Old 05-18-2021, 11:29 AM   #1
2021 28' International
Knoxville , Tennessee
Greasing Airstream International
I was recently advised to grease “shackles” and another thing I’ve now forgotten, on my trailer.
I can’t find anything under my 28 ft. International to grease.
Am I missing something??
Gibson3798 is offline   Reply With Quote
Old 05-18-2021, 12:11 PM   #2
2002 19' Bambi
Lafayette , California
Your trailer has Dexter Torflex axles which have no shackles in the suspension system. I presume the advice you were given was from someone referring to the shackles in a leaf spring suspension system.
There is very little one could grease under an Airstream. Our trailer has manual stabilizing jacks which I lubricate regularly, but that is with a shot or two of WD40 or something similar.
Tim
Tim A. is online now   Reply With Quote
Old 05-18-2021, 06:52 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
You are not missing anything.
Nothing externally to lubricate.
However repacking wheel bearings would be something to be done that involves grease. This would entail removing the tire & wheel assy. Then removing the hub assembly. Cleaning out the old grease from the hub and bearings. Then install new grease, inspect the brakes, install new seals and re-assemble
Not sure of the interval to repack wheel bearings on a 2021 model. And the owner's manual will give you guidance on that. In fact reviewing the Air Stream owners manual would be far more productive than greasing shackles.
Action
Packing and Greasing Bearing 1963tradewin Axles 15 09-16-2010 05:23 AM
Bearing greasing intervals slk Axles 7 06-09-2010 08:31 PM
Greasing bearings henw Axles 14 03-20-2010 06:16 PM
greasing bearings on 3500lb Henschen axle toastie Axles 1 06-28-2009 07:43 PM
Hensley Arrow hitch update-- greasing John Hitches, Couplers & Balls 0 04-17-2002 09:28 AM
