11-16-2020, 01:40 PM
1984 31' Limited
North Pole
, Alaska
Broken Wheel / Axle
I am new at this "forum" stuff - so please bear with me - I have a 1984 31ft Avion travel travel trailer.
Yesterday, as I pulled out of the driveway, my driver's side, front wheel assembly literally broke off the end of the axle, on my Avion. It looks like it broke off right at the weld where the wheel assembly/knuckle is attached to the axle tube.
How should I go about fixing this?? I do have a replacement axle I purchased several years ago.
11-16-2020, 01:50 PM
Moderator dude
1966 26' Overlander
Phoenix
Welcome to Air Forums!
Your Avion has a very different suspension and running gear than an Airstream.
Your Avion has leaf springs with an axle tube. Air Stream does not have this arrangement.
With that said, I believe your assessment is correct. The weld or the joint failed. You said you have a replacement axle. Does this include the brake assemblies attached? If yes you have solved the problem and swap out. Fortunate for you!
If not, you might be able to consult a local welder that can reattach what has come apart. Reattachment may mean welding some support to the stub that extends into the tube for a distance of 4 to 6inches past the clamping point. The trick or high skill set is getting the alignment correct of the axle end to the axle tube. A 90 degree in all directions of the axle end to the axle tube would be necessary.
Action
11-16-2020, 01:53 PM
Moderator dude
1966 26' Overlander
Phoenix
And it looks rather catastrophic!
Do check the other axle ends for cracking.
Action
11-16-2020, 02:33 PM
1994 34' Excella
Warren
, Manitoba
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
11-17-2020, 06:12 AM
1984 31' Limited
North Pole
, Alaska
Thanks for replies to Broken Axle
Thanks Action and CB Wells for your replies.
It looks like I will be using the spare axle - I called around yesterday (Ft Worth, TX area) and discovered, nobody really wants to work on the broken axle - started with a Dexter factory/plant locations in Indiana and Oklahoma; got referred to some TX trailer locations and got more referrals, but no service help. I was pretty sure going into the phone calls, that only a few places would probably have the know how to weld the axle back together properly -- does anybody know of a location that does this kind of work??
What caused the failure?? I don't know - I am pretty sure I was not over weight. I travel by myself. I have only owned the Avion for six years, and my Dad had it for six years prior to that. So, that leaves alot of of time (since 1984) unaccounted for.
Two of the four axle halves, have Dexter metal tags with weight limitation of 5200lbs max. I am assuming one tag is for two axle halves; therefore a max weight for the trailer of 10,400lbs and 5200lbs "per axle pair."
The "new axle" has a fleetwood sticker on it and also a Dexter metal tag, but no weight limitation. It appears to be the same style. It does look like the spindle is useable; just needs some cleaning up.
Are there any tips to how the actual replacement of the axle should proceed?? Looks pretty straight forward with removing the four nuts off the spring hanger U-bolts and the nut/bolt from the center of the trailer mount.
One thing, it looks like I need a new bushing for the center trailer mounting bolt - anybody know where I can get one??
Again, thanks for your inputs!!
Paul B.
11-17-2020, 10:25 AM
2005 31' Classic
Venice
Looks to me that a boat trailer axle will work. Change them both out ! My, you are very lucky...what if that happened in the middle of nowhere. $$$$$$$$$$$$$$
11-17-2020, 10:59 AM
Moderator dude
1966 26' Overlander
Phoenix
Paul B.
If you are going to pursue a welded repair (and I would even if it is a spare) seek welding shops not axle shops. I know it is an axle, however axle shops, spring shops and trailer shops may never see your situation. If they do likely they do not have a person that is skilled to make that kind of weld. Find a shop or a guy that only does welding. A person that has done welding for a long time and lots of jobs. Welding technology has changed since the 1980s just like everything else. A welding shop will know how to address the break and if it can be repaired will be stronger than the original work. Actually the more difficult part might be alignment.
As to axle replacement and that procedure, your guess is as good as most of the people reading this thread in the Air Stream axle forums. Because an Air Stream axle is mounted quite differently than the axle you have on your Avion. Air Stream axles bolt into a slot and there are no leaf springs. The springs are rubber torsion rods that are internal to the axle housing.
Good luck.
