06-10-2022, 03:45 PM
#41
1994 25' Excella
Waukesha
, Wisconsin
Interesting to note that the Goodyear Endurance tires carry a higher weight load rating that the Michelin tires being discussed here.
GY Endurance: 3640
Michelin: 3042
Richard
11018
06-10-2022, 04:24 PM
#42
2022 28' Pottery Barn
¯\_(ツ)_/¯
Do you think that someone pulling an Airstream is going to have a problem with 12,168 pounds of tire load rating for 2 axles and 4 tires at the rear of the trailer?
Same thing for 6084 pounds of tire load rating for one axle and two tires at the rear of the trailer?
06-10-2022, 06:39 PM
#43
1994 25' Excella
Waukesha
, Wisconsin
No, I don't. Just pointing out that the Michelin tires don't have as much headroom as other options.
Richard
11018
06-10-2022, 08:24 PM
#44
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
And yet Airstream uses and specifies LT tires (they use Michelin) over ST tires on higher end models. So my choice of using a LT tire over an ST is the same as used and specified by Airstream. I guess I am in good company for a reason.
2022 25RBT FC, 50A Dual AC, Awning Package, 270W Solar, Convection Microwave. Ceramic Coat, Grand Lounge, 3" Lift, 16" Michelin RIBs, Multiplus II, Battleborn 400A, MPPT 100/50, Orion-TR 30, EasyStart (2), Easy Touch, AirKrafters jenRack, Onan 2500i, Truma Aquago Confort, Starlink, Pepwave, Parsec
06-10-2022, 08:42 PM
#45
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
TETO....Now let's talk about Hitches & batteries.
06-10-2022, 10:08 PM
#46
2015 30' FB FC Bunk
Golden
1/2 ton verses 3/4 ton.
06-11-2022, 05:12 AM
#47
1994 25' Excella
Waukesha
, Wisconsin
How many models actually have LT tires spec'd on the label?
What was the reason this was done? Does anyone know from Airstream why they went with LT tires over another option?
Richard
11018
06-15-2022, 09:13 AM
#48
Ravenna
, Ohio
The factory tires supplied are just junk as far as I am concerned and I have replaced three brand new sets as soon as delivered. Our new 2022 FB 25' tires had deformities in the side walls on all the tires but the spare was really bad. The shiny spot captured in the picture was at least an 1/8" bulge off the surface. Very noticeable. I assume they mount the worst ones on the spare, at least this was the obvious case with mine. I normally just replace them with Michelin or on the 2015 30' I went with Nokians. On the 2022 I upgraded to 16" and went with Michelin XPS RIBs running at about 50psi. What a super quality tire that is towing very nicely.
In the attached picture you can see the prominent bulge and sidewall deformity at the tread. The picture really does not show it as bad as it was. They are just $25 each tires on a $100,000 trailer. Ok, maybe $35 at the most.
If there is a "Bulge" outward, the tire should be replaced. If new the dealer should :adjust: it and replace fro free. If it is a depression then it is not abnormal but the location of body ply overlap. Nothing wrong with such a tire. Depressions (one or more) are almost always found with close inspection, no matter the brand.
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
06-15-2022, 09:17 AM
#49
Ravenna
, Ohio
LT tires have a lower load capacity than do ST type tires of identical size and Load Range. This is not a function of Michelin vs GY vs Bridgestone.
ST tires are supposedly rated for higher load capacity as the load formula is based on a lower operation speed with 65 mph stated in the Tire & Rim Association design manual.
"Speed Rating" Symbol is actually a rating of handling capability with higher symbol tires usually deliver crisper handling and steering response.
06-15-2022, 09:19 AM
#50
Ravenna
, Ohio
GY Endurance: 3640
Michelin: 3042
You may have missed the "Type" tire difference. ST vs LT.
06-15-2022, 09:32 AM
#51
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Not a safety issue nor a defect that will cause any problems, IMHO. Those Endurance ST's are great tires...and, as others pointed out, it is not uncommon to see in Michelin LT tires as well...I wouldn't worry so much about the looks...those GYE tires are doing very well over past 6 years!
