Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 06-03-2015, 09:28 AM   #21
1962 19' Globetrotter
Vancouver , British Columbia
Ahhhh so that's the reason she locked up is because the lower spring busted.
I haven't measured but these 62 globetrotters are a 12" setup correct? I'd like to get through inland but I'm in such a rush I might have to sorce local. With a full hub replacement she should spin
Stupidnoob is offline   Reply With Quote
Old 06-03-2015, 09:29 AM   #22
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
When I got my Bambi II the brakes had not been used in over 10 years. So of course they would not work when I plugged in. Axle was shot so I went ahead got a new axle complete with new hubs and brakes thru Colin. After the new axle was installed brakes would still not work. I took it down to Foley Airstream and they discovered that all the brake wiring had totally self destructed. They replaced the wiring and low and behold I had brakes. Nice feeling having reliable brakes and to once again be legal in my state.
MICHAEL
Old 06-03-2015, 09:31 AM   #23
dznf0g's Avatar
Oswego , Illinois
One of two things happened, IMO. Either the brakes were so mis-adjusted on the loose side, that the adjuster came off the ear of the shoe and then the spring came loose and broke from rolling around, etc. Or, the spring broke and the shoes were so mis-adjusted (loose) that the adjuster fell out.
-Rich-
Old 06-03-2015, 09:41 AM   #24
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
If you are not using the brakes just take everything off and put the drum back on. The brakes don't need to be there.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 06-03-2015, 10:01 AM   #25
Sweet Jesus lol, just my luck.
So I'd like
To get confirmation if anyone here has their measurements on an old single axle globetrotter (1962) what I've measured is:
22.5% arm angle
57.875" outside to outside mounting bracket
73.75 hub face dimension
That sound about right?
I think my original axle was 3200? Def need 3500 at least??
Old 06-03-2015, 10:40 AM   #26
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
In 1962 some of the axles were welded to the frame, all were bolt on after that. You might need to have a frame bracket made up and welded on so you can bolt on a new axle.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Old 06-03-2015, 10:57 AM   #27
Yup mine was welded
Name:	ImageUploadedByAirstream Forums1433350578.328504.jpg
ID:	239919Click image for larger version
Name:	ImageUploadedByAirstream Forums1433350620.171388.jpg
Old 06-03-2015, 11:42 AM   #28
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Think about the OTHER drivers
Running without brakes - sure you CAN do it - but it's probably not legal, and if you have to have your trailer safety inspected annually, brakes and tire wear are about the two biggest things they check.
Even if you operate with NO brakes, you need to be aware of what can go wrong. ANY trailer CAN become separated from the tow vehicle. And with no brakes - this is exactly what happened right here in Va. Beach, to people I knew and loved:
The husband and wife were towing a utility trailer without brakes. They needed to stop at the local toll gate and when they braked their truck, the trailer bounced off of it's ball, the safety chains parted, and the trailer bounced along the road, with it's tongue going up and down hitting the roadway. The freak accident? The tongue hit and pierced a station wagon's gas tank two lanes away from them. The family of seven lost two members, and the rest were horribly burned. These very nice people were tied up in court for years, the trailer hitch manufacturer was sued, the station wagon manufacturer was sued, they were sued. The trauma of watching that family fry was worse than all the rest. I think they both died earlier because of that experience.
Several posters have suggested you consider new axles with new brakes and bearings. You seem want to avoid spending money, and seem to be happy that you can put stuff back together with NO brakes. I just pray that YOUR luck doesn't run out. Being cheap cost everyone who was sued almost $17 MILLION dollars.
There are a LOT of benefits to having a new axle on an old trailer. Knowing you've never killed someone through carelessness - priceless.
Old 06-03-2015, 12:10 PM   #29
That's a pretty harsh assumption
Did you not see my
Post above of my axle measurements and looking for confirmation?
I'm not looking for a lesson. I tow food trailers every single day, 6 times a day. I'm well versed in towing.
Obviously I'm replacing my axle if you took the time to read the above post. Please don't jump to conclusions about my character there buddy.
