Old 11-30-2021, 08:56 PM   #1
2018 30' Classic
Mannford , Oklahoma
EZ lube axles
If you have Dexter EZ lube axles on your Airstream--Beware--
Do not use a grease gun to repack the bearing. It is too easy
to pump too much grease, blowing past the seal and fouling the
brake assy.
Instead of the grease gun, spend the extra money to have the bearings
repacked the conventional way.
geraldsmith is offline   Reply With Quote
Dexter E-Z Lube (not NevR Lube) Axles Al and Missy Axles 14 02-21-2022 07:55 AM
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
Dexter Never Lube axles boomerang1 Axles 1 07-21-2012 07:59 PM
Dexter Disc equipped axles never-lube bearings - maintenance dznf0g Wheels, Hubs & Bearings 4 08-17-2010 04:35 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
