Old 02-26-2019, 02:50 PM   #1
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Question Torsion Axle Shock Removal on 2004 Classic
I am perplexed. How do I remove the upper shock mount on the axle? It is right up against the frame and even the nut is to thick to slip out. Please tell me there is a way without dropping the axle to change the shock!!
This is on a 2004 Classic 28.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 02-26-2019, 03:24 PM   #2
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
when i did my 2005 classic it was a fricken BEAR to get the shock off the upper mount.. there was room but a min amount but enough to get the nut off and I was able to twist and turn it on the mount it get it off.
yours looks like you might have to drop the axle to change it out. DAMMMM...
I think the shock mount was not installed correctly. I know on the upper especially they, Out of door mart AS dealer, recommends to cut the rubber bushing in half, out one half on the shaft, squeeze the shock on mount, put other half on shaft and put washer and nut back on.
If you do drop the axle might be a good time to get the lift kit.
https://www.amazon.com/Dexter-Torfle.../dp/B00AZNVVC8
here is video of a guy adding the lift kit to a 30 ft classic.
GOOD luck.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 02-26-2019, 03:51 PM   #3
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Mine was the same. I have read where someone said to bend the mount.
Removing the axle you can likely plan on cutting off or grinding frozen mounting bolts.
15 year old axles, how much movement is left in them carrying the trailer load vs. jacked off the ground?
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 02-26-2019, 04:11 PM   #4
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Dang, dang, dang guys! Exactly what I was afraid you were going to tell me!
The trailer is 15 years old, but it has very few miles on it (until I got it). I am guessing it had less than 15,000 miles on it. I am redoing the brakes and bearings. All of the parts, except the pads, look new from a wear standpoint.
I think the torsion axles are in good shape. It rides well and there is a lot of travel left in them.
I think I am just going to ignore the shocks for the time being. If I change the axles at some point, I'll change the shocks.
Thanks for your inputs!!
DaveP
Old 02-26-2019, 04:19 PM   #5
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Originally Posted by DaveP View Post
<<snip>>
That's what I would do!
Alan
Old 02-26-2019, 04:28 PM   #6
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
If the trailer has that few miles and there is no visible leaks on the shocks, best to leave alone and service the brakes and grease bearings.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is online now   Reply With Quote
Old 02-26-2019, 05:30 PM   #7
AlinCal's Avatar
1991 25' Excella
Add my vote.
Will Rogers
Alan
Old 02-27-2019, 09:57 AM   #8
harryk's Avatar
2005 31' Classic
Venice , Florida
The less you use the trailer, the more likely the rubber torsion axles are on their way out.
harryk is offline   Reply With Quote
Old 02-27-2019, 10:25 AM   #9
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 86
At about 120,000 miles, and after having devastating tire wear issues, we replaced our axles, shocks, etc. on our 2004 Classic. We started having issues at about 50,000 miles. We had bearings packed every 20k miles. We were not showing the wear typical of the shocks being bad. Wish we had replaced our axles much earlier. Major repair results axles shocks tires skylights Good luck with your shock replacements.
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 02-27-2019, 11:16 AM   #10
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Gus,
Thanks for linking your earlier post. Interesting reading. I saved the image of the Dexter label for future reference.
I also have the 4200 lb. Dura-Flex axles although my 28 foot Classic weights a few less pounds.
I put new tire on the trailer right after I bought it and I log every trip. So far, I only have 7500 miles on the tires, but there is no unusual wear showing. I also track tire temperature and pressure with a Truck System Technologies Tire Monitor System. I'll keep an eye on things going forward.
Again, thanks to everyone for their inputs!
DaveP
Old 02-27-2019, 12:05 PM   #11
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
As bad as this seems, bend the mount, remove & install the new one. The bend the mount to the original position.
>>>>>>>Action
Old 02-27-2019, 09:40 PM   #12
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
The Airstream Service Center told me that if the shocks are not leaking they are OK. I have travelled to Fairbanks, AK plus many more miles. I'm planning on going to Labrador with the Viking Trail Caravan this summer, so one more leak check and I'm on my way.
guskmg
Restoring Torsion Arm/Axle Resiliency Happycamper Axles 15 06-08-2018 05:12 AM
Bent torsion arm, 2004 34 footer Frank's Trailer Works 2001 - 2005 Classic 26 03-15-2014 10:15 AM
To Shock or not to Shock jlovelady Shocks 35 11-16-2012 08:01 AM
Dexter Torsion with no lower shock mount? Aktundra Axles 7 02-11-2012 11:15 AM
Help connect dots: Axle rating + torsion spring + shock. Aktundra Axles 3 02-05-2012 05:50 PM
