Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 10-21-2021, 08:55 AM   #1
Ray Eklund's Avatar
2019 27' International
2014 25' International
Fort Saunders , Wyoming
Compact Tire Inflator: Milwaukee 2475-21XC M12 4Ah
Taking the Airstream to have tires brought up to pressure... is a PIA. The tow vehicle not so much, if you know where to go. 80PSI on the door. Cold psi...
Part of the problem with heavy Tow Vehicles are the tire pressures. Some tire facilities run a lot of air driven equipment. Their system may be 100psi or a bit more. When a lot of work is going on, you are lucky to get a tire to 80psi. Even 70 psi. (This is what I had explained to me. I provide Hot Air, but not PSI in tires.)
Thought... I would buy a large compressor and have it at home to top off PSI and check tires before leaving on a Camping Trip. Pros and Cons for those.
Found 'Compact Tire Inflator'. This one cost a bit more as it has a Lithium Battery. Comes with the battery and charger. Also some other attachments for other uses.
List price was $199.00 and with 'Friends & Family Event' discount, for what reason I was not arguing... price ended up at $169.15 with Sales Tax, no shipping costs. An Airstream Dealer was using this to inflate tires... I thought... yeah right.
Well, it did. If you want 70psi, set it at 72psi and take your Pressure Gauge and check. Got 69.5 to 70psi. Great.
It is rated to 120PSI. You figure that out. I am content it does the job I needed it for.
The Tire Pressure Gauge you use will be more accurate, I believe than the shutoff on this unit. As you get into higher PSI, the error subtracts 2 or 3 psi. I use my Pressure Gauge Accu-Brite by DuraPRO that Nancy bought at Costco for... herself. My Sears gauge was too awkward... so I... did a swap. I know. Bad, but I do things like this as I am a Neanderthal.
With the Lithium battery option it costs a bit more. But... you charge the Battery... and can use it on the road when needed. It is not that large... which surprised me it works at all.
These large tires on the F350 and the 16 inch Michelins take a lot of Air to get the PSI up... but if I am pleased, which I am the worst critic of anything that does not work as described.
In your garage to add air... COLD PSI. Hot tires at a Service Station... they will let air out as the pressure is UP. So this is a good point to know. The next morning you discover Cold PSI is now below what you wanted... and then... Repeat? Ha ha ha.
Just check it out on the Internet. Nancy wrote $183.32 and order total said $169.15 with estimated tax.
Not cheap... but I am old, really need to spend some money before it is used for campfire starter... and really... don't give a S*%&T when something works.
Once you drive off the Airstream Dealer's Lot... just open your wallet and toss it out the window. You are going for a ride where Tossing Money Out of the Window and a Tire 'Inflator' is one of those toys that seem to work... A miracle if it will over many years.
Made $2.85 playing three hand Video Poker at the Casino yesterday. A free beer. We are in Desert Country now. Bye bye snow, wind and frost bite... Sunshine and Free Beer? We will see what this Free Beer is going to cost... today.
Free Air? We can debate that, but convenient.
ID:	406700   Click image for larger version
Human Bean
Ray Eklund is offline   Reply With Quote
Old 10-21-2021, 09:17 AM   #2
ITSNO60's Avatar
Tucson , AZ
Ray, did you get it at Home Depot or Amazon, or? I am seeing prices higher than what you paid, but there are different amp hour batteries available as well, how many AH is yours? This might be an option for me as I need small and light weight
Brian
ITSNO60 is online now   Reply With Quote
Old 10-21-2021, 09:22 AM   #3
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
I have the Porter Cable cannister type at home; I used to carry in the bed of the PU. I got tired of moving it around, so I got the Vlair 300 model last year, while on sale...think it cost around $165 or so... I have used it 4 times now and it works great. Smaller, easily clips to the battery, has long hose with gauge so I can easily go around both sides with just the hose. I also got the tire/plug kit which came in handy last year while up in the mountains on a dirt road when I hit a screw and got a flat. Here is the place I got the best deal last year...but Amazon also carries. https://www.viaircorp.com/rvs-portables/300p-rvs
2017 28' Twin Flying Cloud
Old 10-21-2021, 09:35 AM   #4
2021 27' Globetrotter
Daytona Beach , Florida
I use a Milwaukee M12 and a Viair 450.
