Old 10-19-2021, 04:07 PM   #1
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
Dexter axles application limits on AS triple axle trailer
Just read this warning at the dexter q/a site.
TORFLEX - Can I use 3 Torflex axles under my trailer?
No, Dexter does not recommend triple Torflex applications because Torflex axles are totally independent and not equalized like a typical leaf spring set of axles. There is no ability to transfer loads from one axle to another. When traversing uneven operating surfaces such as driveway entries, railroad crossings or speed bumps, the entire load can be put onto one axle causing severe overload. It isn't reasonable to expect one axle to carry the entire load of three axles when these conditions occur, even though these instances cause only momentary over-loading.
Has anyone else heard this limitation to dexter axles on AS’s’s?
"The significant problems we face cannot be solved at the same level
of thinking that created them." -Albert Einstein
wayne.yl is offline   Reply With Quote
Old 10-19-2021, 05:48 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
That disclaimer has been on their website for a very long time.
Action
Old 10-23-2021, 02:15 PM   #3
1987 34' Limited
Hantsport , NS
Our triaxle Dexter replacement units just landed. The original 1987 Units were torsion axles, installed by Airstream. Install the proper shocks and drive with consideration of what you are pulling. Disclaimers are litigation repellent to protect against the lowest common denominator. My favourite is “…while on cruise control don’t leave the driver seat to use the toilet ….”
Daytonacoupe is offline   Reply With Quote
Old 10-23-2021, 02:34 PM   #4
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
I mean, there's not much other choice. I replaced the three original axles under our AS with Dexters... The originals would have had the same problem.
88Limited is offline   Reply With Quote
SOLD: One half of a Dexter Axle Lift Kit K71 724 02 for 11 Axles - Colorado tinytiny Airstream Classifieds 4 12-07-2021 05:37 AM
Axles: Dexter, Leaf Springs, Coil Springs, Straight Axles Ray Eklund Axles 22 09-10-2016 06:02 PM
Triple Axle versus Double Axle Mabeygal Axles 12 08-09-2016 04:21 PM
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
