Originally Posted by Tireman9
Since the Michelin tires are not ST type are they larger in size or higher in Load Range than the LT type Michelins?
What were the OE tires? (Size, type and LR and recommended inflation?) is your tire load capacity at least 110% of GAWR and have you confirmed your actual axle weight is less than GAWR for each axle?
Trailer is single axle, 4500 gvwr.
Actual load on axle when loaded for a two week trip stuff for three people, with full water, was 3900 lbs.
Previous tires were GYE, 225/75/15. Ran them at 55 psi for a load capacity of 2270 each. This worked well, and reduced the number of sheared pop rivets.
New tires are 235/75/15. Load capacity of 2271 at 42 to 44 psi. Run them at 50 psi.
I have confidence in the Michelins.