Both work great. The Milwaukee is really nice for small adjustments , like on a sxs or mountain bike, but will also air up truck tires. I use them both a-lot.
nitzo is offline   Reply With Quote
Old 10-21-2021, 10:19 AM   #5
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
I have one of these and consider it indispensable. What a great little tool! It weighs very little and takes up a small space. I carry it in whichever vehicle I am driving. You just need to make sure you check the battery on a regular basis (quarterly?). It holds a charge a long time, but you don't want it to fail you when you need it. It's also great for airing up your spare tire when you do your battery checks (hint hint)...
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 10-21-2021, 11:04 AM   #6
Cedar Hill , Texas
Slime X Heavy Duty, $75.00 (Amazon)- compact and works great.
fthopkins is offline   Reply With Quote
Old 10-21-2021, 11:20 AM   #7
InvertdEagle's Avatar
2022 33' Classic
Manassas , Virginia
I've been using this for years:
https://bestrestproducts.com/product...tire-inflator/
It was originally designed for BMW motorcycles - and that's why I bought it back in the day. Over time folks have used them for way more than just Beemers. They were commissioned by guys overseas in the sandbox to fill up their Humvee tires (which are astonishingly large). BestRest products send quite a few to Iraq & Afghanistan for just that purpose.
I like it because it's small, lightweight, 12V battery powered, and has the capacity to fill tires up to the inflation pressures required for my trailer (80 PSI). They aren't inexpensive, but they're all US manufactured and appears to be very well made. I have 3 of them (1 in the bike, one in the truck, one in the trailer).
InvertdEagle is offline   Reply With Quote
Old 10-21-2021, 11:50 AM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I am on a long trip and needed to inflate. Looked at the 18 volt models. Bought a Kobalt inflator at Lowes. 110 and 12 volt. Used it on 110. It works good. I did not want to commit my drill batteries to inflation. I just do not boondocks that much and my tires seem to stay inflated pretty well.
Old 10-21-2021, 12:11 PM   #9
Maxine-A
2019 25' International
Tacoma , Washington
Dewalt Tire Inflator - 20V - 0-150 PSI + Vacume
I had purchased the DeWalt Max cordless Vacume Kit for my AS and when searching for a portable inflator settled on the DeWalt also. The Vacume kit came with one battery and charger and I use it to power both. Very accurate inflator, the Vac is perfect for truck & AS and they both are easy to stow, and also light weight.
Maxine-A is offline   Reply With Quote
Old 10-21-2021, 12:20 PM   #10
Ray Eklund's Avatar
CPO Milwaukee
There are a lot of Tire Inflators out there. Some members are adding other options, which is good and prices with theirs, so lots of satisfied customers are the BEST to choose from.
CPO Milwaukee: was a supplier on the manufacturer's list.
Milwaukee 2475-21XC MM12 Compact Inflator Kit (4Ah) $199
Friends & Family Event- Take 15% off orders of $129 or more: -$29.85
Came to $169.15 plus Sales Tax to total of: $183.32 Shipping included.
I watched the Airstream Dealer using it. The NON Lithium battery model is less expensive. I figured get the Lithium and will forget what I paid extra, anyways. It had double the charge of the less expensive option.
Prices may vary. Nancy is a sharp shopper. Ordered on October 15 and arrived October 19th. Charged battery and did Eight Tires and put Battery into Charger and it quickly was 100%.
Top of page says: Take 10% off orders over $129+ (log in for 15%) Use code CPOFRIEND
Had 33 reviews. When they work probably no review. When they don't... everyone would be commenting... is how I felt.
You select the pressure you want, connect and push a button. When it gets to that pressure selected... it shuts down by itself. Neanderthals like that...
Human Bean
Old 10-21-2021, 02:16 PM   #11
ITSNO60's Avatar
Tucson , AZ
You got a good deal and they are now out of stock on everything except the 2AH version. I may look for the bare tool as I have a lot of M12 lithium stuff, 5 chargers and about a dozen batteries. 2 of my big batteries are 32 WH which converts to 2.67AH and one is 43 WH which converts to 3.58 AH (Milwaukee rounded up and labeled it as 4AH) and all the rest are the little 1.5AH ones.
