06-08-2021, 07:08 AM   #1
2014 16' Sport
San Diego , California
New Tires
Need new tires on 2014 Bambi 16 ft. Should I stay with 14” and if I take to tire store can they accommodate a trailer & do they have experience with changing tires on trailers vs Airstream Dealers? Live in So Cal
Karrylou is offline   Reply With Quote
Old 06-08-2021, 07:37 AM   #2
2015 25' Flying Cloud
Tucson , Arizona
Some tire stores can accommodate, but you should call the specific location you plan to go to if you want to be sure. We used Discount Tire and had a pleasant experience. You'll need to look in your owner's manual to figure out where the jack locations are on your model. They're usually marked under the trailer as well. You'll need to make sure whatever tire store you use puts the jacks there and only there or you risk frame issues. I explained this to DT and they were very accommodating and didn't mind me supervising the job.
McStreamy_ is offline   Reply With Quote
Old 06-08-2021, 08:02 AM   #3
Kevin245's Avatar
We won't weigh in on tire size question, but we did get new skins on our 5-er last summer. I called out local Discount Tire and they were very helpful with the order placement and installation scheduling. On the install day they had me back into an area next to their building. Then they brought their equipment out and discussed with us where we wanted the jacks placed. They took it from there. Very pleased with their service.
William C. Swinney
Old 06-08-2021, 08:31 AM   #4
Coloradobus's Avatar
Yes, have tire shop use “jacking points” labeled underneath. DO NOT allow tire shop to “jack up” your airstream by the axle. Chances of ruining your alignment goes up exponentially
JIM n CHRIS
‘62 Overlander 26 ft. ATW Yeager trailer #5289
"62 Airstream 22ft. ATW Hall trailer #83,’90 SQ Sream, ‘06 Bambi Q/S, Prevost Featherlite 45ft, GMC/ Bigfoot camper
Coloradobus is offline   Reply With Quote
Old 06-08-2021, 09:52 AM   #5
1969 27' Overlander
Pleasanton , Texas
How do you locate proper hacking points? 69 Overlander.
Mbeech is offline   Reply With Quote
Tires...Tires...Tires Bob Thompson Tires 279 09-19-2019 03:17 PM
Manufacturer’s tires to new tires Panchopaco Tires 8 12-02-2018 03:20 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
