Old 05-20-2020, 11:53 AM   #1
1977 31' Sovereign
Senatobia , Mississippi
Can I reuse my disk brakes
I have a 77 Sovereign needing axle replacements. The current axles have hyd/vac disc brakes that have been converted to hyd/elec. My thought are to buy the bare beam axles and reuse my current disc brakes and hubs.
My main thoughts are the disc brakes are better than electric so why not save $400 and retain the better stopping power.
I'm sure there are sides to this issue that I have not thought of so needing input as to if this is a good idea or not.
Kevin
kscarter is offline   Reply With Quote
Can I reuse this Belly pan? megan1968 Belly Pans & Banana Wraps 9 03-31-2020 09:42 AM
Vacuum Disk Brakes APB Brakes & Brake Controllers 27 07-04-2019 10:33 AM
disk brakes HubbyBear Member Introductions 2 04-03-2006 10:50 AM
Rotors for vacuum disk brakes wvmiller Brakes & Brake Controllers 4 10-21-2002 04:43 PM
conversion from vacuum/disk to electric brakes excelladep Brakes & Brake Controllers 2 05-30-2002 11:54 AM
