Old 03-06-2020, 04:32 PM   #1
2018 30' Classic
Lake Charles , SW Louisiana
Hub Inspection Question
Planning on doing an inspection of the hubs and brake assy. on our new-to-us 2018 Classic within the next few days. Am aware of the jack(ing) locations behind the rear axles but curious to learn if that's all that is needed in order to safely and securely lift both the front and rear wheels (same side) off the ground, pull and inspect the hubs, brakes, etc. OR if additional support is needed/recommended, i.e. the use of jack stands under the axles or accessible frame area when doing this type of work.
I did contact AS in JC and they stated all that is required is lifting/jacking from the rear (jack points).
Any other precautions or recommendations from others here who have done this themselves will be Greatly Appreciated.
"Finding the Roads that Await Us!"
Rick & Lydia Williams
rewillia is offline   Reply With Quote
Old 03-06-2020, 05:08 PM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Rewilla,
Your rig equipped with Nev-R-Lube bearings and drum/hubs?
Not the same procedures as older classic tapered cup cone bearing system.
Not trying to talk you out of it just a question and Nev-R-Lube requires a small snap ring pliers and IIRC 1 7/16 socket. Id have to check size. Also Dexter has specs on inspection allowable wheel play.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-06-2020, 05:23 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard...👍
Ck the manual or pull the wheel to determine which bearings you have.
Safest place to jack your AS. Where I put the stands for Winter storage.
ID:	362748   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 03-07-2020, 12:21 AM   #4
2018 30' Classic
Originally Posted by GCinSC2 View Post
Rewilla,
Gary
Gary, Yes, and thanks for asking; It is equipped with Nev-R-Lube's and I'm aware from reading the Dexter Manual the procedure for pulling the hubs to include the internal snap rings and 1-7/16ths socket as well as the torque settings and allowable wheel play.
With the trailer being new-to-me, and my 1st AS, I want to inspect the brakes to know where I stand in terms of wear and seal integrity. At present, I've seen no sign of seal leakage but again, just want to know.
Old 03-07-2020, 04:37 AM   #5
GCinSC2's Avatar
Good plan. Get to know what you have.
S/OS #001
Old 03-09-2020, 05:37 AM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Lift one side at a time. Block the tire of the opposite side before lifting.
>>>>>>>>Action
Old 03-09-2020, 05:53 AM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I leave mine hitched to the tow vehicle in park with parking brake on.
2019 Ford Expedition Platinum
Old 03-10-2020, 01:52 AM   #8
2018 30' Classic
Thank you all. The job went well and as expected, no issues. I did rotate the tires during the course of the inspection, ie. front to rear.
Old 03-10-2020, 04:55 AM   #9
GCinSC2's Avatar
No issues, good news. But don't you feel better knowing what's behind the drum? And how to get there.
S/OS #001
Old 03-11-2020, 03:32 AM   #10
2018 30' Classic
That was the intent all along, learning. It's a no-brainer now.
2017 Flying Cloud 30 ' Hub Mount / Stud Mount question twolanehwy General Repair Forum 3 09-24-2017 02:03 PM
Another Hub Cap question Bex All Argosy Trailers 4 08-08-2013 04:13 PM
Brake/ Hub temp question ck21084 Brakes & Brake Controllers 25 07-25-2010 09:11 PM
Bearings to hub question wayne.yl Axles 20 09-01-2007 09:33 AM
Hub keeper ring question noiva General Motorhome Topics 0 07-29-2006 10:20 AM
