Old 07-18-2024, 12:16 PM   #1
2023 22' Caravel
Herndon , Virginia
At what PSI hot should we set TPMS alarm?
We have 2023 caravel 22fb
We have original Goodyear endurance tires , Goodyear® Endurance ST225/75R15 Tires, and set PSI to 80 cold
I can’t seem to find guidance on when is PSI too high when driving ??
What do others set for PSI warning?
gokayaking is offline   Reply With Quote
Old 07-19-2024, 06:09 AM   #2
2023 22' Caravel
Herndon , Virginia
Reply we got from Kyle at colonial airstream …
I believe TST recommends a high-pressure alarm between 20-25% of the recommended pressure. During summer travel most tires will likely climb by 5-10psi easily and this could be more depending on ambient conditions. This would put your high pressure alarm around the 95 to 100 psi area.
Old 07-19-2024, 09:53 AM   #3
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
i set it to +15 psi during hot summer
i use +10 in spring and fall
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 07-19-2024, 12:58 PM   #4
Turkeybaster's Avatar
2008 27' Classic FB
Central , New Jersey
My 1st thought is if you are running at 80 psi cold you may want to consider a lower psi (80 psi may be too much based on your weight).
As for temp alarm, my system (TireMinder) has an automatic alarm threshold based on what psi cold temp I input (65 psi for me, also GY Endurance). I didn’t have to select an alarm temp. I didn’t know some units are set up that the user has to decide what alarm temp is dangerous.
-TB
2008 Classic Limited 27FB “The Chief”
2017 F-350 6.7L Platinum
Turkeybaster is online now   Reply With Quote
Shurflo City Water inlet: 50 PSI vs 65 PSI Pierps Fresh Water Systems 25 02-14-2024 08:06 AM
80 psi vs 65 psi - are both safe in this situation? GOUSC Tires 72 10-16-2019 04:56 AM
100 PSI or 70 PSI? '92 300LE fangthorpe Airstream Motorhome Forums 5 09-16-2010 10:11 AM
Manual says ST225/75R15LRC 50 psi -- PO used ST225/75R15LRD at 65 psi Driver1 Tires 3 06-23-2008 08:26 PM
