Old 10-12-2019, 07:46 PM   #1
1973 31' Sovereign
Clarksville , Tennessee
Torsional Stub Axles
I own a 1973 Airstream 31'. I'm about to install a lift kit and thought about changing the axle stubs.
I'm looking at the Reliable Brand axle stubs from Rigid Hitch, they are $227.00 a pair. Part #rts-1000-07 lh rts-1000-08rh.
Would my 6 lug hubs fit the new 1" spindles? If not what size are the spindles?
Airstream134 is offline   Reply With Quote
Old 10-12-2019, 08:02 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums.
What are axle stubs? I've been around Airstreams a very long time, and have never heard of them.
If you are referring to the torsion arms that move and hold the bearings and brake assemblies, they are not replaceable or repairable. If they are the originals, you should replace the axle assemblies, including new drums/bearings, and brake assemblies.
Old 10-12-2019, 08:09 PM   #3
1973 31' Sovereign
Axle stubs
Axle Stubs are the part that bolts on to the "axle tube". They come in a variety of bolt on or weld on configurations. You can buy them with the hubs and bearings or without the hubs. IE: Amazon, eTrailer, etc.....
I figured Id get some grief about this, but I run dexter axles under both my horse trailers and Ive changed out just the axle stubs and not the tubes on both. The tube itself is just that a tube.
It appears to be the same setup, the axle stubs bolt on to the axle tubes, it may appear they don't but they do.
Old 10-13-2019, 05:39 AM   #4
1993 21' Sovereign
The only thing that bolts to the axle tubes is the frame of the trailer. Period.
Old 10-13-2019, 11:27 AM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
For leaf spring axles … sure.
For torsion spring axles … nope
>>>>>>>>>>>>Action
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
Tips for removing shower pipe stub JeweloJalopy Sinks, Showers & Toilets 5 08-03-2013 02:38 PM
Bath Sink w/gooseneck and shower stub source CtRobert Sinks, Showers & Toilets 0 03-04-2011 08:04 AM
OR 090 : L.L. 'Stub' Stewart Rally mike rogers WBCCI Rallies & Events 21 04-15-2008 11:16 AM
