09-11-2009, 06:41 PM
2004 25' Classic
Prescott
Continental Vanco 2 225 / 70R15C tires
Here is another tire to consider if you are getting upset with the trailer tires that are out there. I have installed these on mine. They look good and from what I have researched, should do the job without having to go to 16" wheels. They are a commercial D rated tire with a max. load of 2470 lbs. @ 65 psi. and a speed rating of 106 mph.
Oh, I have NO connections with Continental in any way
09-11-2009, 06:48 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Your post says your new tires 225/70's. Does the lower diameter tire diameter affect the stance of your trailer? I'd love to see a picture of your trailer with the smaller tires on it.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
09-11-2009, 07:52 PM
2004 25' Classic
Prescott
Hey Brian, it does sit about 1/2 " lower. The Marathon's diameter is 28.3" and the Vanco 2 are 27.4 " A will get a photo up later.
09-11-2009, 08:07 PM
St. Catharines
, South Western Ontario
09-12-2009, 02:09 PM
2004 25' Classic
Prescott
Brian, not sure what type of photo you are after, up close or what. So here are 2 shots.
09-12-2009, 04:34 PM
, At Large
Interesting. How close are the sides of the tires to the insides of the wheelwells? >Lower aspect ratio means wider tire.<
09-12-2009, 04:53 PM
1993 34' Excella
Estancia
Are the Vancos ST or LT tires?
09-12-2009, 05:15 PM
2004 25' Classic
Prescott
The Vancos are a commercial mini bus van tire. They are defiantly not an ST tire, and I do not think they are rated as an LT tire either.
I just got back from a 22 day trip stopping at 4 campsites and covering about 1,200 miles with these tires. I stay at about 72 to 76 mph on the interstate. Got into some interstate construction areas that really bounced the Airstream around with no markings or rub marks on the wheel wells. It did bounce everything we had on the rear bed off! LOL
I would say there is about 1"- 1.25" of room in the inside and about 1.5" outside.
09-12-2009, 05:29 PM
1993 34' Excella
Estancia
I thought the only tires that were recommended for Airstreams or for trailers in general were ST or LT tires?
09-12-2009, 08:14 PM
2004 25' Classic
Prescott
Good question! I'm gonna go out on a limb here and say the Vanco tire is like an LT tire since it has both the index load rating and a D load rating JMHO! I do know from the highway towing I've done with them on that there is no difference on how the trailer tracks in comparison to when the Marathon tires were on. If anything, it tracks better. Hopefully someone with more knowledge about tires will chime in about this.
11-21-2009, 08:08 AM
2007 27' International CCD FB
Everett
In order to bring this thread back to life....are there any more actual applications from the readers who may be using the Continental Vanco 2 tires. I have to replace my Goodyear OEM tires after a blowout. I had about 12K miles on the tires and wish not to repeat that experience!!! However, the list of replacements are indeed short and quality of all is questionable. These tires are new to my list and are priced in the same ballpark has Goodyear.
Air # 20467
WBCCI #4018
Just call us Jean & Bill :-)
11-21-2009, 09:22 AM
1994 21' Sovereign
Tucson
Made in ????
Where are these tires manufactured? There should be two letters in the DOT code on the side of the tire that indicate the location.
I bought a set of Carlisle tires that were supposed to have been made in the good ol' USA, but the DOT code revealed that they were from the other side of the Earth.
The required "Made in China" marking was placed on the part of the tire that is covered by the rim when mounted!
11-21-2009, 09:51 AM
2004 25' Classic
Prescott
Tires come from Germany
11-21-2009, 11:52 AM
_
Originally Posted by HankandLois
...are there any more actual applications from the readers who may be using the Continental Vanco 2 tires...
hi hank
it appears this is a passenger van tire (car like ride with EXTRA load and tread life)
it is interesting that there is only 1 review on the tr site, i've never seen JUST 1 review there on a tire.
Continental Vanco 2
vanco is a class/style with 5-6 models to choose from.
Contis
and here's the conti stuff...
Continental Tires - Continental launches the Vanco 2:
so it appears this model is similar in application and design to the mich' x or lt series for vans.
good luck choosing!
cheers
2air'
06-19-2012, 10:10 AM
2007 25' Safari FB SE
Alamo
Bob,
Since you have had the Vanco's now for several years now you comment on how they hold air, mileage towed, tread wear, etc.
TKNELLE
Alamo, CA
06-20-2012, 02:55 PM
2004 25' Classic
Prescott
Our last trip was in April. At that time the trailer had been dorment for about 3 months, sitting up on jacks. The tire pressure was still at 62 psi, which is what I keep them at. Tire wear in not noticable, they still look new, with only about 16,000 miles on them. I am getting ready to pull them off in the next few weeks to change out the brake assemblys. Will take a good look at them when off the trailer.
Julia & Bob
W/ Deedee & Boo
AIR #30685
08-09-2012, 07:31 AM
2005 25' International CCD
Lilburn
From what I read on TireRack these are summer tires not intended to be used in freezing or near freezing weather. Is this new info, or does it not apply to a trailer use? I am in Georgia and it does freeze sometimes.
08-09-2012, 08:10 AM
Lilburn
I also found Goodyear makes a similar tire. That, according to the reviews on TireRack, is being happily used by an Airstreamer. Still wondering about the summer tire thing though.
08-10-2012, 07:02 AM
2004 25' Classic
Prescott
You can do a search and get all kinds of info on what you are asking. The jest of it all from what I understand is the summer tires are great for just about everything except snow and ice. I was up at Red Top Mountain State Park 2 yrs. ago at the end of the year. Got caught in a nice snow storm and was on the road with it coming down. Had no problem since no snow was sticking to the road. Now if you plan on driving in the snow a whole bunch, I would switch out both TV and trailer with winter tires. Only reason would be for the stopping and accelerating capability of them. Here is one article on it:
Tire Test: All-Season vs. Snow vs. Summer - Edmunds.com
Julia & Bob
W/ Deedee & Boo
AIR #30685
09-16-2012, 05:09 PM
2015 30' Flying Cloud
Ventura
Trailer Tires
