Old 11-15-2018, 01:23 PM   #1
GuitarmanFL's Avatar
1972 27' Overlander
1971 31' Sovereign
Orlando , Florida
Dexter says "subtract tongue weight from GVWR to determine Axle rating"
"The axle capacity is usually determined by subtracting the hitch load from the Gross Vehicle Weight. The remainder will be the load to be carried by the axle(s). When making this calculation, be sure to consider the final load distribution. If the weight is shifted off-center laterally, the load imposed on the wheel(s) on the side closest to the load center will be greater. The load on the heavier side must not exceed one half the rated capacity of the axle(s)."
Source: Page 10 Dexter Applications Manual, downloaded today. November 15, 2018.
This means that if my Airstream is 6,300 GVWR and my Tongue is 1,000, my 3,000 axles can easily handle 6,300 pounds... so no new axles needed. They are only carrying 5,300 pounds, and my hitch (actually) 950 pounds.
Also, they are currently tracking at about 5 degree down, and Dexter further states that under load, your arms should be near zero degrees...
So, according to the guys that build these things. I'm good.
Yay!
The Shifty Drifter.
2018: 7500 miles: FL to Co
2019: 7500 miles: FL to Co
GuitarmanFL is offline   Reply With Quote
Old 11-16-2018, 06:08 AM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Do you know the individual axle load?
Or side load?
That is part of the directions as well. Typically each wheel position can be loaded un-equally.
>>>>>>>>>>>>>>Action
Old 11-16-2018, 06:30 AM   #3
dznf0g's Avatar
Oswego , Illinois
This isn't new....but little known. As long as one adheres to the numbers, their statements are true and logical.
-Rich-
Old 11-16-2018, 06:33 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Good point.
At least, get a trailer weight loaded for camping with WD set and get axles that total 500lb more than the actual weight on them.
Example...I have 7640lb on the Classics axles and would get 2 4000lb if I was going to replace them.
But I'm a bit anal about it and unload them during storage...SFSG. 😗
For Guitarman...
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 11-16-2018, 07:03 PM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My axles are rated at 5200 lbs each...there are 1050 lbs on the hitch...2013, 31’ classic....when fully loaded..7800 on axles...
Old 11-17-2018, 08:27 AM   #6
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Our 2014 31' Classic has 5,000 pound rated axles which are more than sufficient for our loading:
Classic Scale numbers May 2014
……1200……——1200
2034……2042—4076
1921…….2062—3983
Total weight——9259
Michelin LT225/75R16/E LTX M/S2 tires
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Old 11-17-2018, 08:45 AM   #7
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
……1200……——1200
2034……2042—4076
1921…….2062—3983
Total weight——9259
...wow..your tongue is 150# heavier....?
Old 11-17-2018, 08:49 AM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Yes, you are good to go. You might also jack up each wheel to see the range of Travel eft in the axle. My 6800 gvwr trailer carries 5600 on the axles when we travel. Not quite the whole tongue wt is carried by the tv. The ad hitch transfers some back to the trailer.0
Old 11-18-2018, 08:10 AM   #9
switz's Avatar
2014 31' Classic
Images: 8
We have a 600 amp-hour lithium battery under the front sofa (about 168 pounds) along with the Magnum MS2812 converter/charger. The tongue weight is down from 1,375 when we had four 96 pound 300 amp hour 6Vdc batteries in a custom stainless steel enclosure on the tongue behind the propane tanks.
We also have the Disc brake pump and controls in the original battery box.
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
"Weight Carrying" vs "Weight Distribution" PasoArt Towing, Tow Vehicles & Hitches 2 01-11-2016 08:04 PM
GVWR...the "Law" or a "Guide"??? TomR Tow Vehicles 8 11-16-2007 06:23 PM
Tongue weight, how determine? pilgrim_still Towing, Tow Vehicles & Hitches 6 06-17-2003 03:45 PM
