Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 01-18-2009, 08:46 PM   #21
CanoeStream's Avatar
St. Cloud , Minnesota
I left something out. Too light tongue loads (eg, < 10%) may result in a trailer that sways uncontrollably at anything more than the slowest speeds. Mid-1970 rear door Argosy trailers have very light tongue weights and display this instability if empty. This can develop into a very dangerous situation at speeds above 25 mph and well below highway speeds. Go into it with eyes open. Test drive away from other traffic & people.
5 meter Langford Nahanni
Old 01-20-2009, 06:43 AM   #22
1961 19' Globetrotter
1959 18' "Footer"
santa cruz , California
thank you all for exploring this brainstorm with me. and thanks for some numbers and better understanding, bob. if the trailer is every born, i will call it: Franken T, spawn of satan.
and please, if anyone has photos of airstream concession trailers for ideas that would be greatly appreciated. i found the www.cosmiccafefl.com which is VERY cute.
greenrig is offline   Reply With Quote
Old 01-20-2009, 07:52 AM   #23
cameront120's Avatar
1972 25' Tradewind
North Vancouver , British Columbia
Check out Bob Blumer's Airstream:
Bob Blumer - The Surreal Gourmet
North Vancouver, BC
cameront120 is offline   Reply With Quote
Old 01-20-2009, 10:34 PM   #24
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Another consideration is that with each additional axle, the inside capacity for equipment goes down. The wheel wells stick up about 12" above the floor and about 12" into the space as well. They are about 24" long for a single axle. By the time you add another one (or two?) axle(s), the usable space along the sides has pretty much eaten up 3 or 4 feet on each side. In a GlobeTrotter, that's a lot. I would think you would want to have all that heavy equipment resting on the floor - not on the wheel wells.
Shari
Old 01-21-2009, 07:00 AM   #25
1959 18' "Footer"
very good point shari. i guess i should explore the single beefy axle concept now that i have gone to the opposite extreme. i would like to hear some testimonials of those who have bigger vintage single axle airstreams and their experiences on the road when the worst happens. what does the trailer do when you get a flat? how does it act? i would imagine you can feel a flat coming? a blowout?
and thanks for the link, cameron. nice toaster!
Old 01-21-2009, 07:14 AM   #26
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Best way to avoid a flat is prevention by keeping good tires under the trailer.
Well balance tire and wheel assembly.
Covered from UV damage when not traveling.
Replaced when the age of the tire is too old.
And a good condition axle if you have a torsion axle. (This includes the spindle on mid-1960's GT)
>>>>>>>>>>Action
Action is offline   Reply With Quote
Old 01-21-2009, 07:35 AM   #27
The single axle is ok, but a tandem offers much greater payload capacity, as well as safety.
No, you normally cannot feel a tire going soft. A "blowout" especially on a single axle trailer, can easily cause a loss of control accident, unless you have a "HUGE" tow vehicle, like a semi-truck.
Which way to go, for you???
You must start with drawings, placing each and every piece of equipment you wish to have, in it's place, at least for starters.
That will basically dictate what you should and must do.
Only you know what all you want the trailer to carry, and then have it reviewed by someone that can create your project.
Opinions are always great, but facts are far more reliable.
Which trailer you chose, is very important as Action pointed out.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-21-2009, 09:11 AM   #28
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Shair's points about wanting to mount equipment solidly are certainly valid. However, by refrigerator is over the wheel well on my 34' Excella. It rests on a welded aluminum angle frame that supports the floor of the refrigerator compartment. You can see it in a couple of photos in this thread: http://www.airforums.com/forums/f425...aes-44474.html
Vaughan
vswingfield is offline   Reply With Quote
Old 01-21-2009, 05:18 PM   #29
1959 18' "Footer"
all my specs are real vague right now. i thought about building over the wheel wells too, but i have no idea of the dimensions or weight of any of the equiptment or even what equiptment and how its all going to fit together. so we continue to explore and learn. thanks all, for the input.
looking for ~22' dual axle 60's to 70's 64Safari Buyer Guidelines 6 08-07-2013 01:40 PM
Make of axle??? toastie Axles 11 01-07-2008 10:10 AM
dual axle conversion Randy Durand Axles 5 02-12-2004 09:21 PM
Shocks for a 68 Avion T-22 Dual Axle? 68 Suburban Shocks 1 10-18-2002 12:45 AM
