04-23-2017, 10:04 AM
2017 25' Flying Cloud
Florence
, Alabama
Leaking tire
Just found a heavy duty staple in my tire. Leaking from one prong. It's a pretty new tire with like new thread. What repair options do I have?
The Colonel and Southern Belle
04-23-2017, 11:06 AM
2016 25' Flying Cloud
Holly Springs
, Mississippi
Most will want to use a plug of some description. Were it mine, I'd call three respected tire sales/repair companies, explain your circumstance, and ask how they would repair it, to include describing what the plug looks like. Then decide how to proceed.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
04-23-2017, 11:24 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Plugging a hole in a tubeless tire without putting a patch inside is asking for trouble down the road. I've seen many plugged tires come back with the same hole leaking. (when I worked in a service station many years ago)
This is how I want mine repaired:
Last time I had one of my tires repair the guy used a patch/plug combination, that looked kind of like a mushroom. The plug went through the hole from the inside and the patch was glued on the inside. It worked great.
Alan
04-23-2017, 12:57 PM
Florence
, Alabama
Update: I took it to pep boys and was informed they weren't allowed to do a repair, too close to sidewall and two punchers within a certain distance made it risky. They told me I might find a tire place to put a patch inside, but given my ability to worry constantly about things like this, I decided to replace the tire.
04-25-2017, 07:20 AM
Florence
, Alabama
Update: new tire picked up, installed yesterday, aired up to match others and tpms sensor installed. Took me longer to put the spare back up. That was one expensive staple.
When I picked up tire/wheel they had balanced and used the hammer on weights on inside and out. I wasn't too easy with that since the others were balanced with the stick on weights inside. They redid it. Not sure it matters but I wanted it to look as clean as the others.
04-25-2017, 03:22 PM
Moderator dude
1966 26' Overlander
Phoenix
Take it to Discount Tire for free flat repair.
1
#rr-0 .review-rating__stars:after { width: 98.00000000000001%; } 45315 N DAVIS HWY
- PENSACOLA , FL 32503-2005
>>>>>>>>>>>>>Aciton
04-25-2017, 05:06 PM
2016 28' International
2015 28' International
2013 28' International
Las Vegas
, Nevada
Good idea to just replace the tire, "it is the most important safety feature that you have!" Plus a tire is a lot less expensive than an entire AS!
04-25-2017, 06:34 PM
Florence
, Alabama
Yeh, I hated to dismiss a practically new tire but the piece of mind outweighed the $200. We are on the first leg of a week long journey and pressures are all good.