This could come in very handy especially that counting all our vehicles and bicycles I am in charge of 35 tires! The bikes are the worst, the ones with skinny tires need air all the time.
Thanks for helping me spend my money
Brian
Old 10-21-2021, 02:32 PM   #12
Olive Branch , Mississippi
I prefer a 12 volt extension to run my air compressor from my vehicle battery. Rechargeable batteries on devices start going bad after a couple of years and won't hold a full charge.
swillis is offline   Reply With Quote
Old 10-21-2021, 02:34 PM   #13
ITSNO60's Avatar
Tucson , AZ
I found the bare tool at Plumbersstock for $79, free shipping, no tax and $1.58 shipping & theft insurance. Available for shipping from Utah in 1 to 2 weeks. Probably sitting in one of the container ships off LA right now. Everywhere I look the reviews are great for this item which is rare for any product anymore.
Brian
Old 10-21-2021, 03:12 PM   #14
ITSNO60's Avatar
Tucson , AZ
I do prefer Makita tools as experience in my contracting business shows them to hold up better but the Makita unit got poor reviews and does not have a trigger hold which is somewhat of a deal killer, I can't be crouching down inflating tires with mosquitoes biting me.
Brian
Old 10-21-2021, 03:42 PM   #15
jcl
Vancouver , British Columbia
I have used the Ryobi 18V inflator for several years. Mine has an analog pressure gauge, but it looks like they have now gone digital. 150 psi, so it handles 110 psi in our road bike tires. I upgraded to a 4 Ah battery, and it lasts well.
jcl is offline   Reply With Quote
Old 10-21-2021, 04:40 PM   #16
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
Plumbersstock also has one with a 4ah battery for $179 which is the $79 for the bare tool and HomeDepot has the 4ah batteries at $99ea.
88Limited is offline   Reply With Quote
Old 10-21-2021, 05:38 PM   #17
Ray Eklund's Avatar
Set at 72psi: 71, 70, 71, 70.5 psi tire check
ITSNOo060 Post #11 said they were sold out of the unit we purchased.
It did say 1 was available. I thought it was a method to get people to purchase this model and they had lots of them. Well... this confirms they had ONE LEFT. I have it now.
I unpacked the unit and charged the battery. Then set it to 72psi. Attached it to each of the Airstreams four tires. Then took the tire pressure gauge that I will use to always check tire pressures.
71, 70, 71 and 70.5 psi with the pressure gauge. Set at 72psi on the Milwaukee unit.
How have others worked out and comparing to your tire pressure gauge?
I am sure there are some 'sleepers' out there... After seeing this one operating... and they were happy at Airstream Las Vegas... I am happy now having something that works.
Human Bean
Old 10-21-2021, 09:46 PM   #18
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
With a lithium powered inverter I use a Campfeld-Hausfeld portable 120v compressor.
You can plug it into at the patio outlets or the refer outlet. Charge the TV using it and a medium duty extensionn cord. Pretty handy.
guskmg
Old 10-23-2021, 10:46 AM   #19
Long time owner
2004 25' Classic
1974 25' Tradewind
1970 21' Globetrotter
1975 26' Argosy 26
Forrest City , Arkansas
I love the Milwaukee inflator. It has worked better than the Ryobi I had before and I have a lot of other Ryboi tools. The Milwaukee made such an impression that I bought one for my girlfriend. Mine travels with the Airstream.
doctorlewis is offline   Reply With Quote
Old 10-27-2021, 10:22 AM   #20
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Agreed. I bought the DW-impressive little unit and battery system works with my other DW tools.
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
TYMATE M12-3 Blue TPMS The Driver Wheels, Hubs & Bearings 0 05-13-2021 11:15 AM
Stop what you're doing right now and buy the Milwaukee M12 Rivet Tool gomotomoto General Repair Forum 27 10-13-2019 12:38 PM
Dyson Car+Boat - a compact vac for a compact rv Alex AVI Sprinter and B-van Forum 22 10-07-2018 11:00 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
