Old 01-14-2023, 02:56 AM   #1
MustangGuy's Avatar
1954 22' Safari
Ringmer , East Sussex
Manoeuvering Options
What do people use (apart from grunt) to manoeuvre their airstream please?
I’m too infirm to do it manually and have no friends 😉
The motor movers in the U.K. all need to have the chassis modified apparently. This wouldn’t have been a problem at the beginning of the build but it is now.
Any ideas?
Niall
Niall
1954 Safari 06027
@drivewildhorses.silver.bullitt
www.silver-bullitt.com
https://www.airforums.com/forums/f67...-238116-2.html
MustangGuy is offline   Reply With Quote
Old 01-14-2023, 06:24 AM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Assuming you are asking about moving the trailer around your property/parking area when not connected to the tow vehicle.
I use a sub-compact tractor to move mine in/out of the barn and into position to hitch up the tow vehicle. The tractor has a 3-point hitch on the rear where a ball is mounted.
Richard
11018
richard5933 is offline   Reply With Quote
Old 01-14-2023, 07:39 AM   #3
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
I use my tractor or my Gator. It's easier to maneuver the AS into my shop by using the front hitch on the Gator.
JEWare
John Ware is offline   Reply With Quote
Old 01-14-2023, 08:14 AM   #4
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
MustangGuy, I have a manual crank model, TrailerValet XL originally for a 23’ Flying Cloud. It came with a coupling that attached to the tongue jack to stabilize it (last photo).
We have a concrete driveway and pad to the side of our garage so I needed something to navigate the trailer in tight 10’ space.
We now have a 27’ Globetrotter which has a third more tongue weigh. I found TrailerValet makes a frame attachment mount with a post that is more stable but does limit the turning ability. I’m able to work around that because I’m making slight turns and mostly moving back and forth.
It’s a good workout but gets the job done for me. Your mileage may vary!
Good luck from across the pond.
Jeff
ID:	427134   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 01-14-2023, 08:26 AM   #5
1994 25' Excella
Jeff
Totally forgot about this...We have the same Tractor Valet mounted on our 25-ft Airstream. Great for moving the trailer around once we get it inside the barn. Don't bother with the mount in the ball hitch though - definitely use the frame-mounted option like in these pictures.
Richard
11018
AC replacement-options, options... Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 5 09-12-2018 08:56 AM
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 12:18 PM
two more options Zed2 On The Road... 0 02-14-2003 04:08 PM
Options for hauling bicycles?? 2003 International CS rmmm68 2002 - 2005 International 4 02-07-2003 07:54 PM
Mister Heater/cheap heating options? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-14-2002 02:03 PM
