01-06-2017, 09:46 AM
1969 29' Ambassador
Fulltiming
, via Jersey Shore and Philadelphia, PA
Shop for axle replacement?
Hello,
I was wondering if anyone could recommend a shop in the FL/GA/AL/SC area to replace our axles and brakes. We're currently in Naples, FL and we'll be in the Orlando area by the end of January. Thanks!
Tim
04-04-2017, 08:45 AM
1969 29' Ambassador
Fulltiming
Moving West
We were delayed in Florida by tow vehicle woes but will be west of the Mississippi by the end of the month. I guess I will be contacting Andy next for replacement axles. Are there any shops I should consider in Texas, New Mexico, Arizona? Just take it to Inland? Any help is appreciated!
04-04-2017, 09:07 AM
1986 31' Sovereign
Miami
Airstream of New Mexico in Albuquerque is top notch. They are doing my axles in May. Ordered them from Inland.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
04-04-2017, 09:14 AM
1967 26' Overlander
Bugtussle
, Oklahoma
if going to Inland is a viable option then having Andy install your axles would be the way to go. He is the axle expert IMO. Get in contact with him right away as I suspect he is very busy this time of year and may need considerable lead time. Going to Inland was not an option for me so I chose to order my axles through a local Dexter dealer and installed them myself. The new axles are perfect and I saved a lot of money, but it sure would have sure been nice to roll into Andy's shop have it done.
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
05-03-2017, 08:35 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Not sure where you folks are but there are a couple of good places in Texas to get your axles replaced. One is A&P Vintage Trailer Works by Fort Worth (Paul Mayeux 817-919-3651, www.apvintagetrailerworks.com). The other is operated by Lance, no additional info. I know he did DKB_SATX axles, and he was very pleased.
Dan
05-04-2017, 11:36 AM
Moderator dude
1966 26' Overlander
Phoenix
Oasis RV center in Tucson is a good one as well.
>>>>>>>>>>Action
05-04-2017, 11:42 AM
2007 22' International CCD
Corona
Inland RV no longer offers installation or any other services, sadly...he just sticks to selling parts and providing good information.
06-23-2017, 07:13 PM
1969 29' Ambassador
Fulltiming
Update!
First, thanks to everyone that replied with suggestions. But in the time between placing my order with Colin and receiving the new axles, I decided to tackle this project by myself. It's just 8 bolts, how hard can it be?
My new barbells, 3800# load rated, 32° starting down angle.
Soaking the fasteners in penetrating oil and loosening the shocks.
I only resorted to cutting off one!
I was prying and whacking on the drums pretty good until I realized I only pulled three mounting bolts! Once that was taken care of they shimmied out with a little size 11.5 persuasion.
The second one went much easier. I started to cut out the first notch when my second cordless battery gave up. I will continue that tomorrow, weather permitting.
Off to the recycling yard with youse.
Of course I goofed and ordered the wrong shocks. I think they're kinda superficial, but, figure if I'm here, and it came with em, it can't hurt. And that gives me the excuse to not rush it and get a coat of POR-15 up there in the meantime.
Thanks for watching!
06-24-2017, 06:40 AM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Great photos of axle removal. It looks like you used a grinder to cut off the stubborn bolt. I used a sawzawl for the one axle I have removed so far. Maybe I will try a grinder on the other axle.
I ordered my axles from Colin about 5 weeks ago. Still waiting. No problem though due to project creep- belly pan removal, frame rust removal and painting, insulation replacement and new belly pan installation.
Dan
06-24-2017, 02:02 PM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
Great Job. I've purchased axles from both Andy and Colin (different projects). Both were for self install. Colin was more cost effective.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
07-07-2017, 05:09 PM
1969 29' Ambassador
Fulltiming
Thanks everyone. I felt a lot more confident due to so many in a similar situation taking the initiative and documenting their experiences here. And a big thank you to Colin Hyde!
After rolling around in the dirt and wiggling everything into position, we're all torqued down and ready to put down some miles. That is, after I replace the bathroom floor. What's that they say? The fun never ends? Something like that.
Here's a little before and after.
07-07-2017, 05:46 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
How did you arrive at the 3800# rating? What were the axles that came off?
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
07-07-2017, 08:25 PM
1979 23' Safari
Wayland
, New York
Nice job!
What did you use to cut the notches larger?
07-08-2017, 05:45 AM
1969 29' Ambassador
Fulltiming
The trailer is originally listed at 6500 GVWR, so I'm assuming the old axles were rated at or around 3250# each. We travel with it right on the edge of GVWR so I wanted a little more margin there. I think Colin made mention of the 3800 number and it sounded about where I wanted to be.
Originally Posted by HiJoeSilver
Nice job!
A 4" cordless grinder made quick work of it.
