06-08-2021, 08:24 AM
1962 22' Safari
Kingman
Why replace the axle?
Been following the form about a year now and am amazed at how many people recommended replacing axles and the number of people who do replace axles WHY? I currently am in the process of updateing restoring a 1962 Safari which has a torque axle.
I talked to a guy at the local trailer repair shop and and asked his opinion. He asked the size and weight of the trailer and if I had pulled it at all? I said I pulled it home 800 miles on I 25 and I 40 without a stabilizer and it pulled great no sway no bounce no tire ware on new tires and best of all no popped rivets. He stated in 30 years he had never replaced a “Worn Out” torque axle. As you may know the 62 only had a hydraulic breakaway brake. I am hoping I can fit new back plates that would allow me to install electric brakes. Hopefully avoid the cutting and welding required to replace the axle.
All comments welcomed..
06-08-2021, 12:32 PM
1973 21' Globetrotter
Houston
The axles don't really "wear out," they deteriorate (lose elasticity) with age.
The rubber rods in the axle that provide the "spring" in your torsion axle will eventually harden up and take a set. If you have ever pulled a rubber band out of the junk drawer and had it crumble because it is hard and dry, then imagine the same thing happening inside your axle.
Even an old axle will usually have some "spring" left in it, and tire wear is generally more of an alignment issue--so it might be hard to notice a hardening axle. If the roads you tow on are smooth (like an interstate), you might not notice any short term damage from towing on an old stiff axle.
Your axles may have been welded in place because it was early days of torsion axles, and they were expected to last for "the life of the trailer." In 1962, they probably never imagined someone would still be towing that trailer around in 2021. These days (and even as early as the 70's), torsion axles are bolted on, I assume so that they are easy to replace.
One way of evaluating the flexy-ness of an axle is to watch the wheel as you jack up the trailer. A good axle will let the wheel travel 2-3 inches before it comes off the ground. An old, set axle will only let the wheel move an inch or less before coming off the ground.
Rule of thumb is that an axle will last about 25 years. I can well imagine there are variables like the environment and how the trailer is stored, etc.
All those rubber bushings that are built into your vehicle's suspension won't last forever either. If you got 25 years out of those, it would be more than twice what you actually get (for best performance).
Another thought comes to mind: I have a buddy with a boat on a trailer. He takes it out a few times a year at most, and as a result, the tires look like they have a lot of life left on them even though they are 6 or 7 years old. One day he headed toward Key West with said boat, and 2 of the 4 tires blew out on the way. He parked the trailer, ran to the nearest town to get 2 new tires (only had 1 spare), came back and installed the wheels, drove a few more miles, and the other two original tires blew out. So, at the risk of mixing metaphors, just because a tire has tread and holds air doesn't mean it is a good tire.
Seriously though, a single axle will run you about $650. That is less than most of the appliances you will have to buy during the average refurb. The cost of axles in the big scheme of a full renovation is pretty minimal.
06-08-2021, 04:28 PM
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Some trailer repair guys primarily work on boat, landscaping or utility type trailers so they will frequently see no need to change an axle out. Our trailer guy also said the axle looked good until he educated himself on Airstreams, axles and the torsion rods inside.
Although they are trailers they are little houses we're pulling behind us. They contain many possessions and have walls and furnishings in them.
Today's roadways, byways and highways are in ill repair and the Airstream going down the road needs all the help it can get. Think earthquake on wheels as you ramble across the country. That's a lot of beating up your precious trailer unnecessarily.
There is also no need for shocks on a car but we put them on for the comfort of the cargo inside.
Hittenstiehl
06-08-2021, 05:00 PM
2002 25' Safari
Dewey
Two good tests to determine if you should replace the axles. 1 - Jack the trailer at the mounting plate and measure how high you need to jack before the tire lifts off the ground. 3" is a good number and anything less indicates that the rubber inside of the axle has hardened. 2 - Have the shirt and pants hangers in the closet jumped off the rod when traveling? That is a good sign that the rubber had hardened and not absorbing the shock of the road.
Once the rubber hardens, the frame and the rest of the trailer take a beating.
Richard
06-09-2021, 07:29 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Just replaced the two stock 3,000 pound rated axles with 10" drum brakes on our 2015 23D International Serenity that scales 6,069 pounds. It was built in September of 2014.
