02-20-2020, 02:09 AM
Salem
, Oregon
My experience and opinion.
Hi, I have some "X" Chocks and virtually never use them. I only used them at a Rally or anywhere where I might stay in one place for close to a week. They help with some rocking of the trailer, but it's on wheels and you can't stop it from completely moving. And these will not work to keep your trailer from rolling on a hill. I can't really recommend any between the wheel chocks. I have a huge rubber truck chock that I use for parking my trailer at home.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
02-20-2020, 06:28 AM
2002 25' Safari
Dewey
We use these https://www.amazon.com/BAL-28005-Del...motive&sr=1-80
Chocks that sit on the ground do not work when you raise one side to keep level.
Richard
02-20-2020, 06:35 AM
2014 25' Flying Cloud
Cuddebackville
, New York
What Richard said.
2019 Ford Expedition Platinum
02-20-2020, 07:23 AM
1976 31' Sovereign
Oswego
Originally Posted by azflycaster
I do not agree that chockss that sit on ground no good if one side raised. I use heavy truck chocks and if raised put them other side that is not raised. They work so well that if forget to pull you have very hard time to move., most of time tow veh. tires will spin, won't move, no they will not prevent theft IMO nothing else will except take wheels off. Cost a lot less than x chocks.
02-20-2020, 08:17 AM
Tampa
I use the BAL chocks. Fewer moving parts than the X-chocks (same company). They can also be locked through a hole on the top disc. (but I never do) I originally used a cordless drill to extend them, but they move so little that the included 3/4 ratchet is just as easy.
Wow. You must have some real 'hills'. I can't imagine a trailer rolling away with the wheels locked.
Conversely, rubber wheel chocks can be a problem according to KYD. After chocking their wheels (fifth wheel) the auto-level lifted one side high enough to lift away from the chock. The unit rolled and almost bent the front jacks.
02-20-2020, 09:06 AM
2016 26' Flying Cloud
Southlake
I used x-chocks for a while, but I forgot to remove them before going on a trip and I didnt even know they were there when I pulled forward. Putting a lock on them would be the waste of a good lock.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
02-20-2020, 11:00 AM
2013 25' Flying Cloud
Crystal River
Admitted Bal X-chock user here. I've been using them for years. Quick and easy on, quick and easy off. Besides leveling pads it's all I use.
While you live, shine / Have no grief at all / Life exists only for a short while / And time demands its toll.
02-20-2020, 11:11 AM
Alamo Heights
I don't own X-chocks, but a different brand called " UltraFab" between-wheels chocks. They are adjustable for the distance between the wheels and have a handle that rotates through about 110 degrees from loose to tight (with a distinct over-center point so they don't tend to loosen until you manually release them.) I've never noticed a tendency for the trailer to roll on an incline with the chocks installed... I've been using them for about 10 years now.
I did try to move the trailer once with one of the between-wheel chocks in place and it was embarrassing... the chock didn't give, the tires on that side skipped in the gravel and it was instantly apparent that something was dragging. I don't know if X-chocks don't have enough range of tension, or if people don't install them properly but I'm confident about the UltraFab ones.
David
Zero Gravitas 2017 Flying Cloud 26U | WBCCI# 15566
02-20-2020, 11:18 AM
Alamo Heights
It seems like this scenario would have had a similar problem with between-wheel chocks, though... if you lift the wheels off the ground, it doesn't matter whether they can turn or not.
David
02-20-2020, 11:45 AM
2018 28' Flying Cloud
Chapin
, South Carolina
I use X-chocks on both sides and usually wedges on one side. Only takes seconds to install and remove. I did a bonehead move a couple of years ago that prompted me to buy the X-chocks. On a gravel site with both a side to side and front to back slope, I pulled on to two high Lego blocks to level. Put in wedge blocks on both sides, but when I raised hitch off ball, the raised side rolled rearward . The wedges slid until off the blocks until dug into gravel. Safety chains were still attached, so it could not have rolled but so far, but scared the crap out of me and DW was pissed. I feel rock solid with the X-chocks. I only use X-chocks for camping. When storage parked on level pavement, just wedge chocks.
02-21-2020, 04:09 AM
I'm In
, Kentucky
I use X-Chocks to stabilize the AS when parked. We can really tell the difference if we don't install them. Mostly we are on level ground, maybe raise up one side on some Lego style blocks. I use regular wedge style chocks to block the tires on the opposite side. With the front jack down it's pretty stable, never has moved. I secure the X-Chocks to a wheel on each side using bicycle locks that have a plastic sleeve. I got a package of 3 that all use the same key, came with 3 keys. Not sure where I got them, maybe Walmart. I use tire covers so when it's time to move I remove the covers and I see the X-Chocks, so I've never moved when they were still attached.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
02-21-2020, 05:32 AM
Around
, Town
To the original question, I do not have experience with those chocks, but know a couple of folks that religiously do (or at least that style). Only downside (which is a minimal risk) is that if one of the chocked tires loses air, the chock's grip fails.
02-21-2020, 06:27 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Forget the plastic...
We use the above illustrated BAL...17yrs SFSG
Problem I see...metal rod threaded thru plastic does not seem all that robust.
They may appear tight when installed.
Holding the AS on level ground...ok.
Under stress???
I prefer tried & true, Plastic...Not so much.
"You don't know where you've been until you leave, enjoy life" RLC
02-21-2020, 08:26 AM
2020 Classic 33
Box Elder
, South Dakota
Matt, x-chocks was a small family business and to the best of my knowledge is not longer making the chocks. I had a set for my 2014 FB25 but when I went to buy a new set in 2017 for a Classic 30 found that they were gone. They did a great job but the BAL Chocks work just as well and are quick to install.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
02-21-2020, 08:52 AM
Tampa
Touche'
02-21-2020, 08:54 AM
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
We have X-Chocks and also use Camco curved levelers with their chock system when needed. The X-Chocks need to be cranked down tight, and on a hill, adding the other chocks works as insurance. The X-Chocks alone, can slip if you don't crank down, and are on a hill as noted earlier. Last summer, while camping in Tetons with some wet conditions, we had to level using our older "lego" leveling blocks on one side, with the X-chocks in. We didn't tighten enough, when we disconnected from ball, the jack stand slid off the front wood block, and rolled back a little...scared the crap out of us! Went right out and got the Camco curved levelers which work pretty well. We now use both Xchocks very tight when installed, and the Camco chocks, and levelers when needed.
https://www.amazon.com/Camco-Curved-...P0Q18D3JWV4CEC
02-21-2020, 08:55 AM
, Texas & Wyoming
https://www.amazon.com/X-Chock-Wheel...90DC5BFYKRG237
There are several on Amazon.
02-21-2020, 09:46 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
On each side...👍
02-21-2020, 01:52 PM
2020 Classic 33
Box Elder
, South Dakota
My Bad. I thought Matt was asking about RotoChocks. They were pretty popular and easy to use back in the 2000-2015 time frame. X-chocks and Bal-chocks are pretty similar.
Gary
NØVPN
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Fastway ONESTEP Wheel Chocks
jcanavera |
Jacks, Stabilizers, Lifting and Leveling |
5 |
10-03-2009 06:14 PM |
Aluminum wheel chocks
MW64OVERLANDER |
5 |
09-01-2008 09:58 PM |
Wheel Chocks
FordTruck |
42 |
04-18-2008 02:30 PM |
BAL Chocks
trippy |
1 |
09-13-2006 06:59 PM |
Wheel Chocks
pjtaia |
On The Road... |
13 |
10-28-2005 02:27 PM |
