Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 03-02-2021, 01:27 PM   #1
2011 23' FB International
Centennial , Colorado
uneven tire wear, axle check/repair (Colorado)?
Doing my own research, but any words of wisdom welcome:
Uneven tire wear discovered when replacing tires on right side, on inside of tire one axle, outside of tire other axle. Did hit a curb once (<10 mph) on left side of trailer (one flat). No vibration noticed.
Thoughts (have photos)? Any Denver (or Front Range, Colorado) shop recommendations for axle check/repair/replace? I'm aware of Foxridge, Ironbear, a few others (not a fan of Windish).
2011 23FB International, probably considered low miles. Danka.
davidmenges is offline   Reply With Quote
Old 03-03-2021, 05:45 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I would contact Luke in Fort Collins. He replaced axles for me a few years back.
airstreaminco@gmail.com
Richard
Old 03-03-2021, 07:24 AM   #3
"Cloudsplitter"
I thought I had bent an axle, turned out to be worn rubber (spring) bushing inside the axle. Inside tire edge.
Nine years is a bit soon, but wouldn't be unheard of on rough roads and heavy loading.
I doubt a 10mph hit on the opposite side would cause that tire ware. Inside ware toe-out. Outside, toe-in.
Went to Jackson Center for the axle install.
Uneven Tire Wear Jwestman On The Road... 2 04-04-2016 05:09 PM
Uneven tire wear!! claybags Tires 46 01-08-2015 10:37 AM
Uneven tire wear Lumatic Tires 7 07-19-2012 09:08 AM
uneven tire wear 64globetrot Axles 4 09-13-2009 02:01 PM
Uneven tire wear..Yikes!! daydreamer36535 Tires 18 07-09-2007 10:17 AM