The replacement Dexter 3,800 pound rated axles have 12" Dexter dual caliper disc brakes and a 3" lift is built into the axle support brackets. We have the Dexter hydraulic brake fluid pump mounted in the front battery box. We had to go from five to six lug SenDel wheels due to brake size increase. We installed new 15" Michelin LTX ℗ 235/75R15 XL Defender series tires the same size as we have used for years.
A Lithionics 315 amp hour lithium battery was installed (smaller and lighter than the prior 300 amp hour lithium battery) with a Xantrex 3012 converter charger (replacing a Magnum MSH3012), and Victron solar charger and smart battery isolator to allow tow vehicle charging of the lithium battery. We retained the existing five 100 watt solar panels on the roof.
We installed a new 5G capable cell antenna on the roof with a Peplink four ethernet port modem with WiFi.
The Dometic Air conditioner received a MicroAir Easy Start and a new MicroAir thermostat on the wall. The television was upsized as well.
The funky cushion on the dinette seat by the door (same funky pillow on most FB and RB 25/26/27 models) is being replaced by a hickory cabinet to at least make use of this wasted space.
The eight year old Hensley Arrow was replaced with the new Propride PPP hitch with the V2 jacks. We got a second stinger which will be configured for the 2021 Land Cruiser to be able to tow the 23D after the in-coil Firestone air bags for the rear springs and a 12.5 gallon auxiliary gasoline tank from Australia are installed.
We fixed the Rigid Industries rear LED lights circuitry so they again come on whenever the tow vehicle is placed into reverse or a manual switch by the door is energized.
This has been a very busy week at A&P Vintage Trailer Works in Paradise, TX. I drive the nearly 1,000 miles to get this type of work done as it will done correctly the first time and they have stood behind their work since 2014 for me.
The 23D is having a third visit and the Classic has been here five times. We expect to renew the Classic axles and go to Dexter Disc brakes with a three inch lift built in the support frames of the axles. We will go to 5,200 pound stock load axles up for the factory 5,200 rated axles. The Victron Orion Smart charger will also be installed on the Classic then as it was not available when we did the upgrade to the same equipment brands a year ago in the Classic.
The big deal to me is that the battery related gear has a simple wall display but the details show up on my iPhone and iPad over Bluetooth. There is a conventional data display for both Xantrex 3012 units.
06-09-2021, 07:40 PM
2014 31' Classic
Apache Junction
Axles on Airstreams have a finite service life. The four rubber strands get stiff and the spring action quits resulting in damage to the Aluminum shell as if riding on steel wheels.
We are upgrading our 2015 23D International Serenity (built in SEP 2014) this week from 3,000 pound stock axles with ten inch brake drums to Dexter 3,800 pound axles with twelve inch dual caliper Dexter disc brakes and a three inch lift built into the axle support brackets. The Dexter brake pump is located in the battery box. There were other major items addressed at this time.
We plan a similar upgrade for our 2014 Classic (built January 2014) perhaps later this year to go from the stock 5,000 pound axles modified with 12" Kodiak disc brakes to 5,200 pound Dexter axles with 12" Dexter dual caliper disc brakes with a Dexter brake fluid pump replacing another brand in the battery box.
We change oil to keep the engine properly lubricated and if we don't there can be serious issues. Axles require attention as well.
06-09-2021, 09:14 PM
1994 25' Excella
Waukesha
, Wisconsin
Price a new axle with brakes and then price all the brake components individually. You might find that the increase for the whole shebang is not that much when you consider the time and effort it will take you to retrofit brakes onto your existing axle.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
05-18-2024, 10:33 AM
2006 25' Safari
St. Augustine
Mine is getting older and with all this axle talk I wondered what I had. I crawled up under and found a tag Dura-Flex/Cap 3300 or 3800 (cannot tell which one but think it is 3800)/Ser 3041909/ Model CAN 1970 Henschen.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
05-18-2024, 11:31 AM
Two Places
, Sticks & Bricks
Are you thinking about changing, just because they are aged? I suspect thousands of axles have been uneccesarily changed.
I remember some advice from Airstream Andy (I miss his posts) and many others. Flexibility of the rubber is key!
When jacking up the trailer by the frame, the tire/wheel should move downward as load is removed, a minimum of 3"minimum. This 3" movement indicates that the rubber is still flexible. Any less than 3" and it is time to replace.
I feel homeless
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 2000 25' Safari)
05-23-2024, 05:17 PM
1999 28' Excella
New Orleans
, Louisiana
Axle replacement?
