Vintage axle advice needed
My '62 Safari had its torsion axle welded on, which was apparently the practice that year.
Of course Airstream soon switched to bolting axles on sometime shortly after '62.
The guys at my shop felt like it made more sense to weld the new one on, since they'd have to cut into the frame to bolt it on . . .
Now I've just read in Rich Luhr's Airstream maintenance guide to "never allow heat (from a torch or welder for example) to be applied to the axle." This is because it can damage the inner rubber cords.
So what should I tell the guys in the shop. They welded the axle on this past Friday . . .
Here's a photo of it before it was welded on.
