Originally Posted by Creampuff
Ceramic balancing beads! Same as Centramatics but they go inside the tire and are way cheaper! Recommended for 15"AS tire sizes is 3 oz. per tire and can be inserted through the valve stems. I've used them before on my vintage '57 AS as well as my '16 25' Int. Signature.
A perfectly balanced tire on an imperfectly balanced running gear doesn't stop trailer destruction- beads do!
If you wonder whether your rig is/ isn't shaking, check the refer door bins to see if you have beverage can rash on the plastics!
There's an old thread discussing use of beads. What's good enough for big-rigs logging millions of miles is good enough for me!
I use golf balls just like the 'big rigs'.......
NOT.
NOTHING goes inside the tires.
I road force & use Centramatics
Couple hundred bucks for permanent POM...is well worth it IMHO.
