Old 09-11-2021, 02:48 PM   #1
Mad Scientist
2017 23' Flying Cloud
CULPEPER , Virginia
Just got new Endurance Tires
I just put 4 new Endurance tires on my 2017 FC/FB- replacing the Marathon tires AS originally put on. Should I worry more about Endurance than I did about Marathon? Tire place inflated to 80 psi-- I think that is too harsh. Any recommendations from the crowd?
TIA
samletz is offline   Reply With Quote
Old 09-11-2021, 03:02 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
TIA
This 'crowd' will have all kinds of advise.
I run 70 something cold in our GYE's, ck cold before every trip and never adjust hot.
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 09-11-2021, 03:16 PM   #3
2019 25' Flying Cloud
Hendersonville , North Carolina
TIA
I ran 60 PSI (measured when cold) in our 2017 International 23D. That is more than enough pressure to support the 4800 LBS that the trailer axles were carrying. The tongue weight was consistently around 800 LBS. Worked well. 80 PSI is not needed and just beats the heck out of the AS.
I always took a look at my tires whenever stopped for fuel. Put a hand on them to make sure nothing was running hot. Tires would gain approx. 6 PSI after running on the Xway. That is normal as the tires warm from cold pressure check.
uraljohn is offline   Reply With Quote
Old 09-11-2021, 05:02 PM   #4
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
No recommendation but I run the GYE tires at 65 psi on my 27' GT.
And, for what it is worth, I attended the Michelin seminar on tires and they mentioned the the GYE is a good tire.
Old 09-11-2021, 07:10 PM   #5
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
I run 60 psi in my GYE's on my 2018, 28 FC.
StuartsDad is offline   Reply With Quote
Old 09-11-2021, 07:13 PM   #6
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I run 65 and Iíve got a 30í. 55-60 on a 23Ö..
wulfraat is online now   Reply With Quote
Old 09-11-2021, 08:17 PM   #7
2015 25' Flying Cloud
Tucson , Arizona
The Endurance is a WAY better tire than the Marathon. We run the Endurance at 65PSI on our 25FB.
McStreamy_ is offline   Reply With Quote
Old 09-11-2021, 08:22 PM   #8
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
I run 60 in my FC26
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 09-12-2021, 09:08 AM   #9
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
We run at 65lb in our international 25 (6800lb loaded) great tire...
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 09-12-2021, 09:17 AM   #10
2019 27' Flying Cloud
Yorba Linda , California
I went to the tire manufactuers tire inflation chart. It showes weight/pressure numbers.
I added 5 lbs to feel better and have no issues, before bringing them down from 80 the screws would come loose.
soling917 is offline   Reply With Quote
Old 09-12-2021, 09:39 AM   #11
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Check out Goodyear's inflation recommendations in this table for your tire size and trailer weight (you will notice that 80 psi is way above the recommended pressure for your trailer):
https://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
2016 International Signature CCD (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 09-12-2021, 09:55 AM   #12
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I believe it states on the sidewall 80 is for max load. I normally run my 25 ft FC at 70
urnmor is offline   Reply With Quote
Old 09-12-2021, 10:43 AM   #13
2018 23' International
Pensacola , FL
I have an auto shop and we always rely on the factory rated pressure which most of the time is in the doorjamb and behind the fuel cap cover. The airstream has a rated label as well. I have paid very close attention to all the comments since 2018 when I purchased a 23FB but never heard this much discussion about the lower pressures. Does anyone know if the factory stated pressure is the correct rating for the trailer or is the tire manufacturers recommendation the correct PSI? Thx
Joseph Sessa is offline   Reply With Quote
Old 09-12-2021, 10:47 AM   #14
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
Talking
On my second set Endurance with my 28FC. No issues. Run mine at 58-60 psi cold. No popped rivets nor broken hinges/latches any more. GY said no impact on wear/mileage difference. Do not recommend running 80psi Max pressure on any trailer tire! Many posts on this, but you can't tell some people that max is hard on tires and trailwrs.....they just don't understand that max, means "max"..
2017 28' Twin Flying Cloud
Old 09-12-2021, 11:34 AM   #15
2017 25' International
West Lake Hills , Texas
Iíve been trying to confirm max PSI of my circa 2017 410840 wheels/rims. A document on airstreamclub.org shows them to be rated for 65 PSI max.
Fungus is offline   Reply With Quote
Old 09-12-2021, 11:45 AM   #16
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
If you owned a 35' with a slide out: GVW @ 11,500# and TW @ 1,400# you would see that 75-80 PSI would be needed. Airstream recommends 80 PSI. To be correct, you need to weight each tire load individually and inflate according to the tire manufacture's recommendation. What happens when a road high point, bump or hole, causes one or more tires to be severely under inflated for the temporary load? That is a good reason to add some padding to the pressures for a safety margin. One size does not fit all. If all your tires run cool at the same temperature and the tread wear is even you are doing it right. A hot tire, or uneven wear, i.e., outside edges wear= under-inflated and center wear= over-inflated, there is trouble ahead.
guskmg
Old 09-12-2021, 11:58 AM   #17
Houston , Texas
Except my Airstream placard also says 80 psi. So, its more than just a max thing.
DCPAS is offline   Reply With Quote
Old 09-12-2021, 12:15 PM   #18
2018 27' Flying Cloud
Delray Beach , Florida
TIA
IMO weigh your TT, then look at this chart https://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
That said, your weight may change from time to time, so you will want to adjust accordingly.
Lew
2018 27' Flying Cloud 2018
Ram 2500 Cummins, ProPride
#4636 FL/NC
South Florida Airstream Club #30
time2travel is offline   Reply With Quote
Old 09-12-2021, 12:18 PM   #19
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera , Texas
I average this cold as well.
banderabob is offline   Reply With Quote
Old 09-12-2021, 01:03 PM   #20
Boy I'm rong again...🥲
I've never changed psi because of load in the Airstream.
The most that the Airstream weight has changed has been around 300 to 400 pounds, which did require a change in the weight distribution settings but not the tire pressure.
Now ambient temperature that's a different story.
But remember better to have too much pressure than not enough!!!
Done
Tahawus
RLC
SOLD: Brand new 15 wheels Goodyear Endurance Tires - Pennsylvania Tin Bin Airstream Classifieds 0 06-15-2021 06:21 PM
Goodyear Endurance ST Tires Made in USA subfan1 Tires 245 05-06-2019 05:26 AM
Metal Valve Stem on Endurance Tires AVS Tires 31 03-27-2018 11:40 PM
Tires for single axels Marathons v Endurance Msherw 2005 and newer - Bambi all models 8 11-07-2017 12:03 PM
