Old 09-29-2018, 06:09 AM   #1
1972 Travelux Princess 25
Cobourg , Ontario
Possible solution to the axle problem
It occurred to me that the problem with old axles may not be failed rubber but frozen pivot joints. The trailing arm can`t rotate if the bearing is full of dirt and rust.
I have seen this before on old VW beetles that had a similar trailing arm suspension. If the suspension froze up the front end would get lower and lower until it bottomed out. The solution was to jack up the car and take off the wheels, grease the bearings and pry down the trailing arms. It might be necessary to do this 2 or 3 times before it freed up.
Might it be possible to drill the axle housing and install a grease fitting and use some lubricant that is compatible with rubber like glycerine, graphite or some kind of silicone grease?
Does anyone have an old Airstream that needs axles and is willing to try the experiment? What have you got to lose?
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 09-29-2018, 08:44 AM   #2
Cobourg , Ontario
I dreamed up this idea last night when I couldn't sleep. This morning I did some web searching and learned more about the way the axles are made. Now I am not so sure they even have a bearing at the end. So this idea is probably a dud. Still it would be interesting to have the opinion of someone who has worked with these axles and taken them apart,
Old 09-29-2018, 08:51 AM   #3
Retired.
. , At Large
Trailer torsion axles are made by inserting a square-ish steel rod into a square tube, using rubber inserts as suspension. There are no bearings.
2017 30' Classic Refrigerator Possible Solution HubbyBear77 2016 - Current Classic (all lengths) 5 09-18-2018 07:15 PM
A possible solution for the Hensley "bump" switz Towing, Tow Vehicles & Hitches 10 12-29-2013 07:27 AM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
Intermittent 12v elec problem & solution ole81 General Interior Topics 4 07-29-2007 10:01 AM
Has anyone ever found a solution to this furnace problem? wacnstac Furnaces, Heaters, Fireplaces & Air Conditioning 9 03-07-2007 12:04 PM