Old 06-03-2015, 12:50 PM   #30
Rascal0729's Avatar
1969 23' Safari
East Ryegate , Vermont
Images: 8
Today my AS is back with it's new Dexter axle complete with new brakes, e-z lube fittings and new shocks from Airstream courtesy of P & S Trailer Service.....& 3- Tow Master ST225/75r/15 mounted & balanced Total cost $794.76!
Rascal0729 is offline   Reply With Quote
Old 06-03-2015, 03:03 PM   #31
Nice nice
Times like this soooooo much easier living in the usa!
Old 06-03-2015, 03:24 PM   #32
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Stupidnoob... I love your screen name :-)
I am just across the pond in Victoria, I just recently ordered my new axles from Inland RV for two of my Airstreams all Andy needed from me was the serial number off of them and he knew what I needed. It was a pretty simple replacement. you can get bare or complete axles...go for the complete and you will get all new drums,bearing, brakes and all that stuff and the shocks (sold separately) were something like 25 bucks each. If you know someone on the other side of the border you could get the new one shipped to you could possibly save a bunch of money on the cross border shipping and just pay duty and taxes at the border
thesignlady is offline   Reply With Quote
Old 06-03-2015, 04:05 PM   #33
Ya I talked to Andy this morning he's awesome.
It's just the exchange rate is a killer right now, added 20% plus taxes at the border you almost end up paying double.
I've ordered lots of stuff through inland but I might have to have this one built up here locally. If it wasn't for the exchange rate its obviously a no brainer.
Stupidnoob yup! But I'mma learnin!
Old 06-03-2015, 05:21 PM   #34
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
How about putting the AS on a low trailer and towing it to the USA to have the work done?
tsunami is offline   Reply With Quote
Old 06-03-2015, 06:47 PM   #35
Haha oh my god that would be a big ass bill! Our dollar is at .74 us.
Old 06-03-2015, 08:53 PM   #36
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Good luck with your new tow master tires!!
Old 06-03-2015, 10:03 PM   #37
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
Will this size axle fit?
22.5* down angle
57.68" outside to outside mounting brackets
hub face 75.87"
3500 # axle
I bought this Dexter axle for my '61 Safari in 2008.
Took the trailer on one trip from Oregon to Minnesota and back
Then I rebuilt the interior and found my weight had gone up to 3575 # loaded
Took this axle off and installed a new heavier axle.
I also made new mounting plates with the additional brackets which take the outside to
outside measurement to about 57.87"
If this would work, then comes the big question --- how much of a hurry are you in?
I will be driving my pickup to Vancouver, BC in mid August and could deliver the axle easily. I am sure we can work around the exchange rate to a price we both like.
Sam
samb is offline   Reply With Quote
Old 06-03-2015, 10:33 PM   #38
Fixxxer's Avatar
1967 24' Tradewind
Summerland , British Columbia
Pacific Spring and Axle is in Langley BC. I got my torsion axles from them made to spec.!
Fixxxer is offline   Reply With Quote
Old 06-03-2015, 11:09 PM   #39
That's exactly who I went and talked to today!!
Was worried about a custom built axle
Yours turned out ok??
Old 06-04-2015, 03:57 PM   #40
Did you not see my
Sorry I came across as harsh. What really happened is I started posting, then got called away for an hours, and hit "send" without looking at the new stuff you had posted. Glad to see you've got your new axle coming. You will love the difference. I should remember that only about 1 in 10 streamers actually are members - and have a pretty sharp learning curve.
I see stuff in campgrounds that just makes me shake - and even experienced campers occasionally do strange things. A neighbor with a fifth wheel has a truck that has the side walls of his bed completely crushed - he didn't lock the trailer down correctly and it fell off the jack and onto the bed. The truck was only 3 months old when this happened. 15 years experience too.
Reminds me to do my safety checks - every time.
Paula
seized brakes and bearing! newbie770 Wheels, Hubs & Bearings 10 05-19-2013 08:38 AM
AC Fan Motor Seized? jonny Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-13-2011 02:00 PM
zip dee seems to be seized camaronz Awnings 10 08-22-2010 11:09 AM
Awning unrolls while driving? Help! SoDakStreamr Awnings 18 10-24-2007 06:47 AM
Heat while driving? Krazykraut Airstream Motorhome Forums 4 12-08-2002 05:31 AM