Our 1999 Excella has been wonderful until recently. We opened the door to a real disaster. We are full-timers. We were told we needed new axles. Maybe they get stiff and lose their cushion. It is a very rough ride for the trailer. We replaced the shocks a year and a half ago.
Axles? We can pay for it done if it is the axles and where would you suggest?
Thanks, Kat
10-29-2024, 06:41 PM
2020 30' International
Fort Pierce
, FL
This is why I am considering Axle replacement
Hello, have recently inspected my brakes and hubs and I have found that the armatures have significant wear. The hubs are Nev-R Lube on a 2020 30' International Serenity. 50k miles. I am based in Florida.
I see a few options:
First: turn the drum armatures, reinstall them and replace the brake plates. This is my preferred option. BUT the Nev-R lube bearings have to be pressed out before the hubs are turned. So far I have not found anyone who is willing to attempt this. I can't switch from Nev-R lube to Easy Lube because the spindles and hubs are not compatible.
Second: buy hub/brake plate assemblies and install them. Sounds straight forward. Estimate from Dexter is $785 each. Total is $3180 before I install them. Ouch!
Third: Replace the axles. Dexter does not have a parts list for the replacement Nev-R lube axle. They need 4 weeks to make one. They quoted a 3500# axle as a comparison for $1558. Total $3116 before installation.
Fourth: Change the axles to Easy-Lube with 3" lift. Since Dexter does not have a parts list, I went to Airstream. Quoted $1940 + $%398 for the lift kit. Total 4676$.
These Nev-R lube bearings seem to be a PITA since the magnets wear out the armatures over time. They are not serviceable by mere mortals. I wonder why Airstream still uses them.
Seems like my best bet is to have a Dexter Authorized Service company replace the axles with Easy Lube axles and build in the 3" lift. New axles, serviceable armatures, higher lift, fewer back-end scrapes.
10-29-2024, 09:16 PM
1985 25' Sovereign
Navarre
, FL
I wonder about the statement that there should be 3" of lift before the wheel leaves the ground as the specs from Dexter for the #10 axle call out a travel with:
22* down is 2.3"
10* down to be 2.71" from no load to full load.
Deflection with 0* is 2.3"
This is for 3500 lbs on a single axle.
Most airstreams would be similar to mine where the max weight is 6200 lbs -700lb tongue or 5500 lbs divided by 2 or 2750 per axle.
This is (very roughly) 2750 / 3500 or roughly 75% loaded.
One might expect for there to be roughly 75% of the movement specified for a fully loaded axle or 2.3" X .75 or (again roughly) 1.73" of travel from loaded weight on the tire to tire off the ground (ignoring the compression of the tire).
I believe expecting 3" of travel jacking the tire off the ground is expecting more than is called out in the specifications unless the trailer is quite overloaded.
10-30-2024, 12:01 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
On our 63 Safari...
If most of the tire is invisible...you need a new axle.
First hint...it's really hard to get out of the wheel well.
10-30-2024, 12:41 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Here is a photo of my 75 Overlander 27' swing arm after jacking up the trailer and removing the wheels. You can see the swing arm is nearly level with the floor. It should be pointed down. Dexter calls this the "starting angle". This condition means the rubber rods inside the axle are hard and lost all elasticity signifying the axles are worn out.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
12-02-2024, 10:15 AM
2013 31' Classic
billings
, Montana
Never lube drum armatures can be turned without removing bearings
12-02-2024, 10:18 AM
2013 31' Classic
billings
, Montana
Call Colin Hyde
The axle man
12-02-2024, 10:58 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
OP gone?
12-07-2024, 06:45 AM
Moderator dude
1966 26' Overlander
Phoenix
Originally Posted by ROBERT CROSS
OP gone?
This thread was started over 3 years ago.
The OP has not visited this website in over a year.
The answer to the question is yes.
Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - Still Streamless. But have brand X TT.
12-07-2024, 08:55 AM
2020 23' Globetrotter
Savoy
I Jacked one side of our 2020 23 FB GT. With the wheels and tires still mounted to the axle the tires dropped only 1 inch. We've pulled the GT about 100,000 miles. I guess that means they should be replaced.
12-07-2024, 09:17 AM
2013 31' Classic
billings
, Montana
I was worried about my nevrlube bearings 80,000 miles. Axle angle is 12 degrees. Installed new axles. Ezy lube. 22.5 degrees took less than 8 hrs
