05-31-2020, 11:34 AM
#21
2018 16' Sport
St. Louis
, Missouri
Fred, thanks for sharing the comments from tire rack. The pictures look very similar to mine. Seems like nothing to worry about.
Thanks again
05-31-2020, 11:39 AM
#22
Sag Harbor
, New York
Thanks for the update. You might want to give your mechanic some feedback IMO.
Great link, Fred, thanks.
Peter
Originally Posted by Sport 16 STL
. . . mechanic, non airstream, said there are bulges on the sidewalks.
05-31-2020, 11:42 AM
#23
Ravenna
, Ohio
Originally Posted by ROBERT CROSS
Have any photos?
These are normal,15k SFSG....
Bulge (out) is not the same as depression (in)
I believe the right tire is a depression left tire not as easy to see.
Try laying straight edge across to confirm in IN or Out.
Out should be replaced IMO
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
05-31-2020, 11:46 AM
#24
Ravenna
, Ohio
I have two posts on my blog about Bulges (out) along with tire Autopsy showing the real reason for the bulge.
05-31-2020, 03:31 PM
#25
Mike from Canmore
2018 27' Flying Cloud
Calgary
, Alberta
Originally Posted by n2916s
All of mine have “dimples” where, I assume” the belts meet. Totally normal.
Roll it by a tire shop...
Ditto. When the sun is just grazing the sidewalls, I see some unevenness on mine as well. Unless they are big, obvious bulges, I expect they are OK.
05-31-2020, 04:19 PM
#26
Sag Harbor
, New York
06-01-2020, 04:50 AM
#27
CapriRacer
I'm in the
, US
And just to be a bit pedantic:
It isn't the belt overlap that you are seeing - It's the PLY overlap. The belts are only under the tread.
CapriRacer
Want to learn about tires? Please visit my website: Barry's Tire Tech New content every month!
06-01-2020, 06:59 AM
#28
Oswego
Sorry, brain fart.
-Rich-
06-01-2020, 07:10 AM
#29
2013 25' Flying Cloud
Crystal River
Sometimes pedantic is a good thing.
“While you live, shine / Have no grief at all / Life exists only for a short while / And time demands its toll.”
06-02-2020, 07:53 AM
#30
Ravenna
, Ohio
Gee Barry, You going all technical on us?
Next thing you know we will be talking about Flippers, Wedges, Fillers, Squeegees, skims and dip.
06-02-2020, 09:05 AM
#31
2009 34' Panamerica
2005 28' Classic
Still
, in the thick of it
I just picked up some Endurance LR E tires this past weekend and mounted them.
Looking at the outgoing Maxxis LR E tires, these seem like they have slightly less tread on them also compared to a spare I had that was still a Marathon, but honestly, last tires (Maxxis) I had on the rig for 7 years.
Maybe some of it is luck, maybe care, but I do keep my tires covered when outside and not rolling. I put armor all on the sides and I keep inflated to proper levels. I have the rims balanced and run centramatics on each hub.
Outgoing tires had about 15-18k on them. One note was that one of the curbside shock mounts was slightly bent and rubbing on the frame. I was a bit perplexed how that could have happened to just one mount, but not related to tires....will keep an eye on it.
One last thing I wanted to say was thanks a bunch for all these great posts on tires. I particularly want to thank tireman for all his great insights. Many of the points made here I have adopted over the years and I attribute as part of the reason why I haven't had to replace a blown tire (yet).
06-03-2020, 08:10 AM
#32
Ravenna
, Ohio
Thanks, but don't forget CapriRacer, the other tire engineer who keeps me honest so I don't drag everyone down the rabbit hold of Engineer Speak and technical minutia. He has a nice web site while I have a Blog. We each took a different approach to trying to help the RV community, but if you look you will see that the two sites compliment each other
06-03-2020, 09:13 AM
#33
2007 30' Classic S/O
Somewhere
, South Carolina
Tip of the cap to Tireman9 and Capriracer for their behind the plies info.
I read their posts.
06-03-2020, 11:01 AM
#34
2007 23' Safari SE
ROSWELL
, Georgia
15K+ on a set of 15” Endurance.Thank god I made it through 2 sets of Marathons,before the Endurance came out.All tires have bulges to some extent.I bought Endurance to get a ‘D’ rated tire that I could buy at Sams’s where ever I travel.I just don’t trust the chinese tires.
Mike & Nancy Gore WBCCI #2914 S E Camping Unit 012 Roswell,Ga.
06-03-2020, 11:23 AM
#35
2017 25' Flying Cloud
Ann arbor
, Michigan
I called Goodyear about this very issue. It is normal.
06-03-2020, 12:13 PM
#36
2019 25' Flying Cloud
Houston
I also want to thank Tireman9 and Capriracer. Both of you have been extremely helpful. Mind you, I still feel a little uncomfortable having my tires at 80 psi, but I am doing it.
06-04-2020, 04:33 AM
#37
CapriRacer
I'm in the
, US
So how go you feel about the Space Shuttle's tires being inflated to 340 psi?
CapriRacer
06-04-2020, 06:42 AM
#38
Houston
165,000 pounds empty vs. 5,900 empty. Pretending for laughs that the tire pressure difference was linear, and ignoring the landing impact load, then I calculate that my tire pressure should be 12.16 psi. Although i guess that would have to be 100% nitrogen.
06-05-2020, 12:34 PM
#39
Ravenna
, Ohio
4 main landing gear tires 44.5x16.0-21, 34 ply, 263 mph
2 nose landing gear tires 32x8.8, 20 ply, 250 mph
But you forget the mileage is probably under 5 miles with the mains only used once.
Could do the math but you probably do not want to pay $thousands for 5 mile use
06-05-2020, 02:34 PM
#40
Somewhere
, South Carolina
Tireman9,
Who made the shuttle tires?
About how thick is the tire tread?
Gary
