02-13-2023, 01:34 PM
2009 25' FB Classic
Scottsdale
Distance from axle to axle
Can anyone inform me of the distance between the two axles on a 25ft airstream? I'm unable to find this information in any documents from Airstream. I'm looking to make a 2x8 long enough to drive the trailer on to keep the tries off blacktop while in storage. The trailer is over an hour away at the present time and I'm unable to get to it for a while. Thanks
Bob & Julie # 5587, 4CU in AZ
02-13-2023, 01:41 PM
2002 25' Safari
Dewey
On mine it is 33.5 inches from center to center. 48 inches would be plenty.
Richard
02-13-2023, 03:12 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I use these....early version
02-13-2023, 05:32 PM
Escape Pod II
2022 23' Flying Cloud
2018 22' Sport
Orange
Allow me to add my two cents in by recommending that you chamfer the boards on the ends.
JEWare
02-13-2023, 07:42 PM
1988 32' Excella
Robbinsville
, New Jersey
If you don't chamfer the boards go with 5' in case one slips a bit when you try to get the trailer on them.
02-14-2023, 07:55 AM
2009 25' FB Classic
Scottsdale
Thanks to all fellow Airstreamer's I will make them 5ft with a 45degree cut. That will allow some room to play with.
02-14-2023, 09:16 AM
1988 29' Excella
Lorena
block at end?
FWIW, I use something similar in my Airstream shed. It's attached to the ground with stakes to keep it from sliding. Likely not something you can do. One thing handy for me is a block at the far end. I leave a chock against that block and back up until I feel the trailer on the chock. That keeps me from overshooting the board. It also makes sure that the trailer is in the same place every time.
02-14-2023, 09:21 AM
2008 25' Safari FB SE
Airstream - Other
Port Orchard
Why do you do this? I am parked on cement, do I need to raise the tires off the cement?
02-14-2023, 09:36 AM
1960 26' Overlander
Tipton
, Iowa
Julie-Bob, a word to the wise. Use your long board only on pavement. I used about a 3 foot board on soft/wet ground. The tire pushed one end of the board into the ground and the other end was forced upwards into the bottom of the trailer, ripping the belly pan. It was not a happy moment!
02-14-2023, 10:32 AM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
I don’t do anything extra, just park on concrete, outdoors in a covered, open air trailerport. Is there some reason to do this because of the blacktop?
02-14-2023, 11:12 AM
2022 28' Flying Cloud
GAINESVILLE
, GA
We’ve got 33” between axles (measured at the center on each hub) on our 28’.
02-14-2023, 11:27 AM
2013 25' Flying Cloud
Wheaton
Pay the extra money and use 2” x 12”. Don’t have to be so exacting and gives more room for error when lining up.
Greg
02-14-2023, 08:41 PM
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake
Hoss pads
Recycled Tire Rubber squares made in the USA. I use them for storage tire pads, on the road as leveling pads or under the stabilizer jacks if necessary. Available online or at a Camping World.
02-15-2023, 12:21 AM
2008 22' Safari
Spicewood (W of Austin)
Originally Posted by hairyclive
Airstream trailers generally do not have springs in the suspension. It’s important to know WHERE to “jack” up an Airstream or you can cause significant damage.
There may be a “jack-pad” fore or aft of the axle itself …a place designated for placement of a jack for lifting the trailer. Otherwise, carefully placing the jack on the frame or axle-attach-brackets themselves may be done.
But do NOT jack an airstream with rubber-torsion suspension by lifting directly on the axle or permanent damage to the axle can occur. The square body of the axle “tube” is hollow and filled with rubber rods that provide the flexibility for travel and the axle-tube can be deformed/crushed if it is lifted directly upon a jack.
Even experienced “Tire Stores” and shops cannot be trusted to know how to jack up an Airstream trailer…. so it’s important to educate them if you let them jack your Airstream trailer.
02-15-2023, 10:44 AM
2017 25' International
West Lake Hills
Two-by for my 25FB is 56 inches long. I used this Hopkins 08200 Endurance RV Leveling System with Wheel Chock. I built it as a tandem not a separate unit for each wheel. My driveway slopes east-west quite a bit. If I were to do it again I would either have a set for each wheel or forgo the Hopkins and angle the ends of a 2x12. The long distance to drive up on these require perfect alignment due to their length...I little more width would be nice.