06-15-2022, 10:03 AM
#52
2021 25' Flying Cloud
Chandler
Endurance
This may not be entirely relevant, but my experience with the GY Endurance was nightmarish. With less than 10,000 miles on them, I had blow-outs on the Endurance tires that came on my truck. Granted, these were on my truck and had used the truck to pull my fifth wheel trailer. On one blow-out, I was pulling the fifth wheel and on the second blow-out, I was not pulling anything. Each time, the blow-outs resulted in over $11,000 damage to the truck. (Thank God for good insurance.) Like I said, this may not be relevant, but I drive on Michelins now.
06-15-2022, 10:20 AM
#53
2022 28' Flying Cloud
GAINESVILLE
, GA
We were concerned about the Goodyear Endurance tires until we started reading TireRack reviews, where they get very high ratings.
I think with the TST package, driving at/under 65 mph, we are in good shape.
By the way: a friend of ours, who owns an SOB, told us “if you are an AS owner or want-to-be, your in a cult.”
06-15-2022, 10:21 AM
#54
2022 20' Caravel
Southeastern
, Pennsylvania
...but it could give you a bit more flexibility on more comfortable/less jarring tire pressures at the higher end of the load scale.
06-15-2022, 10:22 AM
#55
, Texas & Wyoming
Very odd since GYE are a 10 ply special tire not intended for use on motor vehicles. Best-suited for: Travel trailers, pop-up campers, boat trailers, toy haulers and fifth wheels.
06-15-2022, 10:43 AM
#56
Home of Vortex tuning
2013 27' FB Eddie Bauer
Spearfish
, South Dakota
Very happy with the stock tires on my '13 EB, held air pressure, no issues, but the weather checking around the bead. It didn't bounce much either, stuff stayed in place while traveling, ran 5# less than max. Almost new as to tread wear.
All got replaced in May this year with the Michelin Agilis cross climates
"Chip Tank" is in Westwood Ca.
06-15-2022, 10:57 AM
#57
1986 31' Sovereign
Miami
Endurance are ST (Special Trailer) tires. Why did you have them on your truck?
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
06-15-2022, 11:43 AM
#58
¯\_(ツ)_/¯
@Tireman9-
In your opinion, do you think running a Michelin Agilis LT CrossClimate 121R (or other appropriate rating for your trailer) at the appropriate size, on 16” wheels and inflated properly is a better, worse or no difference decision over the same scenario with a Goodyear Endurance ST tire?
06-15-2022, 12:18 PM
#59
2007 30' Classic S/O
Somewhere
, South Carolina
WellSaid11,
Not an answer to your query but a bit of the way it was a few yrs ago. And just an overview.
There was thread after thread about problems with the GYM. I found a belt seperation on my then about 3 yr old GYM's while in camp and removed three wheels in camp and got new GYM's thinking end of a close story. But after that one of my new GYM tires had a sidewall bulge (not indentation) shortly after installation on my 2007 Classic Ltd 30' Slide Out with a 7940 Lb UBW 10,300 Lb GVWR yes possibly the heaviest tandem axle rig AS made.
My tire shop offered to replace the GYM's and I chose MAXXIS and had several years service out of them.
The GYM failure threads just kept coming. The MAXXIS looked a bit like R&R time and no suitable replacement was in the market.
But many here I believe were just fed up with the potential ticking time bomb status and I followed the lead of several early adopters of the Michelin LT tires and I felt it was a better choice to use a tire with a darn good reputation and my personal experiences included to use a quality tire even though it meant changing from 15's to 16's added to the price.
The GYM "reputation" left a bitter taste in many owners mouths and it was years before a new and improved GYE entered the market and then several years more before the GYE started to get good owner reviews.
It was not a July end of GYM's and in August new GYE's appeared it was years.
I'm on my 2nd set of Michelins on the 30' these are the Agilis and I'm satisfied and have not had one issue with either of the two sets of Michelins I've used on it. PSI and temp are monitored via a Dill internal TPMS system. And personally seeing the same LT tire in the lobby at JC as you walked in left quite an impression.
Gary
06-15-2022, 12:40 PM
#60
2019 27' Globetrotter
East Hills
, New York
I noticed a problem after about 10K miles. I learned that it wasn't a problem.
WHAT ARE SIDEWALL INDENTATIONS, UNDULATIONS & PROTRUSIONS?
https://m.tirerack.com/tires/tiretec....jsp?techid=32
