Old 08-02-2017, 04:45 PM   #1
Richard
2006 30' Classic S/O
Merced , California
How to bolt the axel to the frame
I am not an Airstream mechanic; but I play one on TV.
I was under my 2006 Classic 30 changing the shock absorbers when I noticed how the axels are bolted to the frame. The bolts have two large washers under the bolt head and no washer under the nut. I find that kind of odd.
Everything is tight and the outfit tows perfectly. So is that proper or what?
kleimanr is offline   Reply With Quote
Old 08-02-2017, 05:06 PM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Must have been running low on washers that day. Mine had washers on both sides.
The axle perch is a tight fit between the frame rails and not going anywhere washers or not.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Floor replacement - c-channel bolt holes slipped 1in off frame holes tshannon Repairing/Replacing Floor &/or Frame 2 07-21-2016 04:07 AM
Floor to frame bolt holes dcole Repairing/Replacing Floor &/or Frame 1 05-27-2016 03:35 AM
Frame Mounted Eye Bolt for the Dog/Security dsaxon22 The Pet Forum 3 03-04-2014 11:31 AM
controller for tag axel brake lorcan Classic Motorhomes 5 07-01-2005 09:32 AM
Tag Axel Brake Voltage / Amperage 87MH Mechanics Corner - Engines, Transmission & More... 1 11-11-2003 09:25 AM
