Old 01-02-2020, 03:31 PM   #1
1976 Argosy 28
Buford , Georgia
Replacement parts for Axle URGENT!
So my sisters '85 25ft airstream lost a wheel and in the process (what came first I don't know) it destroyed the brakes and bearing on one wheel. So where can you get parts for the older axles for this, I was told she needs new brakes, bearing and hub. She is stuck in a small town (Franklin Ky) at a mechanics shop that does stuff like this. Any help would be great!
thanks
John
strangepod is offline   Reply With Quote
Old 01-02-2020, 04:40 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you're sure she only needs bearings, seal, drum, and brake assembly, you can get them at almost any trailer repair shop. You will need to let them know if it's 10" or 12" brakes. If it's 12", the outer bearing is the smaller one (3000#), rather than the larger one (6000#). If the spindle was damaged, entire axle replacement is required.
Axle replacement / Floor Replacement - Newbies! toesonoz Vintage Kin 12 07-02-2016 05:05 PM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
