Old 07-18-2021, 06:18 AM   #1
Peter417's Avatar
1966 17' Caravel
1972 21' Globetrotter
SW , Missouri
Dot 00b 38tb3u
Can some help me date these?
DOT 00B 38TB3U
There is no other 4 digit numbers.
Peter417 is offline   Reply With Quote
Old 07-18-2021, 02:29 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The four digit tire date coding started in 2000. Prior to that there was a code however it was a 3 digit code.
Action
Old 07-19-2021, 12:05 PM   #3
Peter417's Avatar
1966 17' Caravel
SW , Missouri
Action
Are you saying these tires are older than 2000? they were purchased about 4 years ago by the PO. Walmart brand tire I believe.
NWA MTB
Old 07-19-2021, 12:08 PM   #4
Sag Harbor , New York
https://www.tirerack.com/tires/tiret....jsp?techid=11
"Tires Manufactured Since 2000
Since 2000, the week and year the tire was produced has been provided by the last four digits of the Tire Identification Number with the 2 digits being used to identify the week immediately preceding the 2 digits used to identify the year."
Peter
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
Old 07-19-2021, 01:22 PM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you take a look at the link listed above, it mentions that they only need to put the full number on *one* sidewall. They can put an abbreviated number on the other sidewall. Sounds like the tires got mounted "wrong side out".
Old 07-19-2021, 01:30 PM   #6
Mollysdad's Avatar
Hi
Agree. The date code might only show on the inside.
Old 07-19-2021, 02:16 PM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I am not saying anything about your tires.
I am stating the tire date coding rules.
You have not posted a 4 numeric coding.
The tire will have it as it is a requirement
Action
Old 07-19-2021, 03:21 PM   #8
Peter417's Avatar
1966 17' Caravel
SW , Missouri
As it turns out there was a 4 digit code, but only on the inside of the tire.
NWA MTB
Old 07-19-2021, 06:18 PM   #9
Question
If everyone would simply go back to the source document in the Tire Rack link in Post #4, it might be easier and require less guessing, speculation, and confusion?
"While the entire Tire Identification Number is required to be branded onto one sidewall of every tire, current regulations also require that DOT and the first digits of the Tire Identification Number must also be branded onto the opposite sidewall. Therefore, it is possible to see a Tire Identification Number that appears incomplete and requires looking at the tire's other sidewall to find the entire Tire Identification Number."
. . . but maybe I have misunderstood the purpose here?
DOT banned shiny Airstreams? rock60 Off Topic Forum 8 10-03-2006 05:18 PM
Tire age and the DOT SafeHarbor Tires 3 08-27-2006 05:35 PM
www.nhtsa.dot.gov cynthia Off Topic Forum 0 08-06-2005 05:36 PM
dot eu Over59 Forum Admin, News and Member Account Info 4 01-12-2005 07:11 PM
dot no for windshield glass wb13798 Mechanics Corner - Engines, Transmission & More... 7 01-22-2004 07:42 PM
