Old 06-23-2021, 11:58 AM   #1
1991 34' Limited
Tucson , Arizona
Bent axles - How to know?
Okay, I was an idiot. I didnít know what I didnít know. 1991 34 foot Classic Limited. So I jacked up the trailer and placed jack stands under front and rear axles for the winter. Came back months later to broken patio tiles under three jack stands.
How do I know if the axles are bent?
Will be replacing tires soon and donít want to ruin a new set.
Hikingsolo is offline   Reply With Quote
Old 06-23-2021, 12:10 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I do not understand. (not unusual for me). Did it fall? Did you jack the axles in the wrong place? Did it have the wheels and tires still on it? Just cause the weight of the trailer broke some tiles under the jack stands would not make me suspect the axles are bent. Just that the load was too concentrated on the tiles. Think wooden pads under the jack stands next time. I think the only way to tell is to run it and watch for tire wear.
I just leave my trailer sit on the wheels and tires.
Old 06-24-2021, 05:05 AM   #3
1991 34' Limited
Tucson , Arizona
I jacked it up with a hydraulic jack on Nader the axle instead of at the jack points. Then I slid in the jack stands. Iím told this is a no-no.
The trailer also sits on its tires, but I had two valves go bad over the previous winter and I was concerned that the trailer would be flat on the ground next spring.
Old 06-24-2021, 05:16 AM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If you're really worried take it to an alignment shop. The manual should show the proper angles for the wheels (toe in & camber). They can put their LASER alignment devices on the wheels and confirm. As long as things measure to spec you're good to go.
Richard
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is offline   Reply With Quote
Old 06-24-2021, 05:33 AM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The wear on your tires will tell you if you have a problem.
Richard
Old 06-24-2021, 10:42 AM   #6
1991 34' Limited
Tucson , Arizona
Thanks. Alignment shop. That’s a great idea. I’ll see what I can find around our summer spot in Show Low, Arizona. Small towns are sometimes a challenge.
Old 06-24-2021, 11:08 AM   #7
mykytiukr's Avatar
1965 24' Tradewind
almena , Wisconsin
Camber!
You could also go to a tool store like Harbor Freight and buy a cheap angle finder and check it yourself. Best to take the tire and drum off and place the angle finder against the machined axle face. As level as you can get it! You can look up the specs somewhere but should be between 1 and 3į positive camber meaning the top of the tire should be leaning out. Unless you jacked it from the center of the axle I highly doubt you bent anything. Unless you know and trust the alignment shop I discourage it. A degree out spec will have little effect on tire wear and you donít want these guys bending your axles unless it really needs it!!!
mykytiukr is offline   Reply With Quote
Old 06-24-2021, 11:12 AM   #8
amxpress's Avatar
2021 22' Bambi
Clayton , North Carolina
You can buy a Camber gauge on eBay or Amazon for less than $20 that will tell you if you have excessive Camber on each wheel indicating a bent axle sahft.
amxpress is offline   Reply With Quote
Old 06-24-2021, 11:20 AM   #9
1996 25' Excella
Tillsonburg , Ontario
Next time jack on the frame the axles are mounted on
Watched Dexter Axle tech change brakes on a 34 at the Int’l Rally in Escanaba. He jacked up one side at a time using the axle mounting frame and changed all three brake back plates while on the jack.
JCW
JCWDCW is offline   Reply With Quote
Old 06-25-2021, 04:47 AM   #10
1991 34' Limited
Tucson , Arizona
Thanks for the suggestions. Iím feeling better about being able to check out any damage I may have introduced. $20 is a small price to pay for peace of mind.
Old 06-25-2021, 05:47 AM   #11
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I am thinking that you jacked up the axles close to where they are bolted to the frame so that the moment arm that would cause them to bend hopefully was not enough to permanently bend the axles. Good luck.
Dan
TouringDan is online now   Reply With Quote
Old 06-25-2021, 07:47 AM   #12
1976 31' Excella 500
Chappell Hill , Texas
If you supported it real close to the mounting flanges there was probably no harm done. Those axles are THICK steel tubing. Still in the future I'd make sure to support it under the mounting flange jack points.
tbashin is offline   Reply With Quote
Old 06-25-2021, 08:50 AM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
More important...Are they still aligned?
We had inside edge,frt curb/side tire ware, checked alignment, excess toe-out. Assumed a bent axle, turned out to be the rubber torsion spring was worn out.
MacGyver's helper using checking stick....
ID:	398183   Click image for larger version
Obrigado, ť hora de descansar.
Tahawus
Old 06-26-2021, 06:56 AM   #14
1991 34' Limited
Tucson , Arizona
Thanks for the heads up and the pictures! Very helpful.
Old 06-29-2021, 06:03 PM   #15
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
"I jacked it up with a hydraulic jack on Nader the axle instead of at the jack points."
Alumacoot
ďWe are confronted with insurmountable opportunities.Ē
Dan and Liz is offline   Reply With Quote
Old 06-30-2021, 05:00 AM   #16
1991 34' Limited
Tucson , Arizona
on Nader=under in autocorrect speak. Sorry I didn’t notice the mistake and now can’t seem to correct it.
Old 06-30-2021, 06:10 PM   #17
1987 25' Sovereign
If you jacked at the outer ends near the hubs, you’re probably fine.
Alumacoot
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
I thought my new axles were bent!!! DryFly Axles 23 10-14-2013 01:22 PM
help! bent torsion axle and dont know if should replace Modern South Axles 14 04-01-2013 09:55 PM
Bad axles, rough road, bent frame Lumatic Axles 0 05-21-2007 08:24 PM
