04-24-2022, 09:43 PM
Living Riveted
2014 19' Flying Cloud
Carnegie
, Pennsylvania
Best tire pressure monitoring solution?
2014 19’ Flying Cloud / Bambi looking to add tire pressure monitoring. Mothership can install but uses a dashboard machine motor - aren’t there solutions that Bluetooth to a smartphone app?
04-25-2022, 05:09 AM
2009 25' FB International
2018 27' Globetrotter
Hanover
, Pennsylvania
If there is such a system I've not heard of it.
We us TST and the monitor is smaller than an iPhone (a bit bigger than a deck of cards) and we just lay it in the console and refer to it as desired. It has an audible alarm if the presets are exceeded.
04-25-2022, 05:12 AM
2021 25' Flying Cloud
Fredericktown
, Ohio
I use TST and have not had an issue. Purchased it through the Airstream Life store.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
04-25-2022, 05:52 AM
2017 16' Sport
N/A
, N/A
TireMinder, uses smartphone as display, doesn’t interfere with other phone function.
04-25-2022, 06:15 AM
1994 25' Excella
Waukesha
, Wisconsin
Tire Minder has a system that will work through your smartphone. But, after trying both the smartphone and the stand-alone monitor, I've gone back to the stand-alone version.
Too many problems keeping the smartphone connected, especially as we made stops and left the vehicle for a while and then came back. I prefer to have the stand-alone, and usually just leave it sitting in one of the dash pockets where it's handy. When it makes a noise my co-pilot or I will pick it up and see what the alert is. I do have a magnetic mount for putting it on the dash if I want to watch something more closely.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
04-25-2022, 06:53 AM
2022 20' Caravel
Southeastern
, Pennsylvania
+1 for the TST.
04-25-2022, 07:48 AM
2011 27' FB Flying Cloud
Delmar
, New York
I’ve been happy with Tire Minder’s Trailer TPS. Very small, solar powered (no wires). I just leave it stuck to the upper left corner of my window.
https://www.tireminder.com/products/...r-trailer-tpms
04-25-2022, 08:43 AM
1994 28' Excella
Manhattan
, Kansas
I had the TST and replaced it with Tire Minder. I didn't like the display on the TST with BLINK BLINK BLINK next tire BLINK BLINK BLINK next tire tire and so on. The Tire Minder I can see all tires at a glance. The one time I had problem I saw the pressure/temps going up on one tire and was pulled over before the alarm went off.
The older Tire Minders and connection problems but the new generation seems to be solid without the problems of the past.
Dennis & Ellie
1994 Excella Classic Unlimited 28 Foot
2017 RAM 2500 Gas 3170 Payload
and
2017 Newmar Ventana Class A DP 7224 Payload
04-25-2022, 08:55 AM
Cedarcreek
, Missouri
I'm guessing I have an earlier generation of Tire Minder... after having a blowout on my vintage Avion, I bit the bullet and invested in the receiver and tire transmitters for all my trailers. I've had 2 legitimate slow leak warnings (leaky valve stem 2 days in a row, lost 10psi) and countless false alerts, lost signal warnings, ridiculously high pressure alerts, etc.. It's a bit of the "boy who cried wolf" syndrome as I'm becoming numb towards the alarms but yet I feel naked driving without the unit stuck to the windshield... it's always turned on when I'm towing!
It's a sickness!
Sent from my SM-A505U using Airstream Forums mobile app
04-25-2022, 09:17 AM
1988 29' Excella
Lorena
+1 tst 507
04-25-2022, 09:21 AM
2017 16' Sport
N/A
, N/A
It's a sickness!
I have mine since 2017, the smartphone one. In the past once or twice I received warnings of a slow leak, each time I had to retighten the transmitter on the tire. This year I revisited the instructions because of a notification of high pressure, turns out I didn’t have the high pressure value set properly . But in any of the cases I outlined, I was glad to have the information. In my case a single axle, I think it’s important to have some warning. It’s like having a smoke detector sounding, I’d want to know false or real.
04-25-2022, 09:38 AM
2021 27' Flying Cloud
Wake Forest
, North Carolina
I've been using EEZ RV Products TPMS system. I've been very happy. It has a small display which charges via USB and charge lasts for days. But I really enjoy that it provide tire temperature as well as pressure. IMO, you don't need it on the dash or displayed all the time as once you set the alerts, it will happily alert you with loud beeps if the pressure or temperature exceeds your limits (high or low). We turn it on when we start driving and keep it in the console. Occasionally I will pull it out and review the numbers.
1x TPMS4C (E618) - Color Monitor + 4 AT Sensors Real Time/24 x 7 Tire Pressure Monitoring System w/3-Year Warranty
https://eezrvproducts.com/eezrv-tpms-info
04-25-2022, 09:47 AM
1994 28' Excella
Manhattan
, Kansas
I not sure why you highlighted temperature but all tire monitors I have seen also tracks temps. The Tire Minder you push button and you can view all tires on the same screen temperatures. Pressure decreasing and tire temperatures go hand and hand.
Dennis & Ellie
and
04-25-2022, 09:52 AM
Castle Rock
I use that unit also. I just bought the repeater for it because I’ve found that the signal drops off from time to time. Aside from that issue that should be fixed by the repeater, I’ve been happy with it.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
2021 25' Globetrotter
Kinnelon
, New Jersey
Happy with TST
04-25-2022, 10:02 AM
1967 17' Caravel
Oak Creek
TST No problems, peace of mind.
04-25-2022, 10:10 AM
2019 25' Flying Cloud
Central
Is it still recommended to use metal valve stems if one was planning on using screw-on TPMS sensors these days?
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
04-25-2022, 10:16 AM
Central
Bluetooth?
Unlikely. The operating frequency BT runs on is around 2.4GHz, same as most low-rate side of WiFi routers. Typically, automotive TPMS sensors will operate at much lower frequencie. The point is that for RF, range is (generally) lower, the higher in frequency you go. So range at 2.4 GHa is going to be lower than say 315 MHz.
So my guess is the reason you don’t see a BT TPMS system is it just doesn’t work well for this particular application.
On topic: I ran a TST 507 on my ‘16 30 FC and it performed very well over two years extended travel.
04-25-2022, 10:17 AM
1994 25' Excella
Waukesha
, Wisconsin
This is my understanding.
But, if you have the new Goodyear Endurance (or any other tire with higher air pressure) you should have the metal valve stems regardless. Same for a TV - if your tires are higher pressure you should have metal valve stems.
Richard
11018
04-25-2022, 10:23 AM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
Similarly, we have had TireMinder for 5+ years, with a monitor/controller like above.