Action
11-17-2020, 12:11 PM
1994 30' Excella
alexandria
, Kentucky
The most cost effective and best option would be to install the new axle and be done. With your trailers leaf spring setup it is not really a tough job - estimate an hour or two of shop labor. Other options would include taking it to a welding shop as already mentioned or you could call Axle Surgeons and could probably fix it along the side of the road. You would have to call to see if they have someone in your area.
https://axlesurgeons.com/
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
11-17-2020, 12:18 PM
1976 24' Argosy 24
1999 30' Excella 1000
White Haven
, Pennsylvania
Honestly. For me. I would bite the bullet and replace both axles. Why screw around. Axles and brakes are the foundation of your safe travel.
11-17-2020, 12:20 PM
Moderator dude
1966 26' Overlander
Phoenix
Cool!!!!
And that has to be an expensive service. But if one has 80,000 pounds of pay load connected to a over the road tractor with a broken axle on the interstate, the service would be less dollars than towing the 18 wheeler into a shop.
For the OP in his driveway, it might be a bit pricey to use that service. However the phone call would be free to find out more.
Action
11-17-2020, 12:32 PM
1994 30' Excella
alexandria
, Kentucky
Originally Posted by Action
Cool!!!!
Action
My friend and his brother have a franchise here in KY with Axle Surgeon. They work on all kinds of trucks and equipment, anything from 3/4 ton trucks, trailers to earth moving machines. Semi-tractor trailers are their bread and butter. They can have a truck or equipment back in service within a day of the call. It often takes weeks to order a new axle for something vs short down time. Their price is much more cost effective than ordering a new axle for a large truck.
WBCCI # 3072
11-17-2020, 12:42 PM
1988 32' Excella
Robbinsville
, New Jersey
As for cause, tight turns on pavement or concrete can put tons of force sideways on axles with a tandem or triple axle trailer, often when backing up.
11-17-2020, 01:16 PM
1976 24' Argosy 24
White Haven
, Pennsylvania
also. It's not really that expensive to replace the axles. If your handy it can be done in your driveway.
11-17-2020, 07:41 PM
Cedar Hill
Paul,
This guy may be near you (Ft. Worth). Paul (that should be easy to remember), 817-9193651. I don't remember his business name, just that he works on AS and Avions. Also, don't know if he works on axles.
Next I would try is Quality RV Solutions, Alvarado, TX. 817-764-1363
Good luck.
11-17-2020, 08:52 PM
1984 31' Limited
North Pole
, Alaska
Thanks for your inputs
Thanks to everyone - I am making progress - more to follow!!
Paul B.
11-18-2020, 04:04 AM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Cayo Repair Services in Michigan. Sons of the original owner of Avion.
11-22-2020, 02:21 PM
1983 31' Excella
Choctaw
, Oklahoma
Paul B.
If you could get it an off. Take it to a oilfield machine shop. That should be able to put it in a lathe and weld it and balance it. We use to balance drive shafts and cooling tower shafts this way.
Tom C.
11-22-2020, 03:47 PM
1960 26' Overlander
Tipton
, Iowa
Avion Axles
Like was said earlier, Avion axles are not like Airstream Axles. My parents had an '83 and if I remember correctly they are only HALF axles...they do not go all away across the trailer. Have you tried a Semi trailer repair center? I have had good luck with them when I needed to get the bushings replaced on my '60 Airstream that has leaf springs. They were happy and able to assist finding the parts that I assumed were no longer available. Your Avion axle will need to be aligned. The process to do it should be included in the owner's manual...it was for my parents.
11-22-2020, 03:50 PM
Niagara Falls
, Ontario
If you have a local shop that builds custom or race cars many of them have jigs for shortening rear drive axles.They should be able to reweld the end in proper alignment. You could also try some of the local cargo trailer builders.
11-23-2020, 12:58 PM
1957 22' Custom
San Diego
Our 1957 Airstream has a leaf-spring-mounted drop axle similar to yours. Regarding the bushing you want to replace, you can get replacement bushings (also U-bolts) from companies that sell them by their size, dimensions, etc. (You probably won’t be able to find anyone that sells such bushings by only referring to the make and model of your trailer.)
For example, a company named SD Truck Springs (New York) has a chart with pictures of various bushing types and a list of available sizes — click on https://www.sdtrucksprings.com/bushi...pring-bushings — I found exact replacement bushings for our old Airstream. (You must first remove an old bushing and exactly measure all dimensions with an accurate caliper.)
While searching for replacement bushings, I found a company in Texas named Southwest Wheel that sells trailer-type leaf-spring-mounted drop axles in widths (measured between hub faces) from 45 to 95 inches, complete with brakes and bearings, for under $500 each — click on https://www.southwestwheel.com/p-303...iler-axle.aspx — the spring seats are included loose, and should be welded in the same locations as the spring seats on your old axle.
