11-22-2017, 11:52 AM
#21
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up
, Traveling the USA
I just replaced axles, brakes, hubs at JC. Because I have a 3" lift kit, I kept the angle at 22.....still when work was complete it raised the trailer between 2-2.5"
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
11-22-2017, 12:27 PM
#22
Vintage Kin
Fort Worth
Originally Posted by Al and Missy
Actually, AS does not fit shocks on the smaller trailers (23 and under) shipped overseas and with CSA ratings. I would think a lighter trailer would be more subject to shock loads.
From Wiki:
"While shock absorbers serve the purpose of limiting excessive suspension movement, their intended sole purpose is to damp spring oscillations."
Since the torsion axle converts vertical movement of the unsprung components to torque on the rubber rods (which have a natural hysteresis) I believe the impact of a shock absorber on the Torflex axle is less important than on a leaf or coil spring suspended solid axle. The axle manufacturer (Dexter) says they are not required, and several on here have reported excellent towing without them.
All that said, I'm a "belt and suspenders" kind of guy so I am ordering my axles with the shock mounts. As a friend one said "overkill is just about right". If I feel the shock absorbers are needed after some test tows, I can add them.
Al
The simplest way to say it is that with no shocks, the tires have to do that work, ALSO. Broken-surface braking is dependent on tire adhesion
Sure, may not able to dintinguish. And I'm NOT trying to be argumentative except to push this one point.
It isn't expensive, is the second.
11-22-2017, 01:02 PM
#23
2002 30' Classic S/O
Fleming Island
Braking is a good point. What the heck, with the brackets on there already, the shocks are only $29 each or so, and easy to install with the axles. I think you talked me into it.
I wasn't trying to be argumentative either, just trying to understand.
Thanks for your persistence.
Al
11-22-2017, 01:42 PM
#24
Fleming Island
Just got a call from Dexter via Redneck Trailer
My guy went ahead and ordered the axles today. Apparently (and this makes sense) the shock mounts are not available on the 32 degree down axle. I changed my order to 22.5 down. If I need to raise the trailer, I'll add the lift kit. Hopefully the shocks will still fit.
Al
Here is a copy of my order form. I turned it in to my trailer repair place today. He will send it to Redneck Trailer (a Dexter distributor) on Monday to avoid its getting lost over the long holiday weekend.
I went with an upgrade from 4400# to 5000# and increased the stargting angle to 32 degrees from 22.5. By my calculations that will raise the trailer just over 3/4" in addition to any gain from replacing the shot axles.
I also specified the shock mounting bracket (in the comments box) but I'm going to try it first without mounting shocks.
Kodiak 12" discs and Hydrastar 1600 actuator also ordered. Hope to have it all together for Canopener.
Al
Al
